Acura V6 Motor Schematic 3G Garage #L136
Aaaarrrggghhhh!
MB - Thanks for posting all this great info today! (including your other posts)
Does the manual you are getting these from include any tourque specs or more detailed pics? Also, where did you get it? Can we just pick it up in our local Acura service dept?
Good job and Thanks!
Registered User
Originally Posted by paul revere
I thought that the exhaust manifolds were cast right in the block, therefore there would be no need for exhaust manifold gaskets.
Originally Posted by MichaelBenz
Ya....that is one they missed....dont believe there is a gasket. But hey...they still have mistakes on their web site for the TL options also....It is a good "general" reference tool though and did come straight from the Acura dealer. They use this material in this Acura Service Consultant Technical Guide book, I am sure, to explain to newbies and ladies whats what when they are in service. Ought to work here too....
But like you said its for people who don't know what the parts are so minor differences won't really matter.
checkmate...
No....it is just a service advisors "for dummies" manual more or less that they use to explain to customers what needs to be done to their car when they dont know what they are talking about.
Service Manager: "Sir, based on my technician's diagnosis of your overheated engine, it looks like we'll have to overhaul it."
Customer: "Oh man..., that sounds very bad. So what needs to be done?"
Service Manager: "Here, let me show you our 'Service Consultant Illustrated Technical Guide'." [Opens book to page shown above] "We will have to dismantle the engine and replace the valves, valve springs, and pistons, among other things." [Points to each respective part]
Customer: "Well, I don't like green. Do you have pistons in any other color?"
TL has a timing belt, not a chain
Originally Posted by skyy406
werd, doesnt the 2004+ TL have a timing chain and not a belt?
Part#14400-RCA-A01 (04-05) ALL
Remarks: (197YU20 VE-501) (UNITTA)
Registered Member
Originally Posted by mio
Can we say DOHC r better than SOHC?
or depends on different engines?
But Honda/Acura has made excellent power output from their SOHC designs. So has Ford, BMW, and some others. However, the move is, and has been, towards DOHC in performance engines.
Airline jet aircraft tech
Due to a MIL light coming on, I took my 06 TL in for repair. Tech read on the HDS scanner that code P0304, #4 cylinder misfire was set. Dealer technician first swapped ignition coils from #4 and #5 cylinder, but code was still set on #4. Then he swapped #4 and 5 fuel injectors, and misfire code followed to #5 cylinder. Changed #5 injector and misfire code did not return after several dealer test drives over 2 days. One thing I forgot to ask at the shop was the location of the cylinder/injector numbers. Are the # 4 and 5 cylinders on the front or rear bank of heads? I own the 04 TL shop manual and I can't find this info in it anywhere, under the hood and even searching Acurazine and the web. Anyone know?
HMFIC
Don
Zonian22
11-14-2015 01:20 PM
darksky
09-05-2015 03:11 AM
detailersdomain
Wash & Wax
09-03-2015 10:56 PM
