Battery (again) - parasitic drain......
My 1 month old TL (vin 38k) experienced the dead battery situation this week Acura replaced Delco unit with an Acura part number (a substantial looking 60 month item). Original battery dropped to 4.7 v overnight [without the security system on] as if it had a dead short (e.g. if something like a power seat motor were stuck in the on position). However with the new battery I'm seeing an overnight loss of about .1 v - does anyone have any insight into what the parasitic losses on a modern vehicle should average? With only a 65 amp/hour battery - and assuming we need about 1/2 capacity to start - anything over about 50 ma and these cars are not likely to crank after a few weeks at the airport.
CEO, Team Anthracite
Originally Posted by bluenose
Acura issued a TSB No. 021004 this past February regarding dead batteries. Might be worth your while to follow up on this with your dealer.
My car cranks quite oddly - sometimes it starts right up after the first crank, sometimes it has to go for about 3 seconds, and sometimes it doesn't start at all and I have to re-crank the car.
..thanks for the info - I'll try to acquire and post TSB
(note to smiranda69: when you check battery be careful when removing cover - the left side tab is easy to break, Just lift assembly straight upwards)
Team Anthracite Member
I wish you would have told that to whoever jumped my car before I picked it up - cover was broken (tab).
Moderator Alumnus
I think bluenose is talking about this over NHTSA TSB database. I'm not sure if this is the official Acura dealership TSB though.
Make : ACURA Model : TL Year : 2004
Service Bulletin Num : 021004 Date of Bulletin: FEB 10, 2004
NHTSA Item Number: 10006747
Component: ELECTRICAL SYSTEM:BATTERY
Summary:
BATTERY FAILURE. REQUEST FOR VISIT. *TT
MetalGearTypeS
08-29-2016 08:28 PM
