Anyone make a Hepa or charcoal cabin filter?
I've been looking for preferably an activated carbon and Hepa filter. So far only found a carbon filter for up to an 04 TL which I ordered and didn't come close to fitting. After an hour of seaching I don't think one exists for the 06 TL. Next stop is Home Depot. I think I'm going to cut down one of their home hepa filters for use in the TL.
The Bosch brand cabin filters have a micro treatment- or you can add a small piece of home depot furnace filter to the unit
it's me, Alan Rickman.
It wouldn't make sense for Acura to change the air filter size mid-production.. I know people on here have them I just can't remember who makes it..
Edit: Check here:
https://acurazine.com/forums/showthr...ighlight=cabin
Edit: Check here:
Thanks. I ordered one for an 04 TL and got two small filters like the 2nd gen used. No way to fit them both and I had already destroyed the stock filter. Had to chop them up to make them fit. It looks like the store sent me the wrong filters now.
WDP Director of R & D
The bosch filter has the wrong listing for anything newer than a 2003/2G TL. It is however the only filter they have for the 3GTL with charcoal - IE they don't make the correct one.....
Originally Posted by THTL
I though Rockauto.com have one with charcoal. I think the model number are ATP HA5 or somethig like that.
For some reason you will find that a lot of times the parts catalogs at NAPA, carquest ect. have the 2g going through MY 04'. I got an oil filter and both places had the 03 filter the same as the 04' which we all know is not the case. I told them to look up an 05' and it was the correct one. Go figure. Maybe use 05' as your MY if you have an 04'. I too wish they made a charcoal fiter, it would help reduce some of the odors and crap form outside. My A4 had a charcoal filter and it worked really well.
Eric
Eric
Eric
Eric
Which one did you get that is wrong. I need to get one too.
The wrong Bosch filter is acually working great but it bothers me knowing there's a filter cut into 5 pieces and siliconed together. There is a big difference when I drive by a dairy on the way to work everyday. The smell is still there but not nearly as bad.
Forget HEPA filter for the cabin unless you plan to change them weekly as the filter would need to be alot bigger to last and here is why;
From Wikipedia:
A HEPA (IPA: [ˈhɛpə]) filter is a type of air filter. "HEPA" is an acronym for "high efficiency particulate air filter" (as defined by the United States Department of Energy).[1] The DOE version of the acronym is actually incorrect. The original derivation of HEPA represented "High Efficiency Particulate Arresting" filter. The term "Particulate Air" conveys no meaning.[2]
This type of air filter can remove at least 99.97% of airborne particles 0.3 micrometres (µm) in diameter. Particles of this size are the most difficult to filter and thus the most penetrating particle size (MPPS). Particles that are larger or smaller are filtered with even higher efficiency.
That is 0.0000003 meter (One meter is approx 39 5/8 inches)
From Wikipedia:
Make MyTL Great Again
The Bosch Filter is wrong. I emailed Bosch and the company I bought it from about it like a year ago. Nice to know they haven't fixed their shit.
ATP HA5 is the way to go if you want charcoal. I just installed my 2nd one yesterday.
And yes, www.rockauto.com is where I got the ATP.
rockyboy
01-25-2016 06:00 PM
