Brake Suggestions
Brake Suggestions
My OEM brakes are warped and spit out way too much dust, I'm looking for an aftermarket set my budget is $180. This is the set I'm currently looking at but the only thing i don't like about them is that they are drilled, i wish they made a set of these or StopTech that are only slotted with the same ceramic pads but can't find that anywhere. BTW reviews are amazing on these PowerStops plus price is very good which is why they caught my attention.
TLX-S
For your budget, Brakemotive is the way to go, it includes rotors and pads for both front and rear
https://acurazine.com/forums/sponsored-sales-group-buys-10/brakemotive-drilled-slotted-brake-kits-lowest-prices-ever-809114/
I have the set installed on my TL for almost 2 years now with no issues
uhhh dude, powerslot slotted rotors is a sister company to stoptech and has slotted rotors...
check out XLR8:
http://store.excelerateperformance.com/
he has lots of different kind of rotors and pads to choose from.
read the description and decide if its for you
also, like the poster above me stated; you cant go wrong with brakemotive. for $250 for all 4 corners is a steal!
however; I personally dont like drilled rotors as over time, they will crack due to the close proximity of the holes.
P.S. Gils, you've been a member here for a while and should know that there are several threads on the same subject...matter of fact there are like 3 or 4 "brake rotor" threads below yours.
check out XLR8:
"Power stop" not "Power slot"...
IMO, budget more for something so important and get something known to be good.
Austin's about to come in here and tell you to stay far far away from Brake Motive. And I have to say, from my time here, I'd probably agree.
check out XLR8:
check out XLR8:
what we're both missing is what warrants the $100 difference from whats essentially the same product or very similar from my understanding.
Right...... well "clearing things up" isn't exactly going to knock down those extra $100 so i'll pass on the stop tech. I noticed that for the price of the PowerStops i can get both front and rear pads and rotors from Brakemotive, i have no problem paying the extra money for the PowerStop set but i'll search how good of a product the Brakemotive's are since their price makes them a little suspect.
You're not understanding justn, we've already cleared up the fact that raising my budget won't necessarily get me a better product just a better name. Isn't that what you explained as "marketing"? So I'm just trying to see if the more expensive set is actually worth it thats all.
Amazon.com: Power Stop K2292 Front Ceramic Brake Pad and Cross Drilled/Slotted Combo Rotor One-Click Brake Kit: Automotive
Front: $31.75
Rear: $28.45
Front: $108.50
Rear: $75.04
$243 total from a quality brand.
I've had my car for 10 years and my last brake job was the first one I didn't go all out and get $100 brakes and drilled and slotted rotors that don't last. Came to this conclusion after scouring many forums for the best brakes and rotors and they all said the same thing. Unless you're going to the track and have the money to keep replacing get Centric rotors and Centric ceramic pads. This isn't cheap stuff it's just Centric makes for everyone so the economies of scale brings the pricing down. Hell Brembo, EBC, and DBA are all made in China except for their highest end stuff and all of the low end stuff looks exactly the same when held side by side. Just my $.02. Honestly, I can't even really tell the difference and breaks and rotors have worn much longer. Centric rotors also have a black coating on the center ring of the rotors to prevent rust. And Brakemotive and all those ebay companies stay away. Sourced from China with no quality control that a massive company lilke Brembo or Centric can command. I'm sure some guys have gotten good sets but there are a greater many that didn't. Look outside of Acurazine and you'll find out.
justnspace (11-09-2013)
P.S.: You can also go to Advance Auto's website and get a full set of Wearever Gold Ceramic pads and rotors for just under $180 with some coupon work and you can get Platinums for around $190, shipped to your home or pick up in store. Let me know if you want help with that.
I agree that Brembos are heavily overpriced for what you get. My one and current experience with Centric/Stoptech is warped rotors and pads that don't want to release as you let up on the pedal until you let off way more than to have to. I got them cut to buy me time until I figure out what pad and rotor combo to go with. Since they've been cut performance is noticeably better and the pads don't grab so bad. And no, it was not pad deposits, they were out of round.
Gil'sUA5 (11-09-2013)
Centrics, a quality brand the makes for many many companies.
Front: Amazon.com: Centric 105.0787 Posi-Quiet Ceramic Brake Pad with Shims: Automotive $31.75
Rear: Amazon.com: Centric 105.0536 Posi-Quiet Ceramic Brake Pad with Shims: Automotive $28.45
Front: Centric Parts 120.40046 Premium Brake Rotor with E-Coating : Amazon.com : Automotive $108.50
Rear: Amazon.com: Centric Parts 120.40061 Premium Brake Rotor with E-Coating: Automotive $75.04
As for the pads, I'm going a new route for me and trying sintered pads. I don't know what make yet, it would be nice if Stoptech made some. They have some unique properties. Great cold bite while working to 1,800F. Less judder and usually less noise. Part of the reason is they don't need much of a transfer layer on the rotors to work well which also means very little break-in. They can be quiet or they can be noisy and they can have good pad and rotor life or bad depending on the specific compound. They're typically more expensive than ceramic but my car gets driven under 6k a year so they will last me many years.
I'm over the ceramic pads. They just don't offer really good performance for heavy duty use. They're good for low noise and low dust and good rotor life but in my opinion they're too much of a compromise for me under track conditions. I've run ceramic pads that will survive 1,600F and they have terrible street manners, a screech that would scare cars next to me at 70mph on the freeway. Sintered will give great track performance with great cold bite and if you pick the right ones only the only real downside is the cost. I've used these on my mountain bike with great success even with glowing rotors from a terrifying high speed night time downhill run. The thing to remember is just like ceramic, sintered can cover a wide range of compositions.
I don't like 2pc rotors on the street but if my current ones warp again I'll probably go 2pc just to eliminate that problem. I almost forgot, the next new thing I want to try is a titanium backing plate between the pistons and the pads to reduce transfer of heat from the pads to the pistons and eventually to the fluid. The nearly pure metal sintered pads can transfer heat a little quicker to the pistons/calipers. I e also got Motul RBF 600 which I believe to be the absolute best brake fluid out there due to an extremely high wet boiling point which is representative of real world conditions.
I'm in no way saying ceramics aren't great because brake pad composition is all about compromises but I think sintered pads fit my set of compromises better.
I think there's only one single sintered streetable pad for the D608 pad shape for my ST-41 calipers. http://store.zeckhausen.com/catalog/...ducts_id=10652
This one is going hurt at $388 especially since I have no other reviews to go off of and I doubt anyone has ever used these on the street. I don't mind $100 pads not working but if these don't work I'm out $400 when all is said and done.
so i went about $100 higher on my budget and ended up getting the powestop set for the front and rear, i think i'll be ok with these... hopefully.
justnspace (11-11-2013)
Former Sponsor
Correct. Powerslot is the sister company of STOPTECH, Powerstop is not.
Amazon.com: Power Stop K2298 Front/Rear Ceramic Brake Pad and Cross Drilled/Slotted Combo Rotor One-Click Brake Kit: Automotive
the one thing that concerns me is that the rotors are made in china!
coupled with the fact that they are drilled, I wouldnt be surprised if they crack over time.
The one thing people need to realize is ALL drilled rotors will crack given enough time, even the best. If you think you can outrun the clock, go for it but you're getting almost no performance increase in the dry since we don't have much airflow over the rotors and a little performance in the wet but nothing a good set of pads won't match. I thought I would wear my old Rotora drilled 13" rotors out before they cracked, especially since I was on a full race pad but they cracked all the way though in several spots so bad that the car had a shudder.
http://www.ebay.com/itm/FRONT-REAR-KIT-BLACK-CHROME-Slotted-Drilled-Brake-Rotors-AND-Max-Brake-Pads-/231002067025?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2004%7CModel%3ATL&hash=item35c8cbd051&vxp=mtrhttp://www.ebay.com/itm/FRONT-REAR-KIT-4-PERFORMANCE-DRILLED-SLOTTED-BRAKE-ROTORS-AND-8-CERAMIC-PADS-/390411249100?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2004%7CModel%3ATL&hash=item5ae652e5cc&vxp=mtrhttp://www.ebay.com/itm/Front-Rear-Kit-POWERSPORT-DRILLED-SLOTTED-Brake-Rotors-CERAMIC-Pads-/271039208659?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2004%7CModel%3ATL&hash=item3f1b321cd3&vxp=mtr
They're all sourced from the same place. You just paid a different company with a different mark up of $100 more. For that kind've money you could've gone to Advance auto parts and gotten DBA, DiscBrakeAustralia, rotors for the front, Wagners for the rear, and Akebono pads all around.
To be honest with every product there is a consumer that has had an issue with it, as you can see IHC has had issues with the stop tech. For any product you'll see great reviews and bad ones, i haven't HEARD OF one person have these crack on them (not saying its not possible). Drilled has its ups and downs, a drilled + slotted rotor SHOULD last longer without warping because it does a better job at dissipating the heat than just a slotted rotor.
I hate cars (11-11-2013)
Lmao wait so slotted/drilled makes no difference at all? Why do you have slotted rotors and not traditional?
for the looks breaux!!!
I personally cant tell the difference between different set of brake pads...carbon vs ceramic, all I know is that I hated the dusting.
so, i opted for ceramic pads and it felt the same.
same thing with the slotted rotors vs blanks.
the best upgrade for stopping power that I did was change out the all seasons and put on a dedicated summer tire.
the difference in tire made stopping un-real!
Last edited by justnspace; 11-11-2013 at 07:40 PM. Reason: expounded on reasoning.
Drilled offers practically nothing on the street. The only time you'll see a difference in cooling is high speed/high airflow conditions which the TL will never encounter unless you run cooling ducts and regularly drive over 100mph. I've purchased white papers on the subject and I have tons of data showing my 13" slotted Stoptechs run considerably cooler than my 13" drilled and slotted Rotoras. I even ran one rotor on each side while I was swapping them out and I would have to look it up but I believe the slotted only rotors were close to 100F cooler.
Slots are there to prevent pad glazing which also keeps a nice surface on the pad. They will not help or hurt warping or cooling.
Preach on Justin. I started that last post before 5pm and just sent it without seeing the other comments on slotted vs drilled vs blanks.
There were too many theories and opinions but very, very few facts on the internet and while I was doing my own research I couldn't wait the year or more to reach a conclusion. If anyone is interested, you can buy some great SAE white papers that are done by engineers and unbiased if you want to cut through the internet myths. One in particular by GM showed the effects of drilling on cooling, rotor longevity, pad longevity, wet vs dry performance, friction characteristics in different conditions, etc. the one thing that was true in the papers and from my own tests is drilled do not run cooler in normal stop and go traffic.
I notice most peoples brakes now. Especially my co-worker and petroleum engineers G37 that has larger factory brakes than I have aftermarket. He has nice brakes, a nice car, a young engineer for a great company and he told me his G37 came stock with a 5.7l V8 and had no idea he had gotten the car with the optional larger brakes and no idea what diameter they are lol.
When I had the 13" Rotoras people noticed them. With the same size Stoptech no one notices but that was the idea with the black calipers and no holes.
