Brightest Fog Lights. Please help
Old Oct 2, 2012 | 07:49 PM
Nrp603's Avatar
Exclamation Brightest Fog Lights. Please help
I am unsure if i want to get the HID fogs, but what are the brightest bulbs i can get that will look like the stock HID headlights
Old Oct 2, 2012 | 09:34 PM
truonghthe's Avatar
the color temp would be 4300K or near that range.
Old Oct 2, 2012 | 10:08 PM
ParaSurfer1979's Avatar
No... If you want fogs lights to do what they were meant to do which is cut through fog and rain, the best thing is a yellow bulb. Putting hids in reflector assemblies not made for HID's will only scatter that light every which way and would actually hender visability more than help unlike hid's in projectors like HID/LED headlights use.
My opinion would be to swap oem bulbs which are 35watts (same as DRL) and swap for 55 watt Nokya Ion Yellow bulbs. But thats if youre looking to keep you lights for great visibility effectiveness. Otherwise swap for hids.
Old Oct 3, 2012 | 06:15 AM
truonghthe's Avatar
^^^^OP want brightest bubl that why I recommend HID since there are no 55w halogen can be brighter than an HID bulb.
Old Oct 3, 2012 | 08:29 AM
Jackass's Avatar
Don't be one of those idiots blinding oncoming traffic with your improperly setup lights. Do what you can to keep your lights setup correctly to benefit your view of the road without impacting other's view of the road.
Old Oct 3, 2012 | 08:31 AM
TheLowLife's Avatar
^ i found this post funny cause of your username
Old Oct 3, 2012 | 09:58 AM
Redsand353's Avatar
I like turtles
i got some yellow overlays from bluebat and they look very bright and awesome.
if your into the yellow...
Old Oct 3, 2012 | 05:51 PM
Nrp603's Avatar
holy chit those are bright. wanna send me a link? yeah im not sure if im feeling the yellow although those are better for fog lol
Old Oct 3, 2012 | 07:42 PM
aj_06_TL's Avatar
XDM
What bulbs are these?? Nokya?
Old Oct 3, 2012 | 09:11 PM
Redsand353's Avatar
I like turtles
stock bulbs, ordered yellow overlays from bluebatmobile on the forums. From outside the car they look very bright, inside the car its not a huge improvement but surely helps in bad weather
Old Oct 4, 2012 | 12:10 AM
HokAy's Avatar
Me got 3000k from theRetrofitSource - Morimoto 3five
Old Oct 4, 2012 | 07:27 PM
Nrp603's Avatar
yeah i dont wanna buy a whole kit was just looking for plug and play. i cant use LEDS for the fogs right?
Old Oct 4, 2012 | 09:03 PM
splew's Avatar
^This.
The stock fog lights were designed to use halogen bulbs, so that's all you should put in them. Don't put HID bulbs where they don't belong.
Old Oct 4, 2012 | 11:56 PM
Thorin78's Avatar
Previous Owner
Amazon Amazon
I bought these a while back, and they work great for me.
Old Oct 6, 2012 | 01:54 AM
HokAy's Avatar
Did you ever adjust/re-aim the fog lights after they were installed?
Old Oct 6, 2012 | 02:55 AM
You can't adjust the foglights.
Old Oct 6, 2012 | 09:36 PM
Nrp603's Avatar
this is what i have right now...
Amazon Amazon
I like the blue, but they just dont seem that bright like its hard to tell if they are even on without looking at the fog light on indicator.
Old Oct 6, 2012 | 10:01 PM
LockDots's Avatar
Engineer in Training
OP wants brightest.
Here you go pal, made with the power of Thor:
http://www.theretrofitsource.com/pro...ducts_id=12811
Old Oct 6, 2012 | 11:18 PM
AbyssBlue2005's Avatar
I would like to see the front view of the yellow overlays. Been thinking about doing that but i don't know how it would look against my silver/black combo.
Old Oct 6, 2012 | 11:55 PM
nate_0022's Avatar
Land of 10,000 lakes
There is an adjustment screw behind the foglights.
Get your projectors retrofitted and that'll solve your problem.
Old Nov 20, 2012 | 11:07 AM
Blue Batmobile's Avatar
Pics of the overlay !
B@t™
Old Nov 20, 2012 | 02:13 PM
350's Avatar
350
My first ricer
HID's would be brightest, whether you want to run them or not is up to you. I have 4300K HIDs in my stock location, they point very low and do not go above the cutoff on the headlights. I find they blend in well with the headlights and brighten the road better. Never been flashed for them. When people put HIDs in their low beams they're much more annoying as they are aimed higher, and on all the time at night.
Old Nov 20, 2012 | 02:15 PM
350's Avatar
350
My first ricer
Also 3000K does put out more lumens than 4300K+, unless they're cheap wrapped bulbs that reduce the output more. If I had bumper fogs I'd go 3000K but I didn't want them right next to the headlights that yellow so I went with 4300.
Old Nov 20, 2012 | 04:06 PM
paperboy42190's Avatar
yes you can
+1
Old Nov 20, 2012 | 05:18 PM
tehloxely's Avatar
What bulb would you recommend for foglights on a 04 with the fog next to the headlamp?
Old Nov 20, 2012 | 05:26 PM
Turbocoop's Avatar
I've got yellow nokyas in that spot on mine and I love em, a lot of people think they're hids for some reason. Pretty bright too and they help a lot in fog and rain. I'm gonna switch those to 5000k hids when I install the accord fogs, then put yellow overlays on the new fog lights
Old Nov 20, 2012 | 08:01 PM
350's Avatar
350
My first ricer
Just to demonstrate, I don't think HIDs in 04-06 fogs are annoying anyone, normally I'm opposed to them but I had some lying around and tried it, and left it.
Lows and Fogs
Just lows
Obviously it looks a little funny cause my car is pointing up a hill (hate my driveway) but you can see they're not glaring everywhere, just enhancing the lows.
Old Nov 20, 2012 | 11:00 PM
Redsand353's Avatar
I like turtles
B@t™
crappy iphone pic is all i have for now
this picture does a terrible job of capturing how yellow they really are, i actually get compliments on them all the time
Old Nov 21, 2012 | 07:30 PM
UA6's Avatar
UA6
See. Its so easy, even a caveman can do it.
Old Nov 21, 2012 | 11:46 PM
Keep in mind that by going to Nokya's from stock, its a jump from stock bulbs (35watts) to Nokya's (55watts). Makes for a more powerful light spread while also only being $9/bulb. Anyone with Nokya's in their fogs care to compare to those overlays or even 3000k HID's on a 3rd gen?
Old Nov 25, 2012 | 04:48 PM
tehloxely's Avatar
Does going from 35w to 55w change or hurt anything?
Old Nov 25, 2012 | 04:54 PM
The Machine's Avatar
Registered Member
Don't do it! You will melt the housing that the fog light is in. It may take a while to do it, but it will eventually happen. Leave the 35w bulbs in.
Old Nov 25, 2012 | 05:15 PM
tehloxely's Avatar
Good thing I asked! What yellowish bulbs would you recommend for fogs?
Old Nov 25, 2012 | 05:35 PM
Not for 07-08MY... As for the most recent poster's question, Nokya makes a 35watt version but hold that thought if people think a 55watt halogen bulb will melt the housing of our foglights then explain why this has not occured with the folks putting HID's in them?
Old Nov 25, 2012 | 05:36 PM
Registered Member
3k is the color you want to go with if you want the fogs to be yellow. You can always add an overlay if you want to intensify the yellow color. I have morimoto bulbs in my car and love them. Of course they cost a little bit more than eBay bulbs, but you get what you pay for. You can order these bulbs from theretrofitsource.com
And to clarify people putting HID's in their fogs should use 35w. If you want to put a 55w halogen bulb in the fog housing that's fine. Like I said earlier, it may not happen overnight, but by putting a 55w HID bulb in the fogs, it will make the housing miscolored and potentially melt it. Of course I can't find the thread showing a guy that melted his housing. GuitarPlayer16 has posted it in threads numerous times.
Old Nov 25, 2012 | 06:03 PM
Originally Posted by Thorin78
http://www.amazon.com/gp/product/B00...ms_ohs_product
These are the exact ones i was talking about. Could you show us how they look inside and out?
Old Nov 25, 2012 | 06:04 PM
Who said put 55watt HID's in there?
Old Nov 25, 2012 | 06:37 PM
Registered Member
Since tehloxely was asking about putting 55w bulbs in the fogs I thought he meant HID's since this is a thread about the brightest fog lights. Also the majority of the replies in here to the OP's question relate to HID's since they are the brightest lights you can install. Not that tehlowely said anything about HID's I just presumend that's what he was referring to since that is what most of the replies are about in this thread.
Old Nov 25, 2012 | 08:47 PM
Chad05TL's Avatar
nothing like taking advice from a jackass.. But you know, about 1/2 the opinions and comments on this website are from jackasses. At least "jackass" decided to not hide his true nature, unlike everyone else.
Old Nov 26, 2012 | 09:02 AM
tehloxely's Avatar
I'm sorry I didn't specify. So these 55w bulbs are fine?
Amazon Amazon
