av6 transmission swap on 2005 acura tl
i found 2007 honda accord non hybrid going check it saturday and doing the swap. my transmission on my acura is out/on its way out it drives for like 6-10 min or less stops and just revs when it hitting gas. i have to cut the car off wait 1-2 min crank up and it値l drive again eventually it値l do the same thing again and i値l have to repeat the same thing
Null and proud of it
Yeah. The Hybrid is probably completely different. There's probably not even a place to mount a starter since it has none.
99.9% of 7.5G Accords are gas Accords. Stick to them.
Best of luck!
Welcome to the forums.
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions forum to the model specific forum.
