Aftermarket or Acura parts
I think I need a new window motor and regulator. Found Dorman product for $75 or Acura for $130. What would you guys recommend? Thanks!!!
Aftermarket or Acura parts.
Spend $130??? If you don't think Dorman (lifetime warranty) is a quality part, go to RockAuto and take your pick. One must be cautious when choosing aftermarket parts, but a window motor/regulator is a no brainer as most offer the same warranty as OEM, (12 months) and you wouldn't be looking for a part if the OEM hadn't gone bad.
Forget the K&N in any form.
DMZ (06-10-2019)
I've had good luck with most aftermarket. If you can find the manufacturer that makes the OEM, then you can often get a better deal. NGK, Denso, Hitachi and Aisen are common manufacturers for Honda/Acura parts. If I"m on Rockauto and looking for something, I'd trust those brands as much as purchasing the part on an Acura OEM site. Having said that, many Acura OEM sites have pretty good prices - way better than your local dealer (and the local dealers often don't have the part in stock anyways. I've used oemacuraparts.com and acurapartswarehouse.com and both have been great.
The other part of the equation, at least for me, is how easy the part is to replace vs. how much it costs. An alternator for example, is around $450 for OEM, close to $300 or so on Rockauto for Denso (OEM Manufacturer). However, an Autozone Duralast is only $150. Since it has a lifetime warranty and is a relatively easy install (about 1 hour at most), I just went with the Duralast. If it goes bad, I'm only out an hour of labor. It's been about a year so far and no problems. Same goes for most suspension parts. I've done upper control arms, tie rod ends and sway bar links - all aftermarket. Moog, ACDelco or Mevotech. So far so good. They're easy to replace as long as the bolts are super-duper rusted and all have good warranties. So far, I haven't had to re-replace anything. And for some reason, OEM Acura suspension parts cost an arm and a leg compared to aftermarket.
A window motor/regulator might be more of a pain to change out. Maybe not, but I hate ripping doors apart. I always seem to break the little plastic clips then get rattles and what not. You might want to purchase more of those clips in case any break. Anyways, if you find it's a pain to do, purchasing OEM might be a good bet so you know you're getting pretty decent quality and won't have to go digging around in there again.
M
. My manual says over 1 gallon of antifreeze but others here says just 1 gallon. Can you help on that? Thank you
mav3556
12-29-2008 05:06 PM
