Can anyone chirp when shifting?
To punish and enslave
I'm having trouble chirping my tires when shifting from 1st to 2nd. It feels like the clutch is slipping or something. Does anyone have tips on chirping in this car? I'm talking about the 3.2 by the way.
whats up with all the hazing of the young people? I mean really?? He just asked a damn question.
TL CHROMETIDE, I apologize for how rude some people are. You have been here for a while so you surely know how flaming goes here and there.
Anyways honestly I didnt know about the VSA button until about a week after I had the car and I was at an acurazine meet in VA and someone pointed it out to me. Really though the CAI made a big difference in this area, and the pulley made an even bigger difference.
You youngsters have it so easy these days - when I was 17, I had to neutral-drop my mom's 1981 Pontiac Bonneville to get any tire squeeling action! If there were internet forums back then (1992), I'm sure I'd get flamed as well...
Just watch yourself out there and drive safe.
You can do it without turning off the TC, I never turn my TC off and it happens on occation. If you shift at the redline and then shift very quickly (including letting the clutch out fast) it will just happen. I cannot speak for 2nd to 3rd, that might require turning off the TC.
Pimpin' Ain't Easy!
wow i must be lucky - or unlucky... however you look at it.
my tires chirp even when VSA IS on... let alone off I can do a decent burnout... trying not to tho...
I dont even try to chirp the tires, and im not slammin on the gas lol. I have an AT btw.
OP - sorry for the @$$hats all hatin on your age... they got beat up when they were 17 - thats why they are bitter.
~Da Nocturnal Cheetah~
I never turn my VSA off, and I have done BOTH (1-2, 2-3) on occassion. However, I burned so much rubber in earlier years that I realize the expense of tires and don't get into that now. I don't agree with the comments about it being unsafe though, because I have NEVER spun out of control. In fact, in earlier years, I used to love popping and snatching it and making the chirp and full burn-outs when I wanted to and in a controlled way. I could make a friggin cloud of white smoke and not move in my 5.0 Mustang!
Yeah, buying new tires will make you cut that out one day as well! Have fun, but just be smart!
Pimpin' Ain't Easy!
lol, i have to get new tires before winter anyway... so i might have fun this summer with these POS's...
Originally Posted by HiTEC
I can chirp the tires in my wifes Hyundai Accent. So it don't really take that much power. I think the car has 110hp.
My Daily Driver
1 Post
That would be the reason for the 3rd gear chirp. I got it once in my 05 with the stock 17's before I replaced the tires. No way in hell I could do it with the 19's unless I get the procats, thermoblock spacers and finish the exhaust......doubtful even at that.
So is it just shifting fast? What is the proper procedure to do it?
Registered Member
Originally Posted by TLFourplay
a couple of ways. first off hit your VSA button. Take it to or close to redline and shift and immediately floor it. Should acheive desired result. Another way (not really recommended in a nice car or a car that you car about) is to get going in first and get about 250rpm's away from redline and shift gears while keeping pedal floored. This will cause your engine to bounce off of redline while you engage the gear. Hell on the clutch though. I used to do that in my 95 GMC Sonoma but no way I would do that in my TL.
Registered Member
o Turn the VSA off.
o Launch the car with aggression.. as in just this side of smoking the tires.
o Once the clutch is fully engaged, nail the throttle.
o Do your 1-2 shift around 6000 to 6200 RPM and do it quickly (speed shift, don't power shift).
If you do this right and your clutch has no appreciable wear, and its support systems and components are good, you should be able to break traction in 2nd and 3rd gears (first will be mostly smoke).
I have to ask.. why do you want to do this? Just to showboat??
Back in a TL again.
I ROASTED THE TIRES IN TO THIRD AND CHIRPED In FOURTH ON THE 07 TLS. TEST DRIVE WAS FUN...
disengage the vsa
-from start or rolling rolling would make more sense
- rev it close to red line and shift with out letting go of the gas you only need to push the clutch in half way once your use to driving stick..
-you also really need to practice shifting quick....
-and make sure you and your shifter are one cause its really easy to go lets say from 4th to 3rd instead of 5th...for some noobs.
- do that in every gear I've done it on my 00 Si the whole time i owned it i put close to 20k on the car and clutch and engine didn't get harmed as far as i know... kid still driving it that i sold it to...
disengage the vsa
06 TL 6spd. Navi/A-spec
Yes i can chirp gears when shifting, no i dont do it! Reason being it can badly damage your clutch and cause a mess that looks like a birds nest between your trans and motor, also could lead to future trans problems. But if you want to beat on your car its your decision, but i would expect mechanical problems in the future!
I guess I won't do it. or I'll at least wait until the end of the year when the car gets turned in. I tried it ONCE and nothing happened so it was whatever, I haven't done any hard shifting since. I wanted to try it because some my friends were doing it and I felt that I had to try it at least once.
2004 SSM/EB/5AT/Navi/RSB
Chirping in FWD doesn't take much magic. It can certainly cost a bunch though. While there's very little risk of losing control, your CV joints won't be too happy with a bunch of chirping.
LOL...but what is the point of all this "chirping" when BOVs sound so much better not even redlining to a point where your engine explodes and the "whizzing" noise of a supercharger in a car rackin up mphs??? Just don't chirp anymore, serves no purpose, if you wanna get noticed....get turbo or s/c....less stressing your engine and you'll also get better recognition from those who are 'checkin' you out...
CHIRP -
TURBO -
S/C -
CHIRP -
TURBO -
S/C -
05/5AT/Navi/ABP/Quartz
If you decide to learn how to do it, this is the most correct post from one of the most experienced drivers. SouthernBoy also makes his clutch last almost forever using proper shifting technique. Do a search and learn how.
Originally Posted by SouthernBoy
My friend, there is nothing magical or special about getting gears (this is an old saying which means breaking traction during aggressive shifting). I can get rubber (another old saying which also means breaking traction under the same circumstances) in 1st (of course), 2nd, and 3rd gear in my '04. If you really want to know how to do this, here goes.
o Turn the VSA off.
o Turn the VSA off.
Originally Posted by fish008
Anyone ever chirp the tires downshifting to slow down? I have never done this in my TL but I was able to do it in my Civic many years ago.
Actually as a matter of fact I just did this today. I was taking some backroads here in Germany that I have never been on and I had all my windows down. I was really getting on it too and I had to REALLY slow down for a turn so I downshifted at 85 to third and I heard both the front tires lock for a sec. It was pretty neat. I put her through her paces today let me tell you but gosh damn I love that car. Bitch of it all was when I went to wash my car tonight after all the spirited driving I noticed my R/F Ron Jon center wheel cap was missing.. damn.
Registered Member
This is very bad technique and should be avoided. When downshifting, if you do it correctly, a passenger in your car should be totally unaware of what just took place.
Registered Member
Well I am going to defend myself by saying that either I had to drop clutch fast and engine brake in conjunction with regular brakes or I was gonna go off the road. Of course as noted by Southernboy this is NOT the preferred method of downshifting.
Registered Member
So exceptions can and do dictate how we do things.. absolutely.
Team Anthracite
chirping i guess is ok if u are trying to accel fast.... =)
look at some quarter mile vid! =) u see chirping 1st-2nd-3rd gear =)
=) or if u want.. look at integra type-r LOL =)
SidhuSaaB
05-30-2020 12:40 AM
Hines57
09-24-2015 01:58 PM
