Air filter replacement 3G Garage #F-129
Old 06-28-2008, 02:34 PM
  #41
'06 NBP TL 6spd
realfresh's Avatar
Originally Posted by nextech
OK, I'm retarded. Even after reading this I managed to break one of the clips. Whe you said "pull towards the engine", I pulled up towards the engine I guess the correct thing to di is to "slide it towards the engine" I managed to not break the second clip.
Now, the question I have is where can I get a replacement clip? Is there even a part number for this? Help would be appreciated.
Thanks nextech, I should've read the whole thread at the beginning but once I saw this, I didn't feel like as big an idiot. Thanks! That really helped.
It took 30k+ miles, but I finally changed the air filter, wow, it's a lot smoother now. The old one was GROSS
Old 07-01-2008, 05:43 PM
  #42
happytang's Avatar
Ok, so the bolts on my air filter are stuck, and I'm getting pretty close to ruining the head.
I guess the best way would be to find a 8mm head? I tried just using a wrench and the thing still won't turn.
Just looking for an alternative.
Old 07-01-2008, 06:09 PM
  #43
Team SSM
SSMTL04's Avatar
yeah, just use a 8mm socket
Old 11-21-2008, 03:18 AM
  #44
whatjones911's Avatar
One of the 8mm bolts snap off while i was screwing it back on. Is there a way to replace just the bolt because these contain retainers.
Old 11-21-2008, 03:29 AM
  #45
more importantly, how can i take out the other half the screw that is still inside? I think i'm screwed. << haha screwed....
Old 12-12-2008, 03:21 PM
  #46
Q('.')=O
imj0257's Avatar
Goddam those 2 clips won't budge! I read that you should slide them out toward the engine but they just won't move and seems like I'm ripping my fingers up lol. Any idea how to get these out easy?
Old 12-13-2008, 03:37 PM
  #47
doggydog's Avatar
Wow after 47,000 miles the stock oem air filter was not only gross but had some build up, it feels heavy. The car is a lot smoother and responsive. It wont go pass 20,000 miles before I replace it again. Stock OEM air filter BTW.
Old 09-10-2009, 08:14 AM
  #48
Q('.')=O
imj0257's Avatar
Just replaced mine for the first time since I've had the TL and damn did it need it. Didn't take a pic but let's just say 3/4 of it was covered in a layer of black gunk.
Old 09-10-2009, 08:17 AM
  #49
LoveMyTL-S's Avatar
Glad to see you got the clips out. What did you end up doing?
Old 09-10-2009, 08:50 AM
  #50
Q('.')=O
imj0257's Avatar
Well I got my oil changed the other day and they took a look at the filter so when I got home I was like if they did it in no time then I should be able to as well. Soo I just did what I did the first time but this time they came out...maybe the mechanics loosened it when they did the oil change but it was a lot easier this time and only took me about 5 min to replace the filter.
Old 09-10-2009, 08:58 AM
  #51
LoveMyTL-S's Avatar
Sweet! Glad it worked out for you. I need to do mine......... Time to order.
Old 09-26-2009, 02:11 PM
  #52
T0L8's Avatar
Is there a Honda equivalent to the Acura air filter for the 3G TLs? I would imagine these cars have some parts that are common to both brands (ex: oil filter).
Old 08-11-2011, 07:08 PM
  #53
Shahk's Avatar
Are there any other threads or a video showing how to change this. Following the first post didn't really work for me. I couldn't get to the bolts on the left side either, these things are turn down so hard its frustrating!
Old 05-02-2016, 04:06 PM
  #54
bigmutt's Avatar
Yes. Same for me. Struggled for an hour today and wound up just tightening the four bolts back up, without removing the filter element.
Remember when you had to spin one wing nut in the center, and the air filter housing cover would lift off ... you'd remove the old, plop in the new, and Bob's-Your-Uncle ... the whole process took about 30 seconds !!
Old 05-03-2016, 05:14 PM
  #55
bigmutt's Avatar
update: never mind on the video request .... although it might be instructive to see SOMEONE ELSE chew up their fingers and hands with the clips, the bolts and the whole damn thing. The top (lid?) of the air filter box is what I found most difficult to work with. Getting it to lift far enough (and clear the car's body right behind it) to get the old element out was actually impossible without disassembling various other pieces.
I kept telling myself that an air filter replacement is not going to get the best of me, so three hours later, and a few broken parts, including a chunk of plastic the size of a half-dollar broken off the housing "lid" I finally succeeded in a task that used to take me 30-45 seconds on my previous car.
The filter looked like OEM original so it's a good thing I got this done ... but now I've got a hole sucking in air ABOVE the filter, so I'm not sure if that's going to affect something eventually.
Suggestion: allow yourself plenty of time; and keep a couple of large knuckle BandAids handy because the WILL be blood. Oh, and most importantly, take the time to unfasten the part that's clamped onto the intake: it only takes a few minutes and makes things SO MUCH easier.
drone619
01-26-2016 07:09 PM
Skirmich
09-15-2015 06:41 PM
Aleax
09-09-2015 08:04 PM
sputik
09-07-2015 01:40 PM
bymotion
08-31-2015 05:00 PM
Quick Reply: Air filter replacement 3G Garage #F-129
