Battery weirdness
Battery weirdness
I have a battery (ever start Maxx) that is one year old based on the sticker that says "Manuf. Aug 09" A week ago I vacuumed the car using the lighter socket then let the car set for 5 days becuase I drove my other car. Today I tried to start it and it wouldn't start. The road side guy checked the battery and said it was half charged. Did my vacuum and letting the car set in 90 degree weather sap the energy from my car.
Heheh, my car did the same thing a couple weeks ago.
Used the lighter socket to pump up the tires, then the next hour (not days) when I tried to start it the car, it just wouldn't.
Jumped the battery and the car's all good again.
I gotta get me a non-OEM battery...
Does your car still start?
TL=True Love
im in the military and I just came back from a 6 month deployment and I come home to drive my TL but the engine wouldnt start so I had to up start it and it took MULTIPLE tries b4 it was up and running. i guess next time i should disconnect the battery for long periods of non-usage. and it was an OEM battery.
hey guys it's very bad to drain your battery low. I think if it gets below 8.5v or so it starts to crystalize and you can't recharge it or it's life is significantly shortened. I would either do what motorcycle guys do, put a trickle charger on it or disconnect the negative if over a week.
My car all of a sudden felt slow to crank for a few days. I pulled out the "Duralast Gold" and it was from 7/07. I replaced it and it cranks with no problem. I just did not want any problems that is why I replaced it.
I lost my battery last week. I let the car sit for 2 months while I was in China this winter and when I got back it wasn't completely dead, but much like the Dread Pirate Roberts, it was mostly dead. Jumped it and I was good to go. But a hard Arizona summer took it's toll and finally killed it. Went to Costco the next day and got me an Interstate. Here's the part I don't get. I had the car completely disconnected for 24 hours before putting the new battery in and I didn't lose any of my radio presets, my HFL data, or my seat memory settings. Is this data stored in some kind of non-volatile RAM or something? The car did tell me to run it outstide while it found the satellite data for the GPS.
you are lucky to get 3-4 years from a battery now-
look how hot and enclosed the whole area is = plus no way to top off the battery fluid like the days of old
acura had a run of weak batts that only lasted a year or 2,,good thing for warranty but you still got stuck with an acura battery replacement
battery maintainers are great, can be found as low as 19!! for the major brand name Battery Tender
There are small solar panels you can place in the window and plug into lighter to keep the battery charged too
they are getting pretty cheap- you see a lot of boats and rv's with them now
Its normal for a battery to discharge when sitting, add the use of power for alarm on lights, memory setting power etc etc .. a milliamp here and there add up
Leave the car for a month and you better take the battery out of the car and put on the battery tender
Using the vac and not driving the car for an hour was the downfall of that project,
you took all the juice out and didnt replace it- what were you thinking?!
The battery is a storage box of electricity- the alternator replaces what has been drawn from the box for use
It doesnt magically get full again!
Note: if you usually drive 10 miles or less on a trip, once a month take the car on a 45-60 minute freeway cruise- that fully charges the battery,,and dries out the oil and exhaust moisture (hidden in them)
the alternator is fighting to refill batt after start, you turn headlights on, run cabin fan and stereo,,all are drawing more power from the battery
it almost replaces the power used to start the car and operate it without extra loads of all the items --and you arrive at work
Keep doing that and it never runs at full capacity or correct voltage for the car
and doesnt charge to actual max anymore
note for all long term stored cars- when you get back FLUSH the brake fluid- its gathered moisture just sitting there,,good idea to change oil and filter too
wiki hygroscopic for details
seafoam or stabil in the gas tank before leaving will help fuel from gumming up and varnish forming in the system
MetalGearTypeS
08-29-2016 08:28 PM
kb1rl
09-30-2015 10:17 AM
