Air cond question
Air cond question
Is there any way to make the fan come on at high speed when you use the "auto" function of the a/c? When I get in my car and it's 90+ outside and hit the auto button,the fan is on the second slowest speed and I manually turn it up to the max. Any thoughts? TIA
Originally Posted by AMIC
It depends on what you have the temp set at. Try putting it on Lo and the fan will probably come on at full speed.
There is no easy way to do it. I tried to figure this out last summer and hoped the memory function would remember the last fan setting or at least remember that I had it set on high speed fan the last time I unlocked the doors, but it just doesn't work that way.
Fightin' Texas Aggie
That's really not the function of Auto mode. In that mode you set the temp and the car makes it that temp. It does whatever it wants to make it that temp. You have no control over any part of the A/C system. If you press any button other than temp then it turns off Auto. If you always want the fan on high then you take it off Auto and the memory will keep it there.
Registered but harmless
Received 1,150 Likes
Auto mode
The "Auto" mode on the A/C system on my 2005 TL automatically increases the fan speed to maximum, or just below max, and enters "recirc" mode to cool down the interior until it is within a few degrees of the set temperature. The system will then turn off recirc mode, lower fan speed and bring in fresh air to maintain temperature. It may take a few seconds (no more than 10) for "auto" mode to increase the fan speed and start recirc mode, but you should not have to manually change any settings. See service department if that is not the case...
Voice Command "Temperature Max Cold"
I have an '05 Navi, so I don't know if this works with all models:
Turn off dual temperature control. (Voice command is "Temperature Balance')
1. Press voice command button on steering wheel
2. Say "Temperature Max Cold"
When you are cool enough, press voice command button and say "temperature XX degreees."
As far as I know, this is the fastest way to cool down your TL.
BoricuaTL
04-08-2016 01:08 PM
