BSR in drivers door
BSR in drivers door
yep, I'm sure without a doubt this has been brought up before . . . so please bear with me.
today, while driving heard a faint BSR. Pushed against the map holder or whatever you want to call it and it went away. Then pushed against the trim closer to the door handle and it went away, then pushed against the trim closer to the rear view mirror and the noise went away.
anyone have this problem and if so, could you clarify where? I hope it's the map holder since I'm not in any mood to have the dealer rip apart my door trim, damaging clips etc, to only end up with a bigger problem.
any help would be great
Shift_faster
Originally Posted by srhewes
What's a BSR? That would help for starters...
http://www.acura-tl.com/forums/showt...7&page=1&pp=25
Good luck.
Does anyone read this
Yup I have this same problem with my driver side door at the same spot by the rearview mirror. It’s not the map holder but the door panel itself that is squeaking. I notice that if I have my window all the way up it will squeak but then if I barely crack the window it will stop. Now when I say crack I mean no air can get through the window but it is still up.
If you notice when you roll up your window all the way the door panel flexes outward. I believe when it is flexed out like that there are two peaces on the door panel that rub together. I know what two peaces they are too.
tman570
06-11-2019 07:56 AM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
