Can 2010 Accord 6 speed tranny fit '04 6 speed TL?
I have a 04 TL which I'm planning to change the clutch. My transmission might be gone also. My friend crashed his 2010 accord coupe which was 6 speed. He told me he'd give me the tranny for the "homie " price if it fits. I know his motor is j35 and mine is a j32a I believe. When I was shopping for a clutch, I noticed that both vehicles used the same clutch. Will the j35 tranny off a 2010 accord fit on my 04TL?
Originally Posted by ExtraslowTL
(Post 16028540)
How did you make this determination? :scratch: |
Although the clutch assembly/flywheel the same, the transmission ratios are different, but that doesn't mean it won't fit.
TL/Accord 1st, 2nd, 3rd, 4th-same 5th .975/.976 6th .770/.771 Final 3.285/3.550 Trans case is the same and most of the transmission parts are the same, but looks like the Accord doesn't have limited slip. |
I don't know much about Honda's. I'm a Nissan guy who decided to try something different and bought a TL. I've searched online and have found conflicting information. I thought my transmission might be gone because I currently only have 1,2 and R. It shifts smoothly into 3-6 but won't move. A friend came over weekend and told me my clutch is done but my tranny is fine.
(Post 16032680)
Assuming your clutch is the issue, it is highly recommended you replace the gear oil in the transmission with ACDelco 10-4014 Friction Modified Synchromesh Manual Transmission Fluid (it takes about 2.3 quarts); this MTF will make a huge difference in how well your transmission shifts as well as how long it lasts. https://cimg0.ibsrv.net/gimg/acurazi...341cc5c303.jpg |
(Post 16032699)
I'm curious, when you make the 2-3 shift while moving along at say 20 mph, what happens when you press the accelerator pedal?
(Post 16032788)
I need to do some research on what these Honda transmissions like. I normally go with Amsol Manual Synchromesh.
(Post 16032680)
Doesnt matter what size engine it is. It should fit. The trans case and bolt pattern are the same. Thats all that matters. You will get better gas mileage but slightly less acceleration with the accord trans. Also will lose your LSD unless you swap it from your trans into the accords trans.
I would not do anything until you figure out why your gears are not working properly. Most likely your TL trans is not bad. |
