Blinker works but not running light
Old 06-05-2019, 08:59 AM
kisersose21's Avatar
Running light on passenger side doesn’t work but the blinker does. Is it a two way bulb?
Old 06-05-2019, 01:00 PM
GhostTL09's Avatar
You need Blinker Fluid......
Then you need to replace it with bulb #7443 I believe is the type number. I bought a double pack for $4 at WalMart
The blinker function will work but it will not burn constant
Old 06-05-2019, 01:01 PM
Received 8,709 Likes on 6,716 Posts
yes dual filament
blinker fluid not necessary because blinker works. If blinker didn't work, then fluid would be the proper fix.
Acura TL Builder (06-05-2019)
Old 06-05-2019, 01:06 PM
Received 16,265 Likes on 11,974 Posts
fill it with 710 fluid
Old 06-05-2019, 01:21 PM
BreezyTL's Avatar
Received 1,020 Likes on 761 Posts
Single filament, but to activate the flasher there is an extra gigawatt applied to it. Since your running light doesn't work, change out the flux capacitor. Report back if this solves your problem so others can follow your steps!
Old 06-05-2019, 01:26 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,652 Likes on 1,117 Posts
You IDIOTS! You all are idiots! The obvious answer is the weld the rear differential together.
The following 2 users liked this post by gatrhumpy:
Acura TL Builder (06-05-2019), Superunknown (06-06-2019)
Old 06-06-2019, 01:29 AM
Registered but harmless
Will Y.'s Avatar
Received 1,107 Likes on 765 Posts
07txtltype-s
11-13-2016 01:51 PM
Powashiftin
01-17-2015 05:47 PM
e5c4p3artist
09-01-2011 10:09 PM
PTN
01-04-2005 03:09 PM
Quick Reply: Blinker works but not running light
