Another B1 Maintenance Thread (price check)
FTW
I got a quote from the dealer say it would be 194.00 After taxes
Sounds rediculous.
So from memory I recall Tire rotation / oil change / oil filter change & visual inspection. What does the B1 include?
Does this seem high? Recommend me a place in MN if you are from MN.
Sounds rediculous.
Turd Polisher
Sorry to thread jack but, how much does it cost for a B2? I'm having my car serviced as soon as it gets back from the autobody shop :\.
FTW
make your own thread.
and... it's easier to just "call" the dealer, ask them "i got a MID B2 Service notice, what does it entail and how much does it cost?"
Kaa - Ching !!!
Location: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
Originally Posted by lusid
hell... 92.00 seems affordable.
Thanks for the reply steve, recall what you had done?
The balance was $47.50 of the $92.00..........
Turd Polisher
holy cow people. its an oil change paying more than 40 bucks is alot to. what does that entail? what do they really do to visual inspect your car? i have no problem with paying for the work that was done not work they were thinking about doing. and besides a relatively new car will not need alot of work period. so its a rip to pay 90+ for b1 service.
Kaa - Ching !!!
The majority of dealers are on the up & up.......
Maintenance Minder B Scheduled Maintenance
Recommended service for your 2006 Acura TL:
Replace engine oil and oil filter
Rotate tires
Inspect front and rear brakes
Check parking brake adjustment
Visually inspect tie rod ends, steering gear box, and boots
Visually inspect suspension components
Visually inspect driveshaft boots
Visually inspect brake hoses and line (including ABS)
Visually inspect all fluid levels and condition of fluids
Visually inspect exhaust system
Visually inspect fuel lines and connections
Maintenance Minder 1 Scheduled Maintenance
Rotate tires
If anything should go wrong with the above I have a service receipt saying it was inspected..........
Rotate tires
Rotate tires
FTW
Originally Posted by TylerT
Calm down turbo. I don't believe the dealers are open at 7:30am.... it would be much easier getting an easy and FAST response here.
yep, i'm having a similar discussion in my thread...
Acura Santa Monica wants $169.95 for B1 service.
two independent shops here in LA:
Santa Monica Independent Acura wants $125.
S&S wants $70.
btw, where can we get a print-out of what comes with each service (i can see here what comes with B1, but what about everything else)?
S&S wants $70.
FTW
Nice link ^
So instead of doing a B1, could I just ask for a oil change / tire rotation? All the other things seem like spot checks which I could do.
Turd Polisher
That is a bit ridiculous. The B2 service for me is going to cost $280 :\.
Registered but harmless
Received 1,148 Likes
Originally Posted by SteveP66
Ask them for a breakdown of the $280.00 - I just don't see why they are charging so much.
Turd Polisher
I'm tempted to do all of this stuff myself because I can't afford it right now .. it would be MUCH cheaper to do it myself. Ugh ... I don't want to mess anything up either :P.
Zonian22
11-14-2015 01:20 PM
BlkTxAcuraTypeS
10-18-2015 08:05 PM
brandnewcolony
09-12-2015 10:39 AM
