Anyone change 6MT transmission fluid (MTF)?
I have a 2000 Odyssey an waited until 30,000 miles to change the ATF per the manual. I was very disappointed to see a lot of metal chips in the fluid and on the magnetic plug.
Also found out you only can drain 3 of 6 qts with each change. Would need to change 3 times to get 87.5% new fluid.
Anyway, I had wished I had done it much sooner. I am approaching 4000 miles and was considering changing the MTF with the oil change.
Just wondering if anyone had done this themselves and could relate their findings.
Thanks in advance.
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
I do my own work.
it probably depends a lot on how you drive........I would check it out at 10 or 15k, 5k is not very long on tranny fluid.....but then again, it wouldn't hurt to see
Shift_faster
Originally Posted by deandorsey
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
Mike Bertram
09-10-2015 09:27 AM
