Brembo (6-Speed) Caliper Torque Spec
It's in the 3G Garage
D-041: FRONT AND REAR BRAKE PAD INSPECTION AND REPLACEMENT
https://acurazine.com/forums/showthread.php?t=118283
The brembos don't have bolts, they use pins, and you remove them with the "special tool", which is really only a 3.5mm punch.
The DVD-A Script Guy
If so it looks like there are (2) 14x1.5mm bolts that hold the calipers. Page 19-19 shows them. Torque to 170Nm or 125 lbf-ft Man that sounds high considering the rear caliper bracket mounting bolts are only 41 lbf-ft. Sorry, I don't have a scan to post
Thanks, adobeman. That's two pages (A/T and M/T specs) I haven't scanned, but I'll do it later and post it in the brake pad replacement thread already in the 3G Garage.
The scans have been posted in the 3G thread https://acurazine.com/forums/showthread.php?t=118283
Thanks guys. That's the number I needed.
FYI... inside pad had just started to go metal to metal at 48k miles. They are much larger bolts than the standard sliding caliper, thus the mush higher torque spec.
