any tips for putting on Aspec front lip ?
I have a front lip with not brackets or anything. I will use double sided tape and was wondering if anyone has any tips for me like do i put it on first then stuff tape in or put tape on the bumper first then put the lip on??
any information will help.
thanks
thanks
well the best tips i can give you are very simple 1. BE PATIENT!!! (no use in rushing and making it look like shit) 2. Make sure you have all the correct tools you need for the job ( once you get started, you want to finish and not be interupted by not having the right tool for the job 3. Having a friend help is a awesome plus 4. good luck and post those pics up asap!!!!
Check the installation links in the 3G garage if you don't have the instructions (year specific) - https://acurazine.com/forums/showthread.php?t=553557
To be clear, are you saying you are going to mount the lip using ONLY tape? Why don't you have the brackets?
so far i only plan to use tape since i got this lip from a friend that didnt have the brackets. ill prob try making something. ill try to post pic when im done. thansk everyone.
Pegon95
08-31-2015 02:18 PM
