Anyone with '04-'06's getting high-beamed?
I was just wondering if any other owners of 04-06's with the integrated fogs get high-beamed by other drivers coming towards you at night? This is while driving with your low-beams and fogs on.
It seems to happen to me almost every night!
It's pretty annoying to me, and I usually just pull the dick maneuver and click my high-beams on for a second to show them that they're not on.
Yeah, I've had it happen (same problem with my '91 Integra back in the day). I usually just give them a brief flash of my ACTUAL high beams and that pretty much ends the issue.
BTW, I only use my fogs when the weather dictates (rain, occasional fog, etc.); which, in Phoenix, is about one Thursday every leap year.
My DRL (Canadian tl) turn off when I turn on my low beams
Just for sanity's sake...
Park 25 feet from your garage door and see if both lights are aimed properly. If not, when you pop the hood you'll see 2 holes in the plastics that leads you to the headlight height adjustment. A phillips screwdriver to adjust and you're done...will take you less than 5 minutes and may stop the high beaming (also...can't help that it DOES look like your highbeams are on...although if it wasn't glaring into people's eyes then they wouldn't be flashing you back). Also...my oem fogs don't shine any higher than the low beam cutoff.
Good luck!
Good luck!
Mike420TL (06-15-2011)
I'm Craig
Yep, happens with me sometimes. My headlights are aimed properly. I felt like a jackass once because a car was coming at me and I could have SWORN their brights were on, so I gave them a quick flash. They flashed back and their brights in fact weren't on- as the car got closer, I saw that it was another 3G TL.
Could be your excuse
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
yep, happens with me sometimes. My headlights are aimed properly. I felt like a jackass once because a car was coming at me and i could have sworn their brights were on, so i gave them a quick flash. They flashed back and their brights in fact weren't on- as the car got closer, i saw that it was another 3g tl.
06 Anthracite TL
i had this problem...in the past. AckTL05 installed the Accord fog lights in the lower grilles on my car, and wired the factory fogs to be my switched DRL's. I like this setup much better, and I now have the DRL's I wanted. To me, having the factory fog lights next to the low beams is a bad design, probably the only bad design item in the TL.
I'd suggest you check the aim of the headlights and make sure that they are proper, esp if you keep a whole bunch of stuff in the trunk all the time.
Registered Member
the stock HID headlights are VERY bright and acura changed the design with the 2006 model for the projector to help cut down on the glare a little bit more. People constantly make that mistake with the TL thinking the high-beams are on when they really aren't.
ReDevil
06 Anthracite TL
There was previously a module to make the fog lights DRL's, but it's no longer available.
Good luck!
Good luck!
Enthusiast
HA! If someone flashes me, I let it slide usually.. But if they decide to flash me AGAIN, They get to see my brights until they pass ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
I'm the bright police, not you!
as far as doin the accord fogs, I'd love to but I'd rather pay someone to come help me with it. not to good with electrical things.
(hint hint for those a-ziner's that live in western pa or within a few hrs drive)
US Navy Seabees
I dunno, but if I had an 04-06 I would even use the "fog" lights. Barely use them on mine, pointless feature if you ask me...
Keep Right Except to Pass
I only use the fog lights when weather dictates (either fog or very heavy rain that makes it hard to see the pavement markings).
I haven't had someone flash their high-beams at me in ages except to warn of a speedtrap. Back when I first got the TL I occasionally experienced people high-beaming me when I was out in more rural areas. It's never happened to me in the DC area, so I suspect it was a case of the rednecks either not being familiar with HID lights or with them just being morons. Hasn't happened in at least five years, though.
if you don't use them, and think they're pointless, then that's fine by me. your life, not mine.
my fogs are yellow ( hid ) and have an aim a bit more outward than the OE installed set up.
Occasionally I get flashed but I dont care.
I only use them in the rain and dark mountain roads when going upstate.
'06 WDP TL 6MT
I had the same issue until i adjusted the beams down a little.
My lights were high enough that on a flat road if i switched between low and high beam i couldn't tell the difference. After adjusting them there is a difference and people stopped flashing their high beams.
This can happen when on the highway rounding a right hand sweeping turn. The cuttoff line for the headlights makes a slight bump upwards on the right half of either headlight. This is to help illuminate road signs and pedestrian traffic at night. Only problem is that when making right handed sweeps, the oncoming traffic is directly in the path of your higher cutoff area. Until they cross past the nose of your car, the oncoming traffic may think you have your high beams on.
You may also notice that oncoming traffics headlights seem extremely bright when following left handed sweeping turns. This is because your now in the path of those cars raised cutoff extensions.
It really shouldn't have anything to do with your fog lights.
The following 2 users liked this post by ttribe:
GoldenShoes (06-14-2011),
jhumbo (06-16-2011)
