any member here that bought a used TL...
Old 10-29-2009 | 07:13 PM
  #41
wonton's Avatar
Originally Posted by Babnik
Check out this deal, probably the best deal I've seen in Canada, 06 6MT navi for $19,900, and it's even from an acura dealership not a private sale: http://www.waterlooautomall.com/acur...hicle?id=4523p
Well this is not in canada but probably a better deal.
http://www.cars.com/go/search/detail...5&aff=national
Old 10-29-2009 | 07:17 PM
  #42
d-townhakuzo's Avatar
I got mine 2 months ago, at 79,000 and have approximately 82,000 on it now. I had the brake light sensor replaced, the bluetooth module freeze, had to get my rack and pinion replaced, and there was an oil leak, but that is about it.
Old 10-29-2009 | 10:52 PM
  #43
AcCURA aTeLy's Avatar
5th Gear
haha, have only had my current TL for three weeks! 04 with 70k, $14,500... previously had a pre-owned 03 which gave me absolutely no problems, bought it a little newer, about 35k in 2005. had my mechanic check this one out and clean carfax. just do some homework, find a clean car, take care of it, and your TL will run a long long time... currently no problems, but, as i said, it's only been three weeks!
Old 10-31-2009 | 08:22 AM
  #44
dmac65's Avatar
4th Gear
Bought mine about 2 months ago. 2005 auto with navi with 99000 miles on it for 13,500. I replaced the timing belt and tensioner along with the water pump as maintenance. Long story short I made a mistake and bent 2 valves so I ended up rebuilding the heads with new valves and seals. Car runs beautiful now. Also needed to change o2 sensor. Luckily I was able to do the work myself. I ended up putting a grand into it but It's a really clean car and now most of the engine is new. Also changed the tranny fluid 3 times to really clean it out. I would suggest any new owner to definately change tranny fluid.
Old 10-31-2009 | 11:58 AM
  #45
yiujai86's Avatar
Bought mine 6 months ago with 67k miles on it for 14k usd. Now it has 86k miles on it and the only problem i've had is the lights for the volume/cruise control go out and the interior rear view mirror liquid leaking problem. Other than that, everything under the hood is great and thats what counts.
obert
12-14-2015 11:36 PM
ryanfett
10-29-2015 06:01 AM
govtcheez
10-01-2015 12:21 AM
Trplezero
09-03-2015 10:25 PM
Quick Reply: any member here that bought a used TL...
