Best Battery to buy?
Sounds like a newb question, but I wanted to get some input on buying a new battery
Nothing wrong with my current battery... but i want to get something better, because of all the horror stories of OEM batteries.
I am running a 900.1 Amp with 1 12" 1500W Sub.. nothing to wild
What do you guys think? Kinda hoping to get input from people who have the battery they recommend... Braille? Optima (red) ?
tehLEGOman
Received 1,983 Likes
What do you guys think? Kinda hoping to get input from people who have the battery they recommend... Braille? Optimata (red) ?
tehLEGOman
MODEL NUMBER: Braille SKU #B3121C
Model Name: 21lb Carbon Extreme Use Battery
PERFORMANCE
Voltage: 12 volts
Full Charge Voltage: 13.8 volts
Short Circuit Current (Max Cranking Amps): 3000
Pulse Cranking Amps (PCA) 5 sec @ 80F: 1380
Pulse Cranking Amps (PCA) 10 sec @ 80F: 1207
Pulse Cranking Amps (PCA) 20 sec @ 80F: 1066
Cranking Amps 30 sec @ 80F: 892
Cranking Amps 30 sec @ 32F: 742
Cold Cranking Amps 30 sec @ 0F: 550
Reserve Capacity: 1hr &15minutes
Capacity (C/20 rate): 31 amp hr
Internal Resistance (ohms): 4 milliohms (.004ohms)
Life Cycle @ 10% DOD: Up to 3500 cycles
PERFORMANCE
Voltage: 12 volts
Nah, no capacitor.. my system isnt much... my lights dont even dim when i hit it... it does make some serious sound, but thats because i used the proper specs on the box and ran it bridged @ 1 OHM stable
honestly, I am having ZERO issues with my battery... but i know what a piece of junk this battery is...
the specs on that braille look nice..550CCA @ 0F... pretty impressive.. i think the OEM batter is like 600CCA at ambient temps (80F)
94 DC4 RS LSV/Turbo
I got my braille 21lbs @ jegs.com
Also thru in half a case of royal purple and the 6" j hooks
Ended up paying like $250 total on the order![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
Shippingwas like $9
Ps. The 21lbs is what nascar uses
Shippingwas like $9
JDM Addict
PERFORMANCE
Voltage: 12 volts
PERFORMANCE
Voltage: 12 volts
This is the battery I am running.
My personal opinion is that it is the best on the market.
And it just so happens to be the best looking too.
![](http://i133.photobucket.com/albums/q73/mitchmonster/acura/batterytop.jpg)
![](http://i133.photobucket.com/albums/q73/mitchmonster/acura/batteryotherside.jpg)
94 DC4 RS LSV/Turbo
Well the cf is just for looks so I'd say get a plain one and spray it wdp rofl, I've been meaning to spray mine but eh you know its one of them mods
Ps. Everyone says braille batteries are rebadged deka batteries (braille has a longer warranty tho)
Bone stock tl-s
allon the braille battery has really good amp ratings. if your system isn't that crazy it should perform nicely. cant beat the power to weight ratio. optimas weigh a ton. i still cant believe i had two in my other ride. my shit was heavy. when i redo my system im gonna skip the cap and run another braille in the trunk for my amps.
and looks so cool![Too Cool](https://acurazine.com/forums/images/smilies/toocool.gif)
![](http://i134.photobucket.com/albums/q81/jptl04/cf6.jpg)
here's my set-up
and looks so cool
here's my set-up
Man of God.....
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
OK, but can the Braille 21 really give much cranking time? When its COLD REALLY COLD?
Like here in Minnesota say its -30F
and your car has been outside in that cold wind until your Mobile 1 is like a slurpie.![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
First try for fire= no go
, 2nd same
, 3rd is it the little batt. that could or couldn't this is what I need! If you crank it like you life depended on it!! I thought it only came with SIZE. More plates and asid... Anyone out there have this kind of knowledge?
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
http://www.odysseyfactory.com/
Used it on my motorcycle when I had one. They make batteries for cars as well. Whenever I went to a bike meet I always saw the older bikes had acid damage. Since there batteries are dry and sealed it was attractive. It has good cold cranking capability as well.
Oderint dum metuant.
Make Nice, Not Rice
jptl04... very nice setup! Do you have a link to the place you bought it at?
Also what's the major differences in Braille 21lb battery vs OEM, besides the weight ratio. (I'm a newb at batteries)
I'm having issues with my power. Sometimes my left switchback won't signal yellow, it's just white. Sometimes my rear view camera won't work when I put it into reverse. Sometimes my Navigation will work, but when I click "Audio" it doesn't go anywhere. I'm pretty sure this is a power issue, because after I drive or idle the car long enough, the problems go away.
94 DC4 RS LSV/Turbo
jegs.com has the best shipped price, if you can get a local shop to aquire one you will save on shipping, on average expect to pay no less than $180 for the braille 21 pounder
Bone stock tl-s
in comparison to the stock it has 550 cca to the stocks 425-450 cca.
braille=21lbs stock=39lbs 18lbs difference
Make Nice, Not Rice
can someone answer my questions please and thanks!
"Also what's the major differences in Braille 21lb battery vs OEM, besides the weight ratio? (I'm a newb at batteries)"
From www.brailleauto.com (click here)
Why Braille Batteries?
- Save Fuel :
Lighter Weight = Higher fuel economy
- Better Acceleration:
Lighter Weight = Faster Acceleration
- Shorter Braking Distance:
Lighter Weight = Shorter Braking Distance
- Longer Battery Life:
Up to a 6 yr life = Lower Maintenance Costs
- No Leak Design:
Non spilling =No Acid on clothing, No Rust
- More Power:
More Power = Starts in the Cold
- Enivronmentally Green Friendly:
Smarter Manufacturing = Cleaner Environment.
Braille Batteries employ recycled materials and are the highest post-consumer recycle rating of any battery! It increases manufacturing costs, but reduces waste in the environment.
- Made in the USA!
Designed, Manufactured with Quality & Assurance
- Free Replacement Warranty
The best warranty in the industry for racing products.
Man of God.....
New shoes on my
Greddy radiator breather tank.
https://acurazine.com/forums/showthr...4693&highlight=
EDIT: NM, I'm wrong..I have no idea! I thought you meant just north of the battery
