Acura ServiceNews Bulletins
#202
I am not able to see any links on Honda site. Every tome I click on the links posted in discussion, I get forwarded to this link LinkDeny and it says 'you are not authorized'. Am I doing something wrong?
For newer bulletins you can click on the first link given (not the second, Honda, link) and go directly to the TSB.
#203
March 2015:
B15030B
AcuraLink iOS Cable Kit
http://www.urvi.net/forumfiles/SN/B15030B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15030B.PDF
B15030B
#204
April 2015:
B15040B
New Features Added to SIS!
http://www.urvi.net/forumfiles/SN/B15040B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15040B.PDF
B15040C
Center Console Lid Won’t Open or Is Hard to Slide
http://www.urvi.net/forumfiles/SN/B15040C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15040C.PDF
B15040D
Removing a Stripped or Broken T-30 Torx Fastener from the Steering Wheel
EDITOR’S NOTE: This article replaces “Tips for Removing Stripped or Broken T-30 Torx Bolts,” posted in September 2013.
http://www.urvi.net/forumfiles/SN/B15040D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15040D.PDF
B15040E
Want more Videos in Service Bulletins? Take Our Survey and Let Us Know
http://www.urvi.net/forumfiles/SN/B15040E.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15040E.PDF
B15040B
B15040C
B15040D
B15040E
#205
May 2015:
B14100D
Center Rear Seat Belt Buckle Installation Is OK
EDITOR’S NOTE: This article replaces the one posted in October 2014. Changes are highlighted in yellow.
http://www.urvi.net/forumfiles/SN/B14100D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14100D.PDF
B15050B
Poor Sound Quality; Weak Volume from the Front or Rear Speakers
EDITOR’S NOTE: This article replaces “Poor XM, CD, Aux Device Sound Quality; Weak Volume From Speakers,” posted in February 2008.
http://www.urvi.net/forumfiles/SN/B15050B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15050B.PDF
B15050C
AGM Battery Testing and Charging Precautions
EDITOR’S NOTE: This article replaces “Battery Testing in 2015 TLXs,” posted in September 2014.
http://www.urvi.net/forumfiles/SN/B15050C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15050C.PDF
B15050D
New Features Added to Tech Line Create New Case Page
http://www.urvi.net/forumfiles/SN/B15050D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15050D.PDF
B14100D
B15050B
B15050C
B15050D
MarcDavidoff (01-19-2016)
#207
June 2015:
B15060C
Removing the Protective Covering from a Leather-Wrapped Steering Wheel
http://www.urvi.net/forumfiles/SN/B15060C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15060C.PDF
B15060C
#208
Agreed, great service you're providing us, thanks!
Is there anyway to tell what years are applicable without opening the links first? Would it be a hassle to add the applicable vehicles & model years? Might also help pinpoint this data in search results.
#209
Since EE4Life is graciously providing these links, and hosting the PDF's so we don't have to go through the process of accessing the Honda links, I'll leave it up to him about expanding on the information, when applicable.
#210
#211
July 2015:
B15070B
Don’t Use Leak Check Dye in These Vehicles!
Affected Vehicles: 2013–14 ILX Hybrid, 2016 MDX, 2014 RLX Sport Hybrid, 2015 TLX
http://www.urvi.net/forumfiles/SN/B15070B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15070B.PDF
B15070C
Hazard Warning Switch Sticks
Affected Vehicles: 2010-13 MDX (All trim levels except base)
http://www.urvi.net/forumfiles/SN/B15070C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15070C.PDF
B15070D
Can’t Send HDS Files to Tech Line? Check Out This Work-Around
EDITOR’S NOTE: This article replaces the one posted in August 2011.
Affected Vehicles: General Information
http://www.urvi.net/forumfiles/SN/B15070D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15070D.PDF
B15070E
In a Pinch, OK to Use ATF Type 3.0 in a 9-Speed Automatic Transmission
Affected Vehicles: All models with 9-speed automatic transmission
http://www.urvi.net/forumfiles/SN/B15070E.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15070E.PDF
B15070B
B15070C
B15070D
B15070E
#212
#213
August 2015:
B15070B
EDITOR’S NOTE: This article revises the one posted in July 2015. Changes are highlighted in yellow.
B15080B
Automatic Intermittent Wipers Don’t Work Properly
Affected Vehicles: 2014–16 MDX - Advance, Technology
2016 RDX - Advance
2015 TLX - Advance, Technology
http://www.urvi.net/forumfiles/SN/B15080B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15080B.PDF
B15080C
Front Brakes Squeal at Low Mileage
Affected Vehicles: 2016 ILX
http://www.urvi.net/forumfiles/SN/B15080C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15080C.PDF
B15070B
B15080B
2016 RDX - Advance
B15080C
MonkeyTrucker (09-02-2015)
#215
September 2015:
B15090B
Checking the Alcohol Level in Gasoline
EDITOR’S NOTE: This article replaces “This New Special Tool Checks Alcohol Level in Gasoline,” posted in April 2012.
http://www.urvi.net/forumfiles/SN/B12040B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B12040B.PDF
B15090C
Never Use Conventional Wheel & Tire Assemblies on PAX System-Equipped Vehicles
EDITOR’S NOTE: This article replaces “Never Use Conventional Wheel & Tire Assemblies on PAX Vehicles,” posted in May 2013.
Affected Vehicles: 2006-08 RL with Technology Package
http://www.urvi.net/forumfiles/SN/B13050C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B13050C.PDF
B15090E
Tire Pressure Sensor Oxidation Causes Slow Leak
Affected Vehicles: 2009-14 TL
http://www.urvi.net/forumfiles/SN/B15090E.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15090E.PDF
B15090B
B15090C
B15090E
MonkeyTrucker (12-01-2015)
#216
October 2015:
B15100B
Dashboard Side Vents Reflect in Door Glass
Affected Vehicles: 2016 RDX (Technology and Advance)
http://www.urvi.net/forumfiles/SN/B15100B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15100B.PDF
B15100C
Check Out the Airbag Inflator Recall iN Page!
http://www.urvi.net/forumfiles/SN/B15100C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15100C.PDF
B15100B
B15100C
#217
November 2015:
B15110B
Multiple Loss-of-Communication DTCs Won’t Clear?
Affected Vehicles: 2016 MDX and 2015-16 TLX with 9-speed A/T
http://www.urvi.net/forumfiles/SN/B15110B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15110B.PDF
B15110B
#218
December 2015:
B15080C
EDITOR’S NOTE: This article revises the one posted in August 2015. Changes are highlighted in yellow.
B15120B
Additional Engine Valley Drain Hole in V6 Engines
EDITOR’S NOTE: This article replaces “New Passage for Engine Valley Drain Hole in V6 Engines,” posted in October 2008.
Affected Vehicles: 2009 TL and all later V6 Acura models
http://www.urvi.net/forumfiles/SN/B15120B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15120B.PDF
B15120C
Aftermarket Replacement Windshield May Cause AcuraWatch Systems to Work Abnormally
EDITOR’S NOTE: This article replaces “Aftermarket Replacement Windshield May Cause Advanced Safety and Driver Assist Systems to Work Abnormally,” posted in October 2014.
Affected Vehicles: All models with AcuraWatch systems
http://www.urvi.net/forumfiles/SN/B15120C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15120C.PDF
B15120D
Always Transfer HDD to Replacement Audio-Navigation Unit
EDITOR’S NOTE: This article replaces “HDD Access Error? Transfer HDD to Replacement Audio-Navi Unit,” posted in February 2013.
Affected Vehicles: All models with HDD-based navigation system
http://www.urvi.net/forumfiles/SN/B15120D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15120D.PDF
B15080C
B15120B
B15120C
B15120D
#220
January 2016:
B16010B
Soiled or Stained Leather Seats?
EDITOR’S NOTE: This article replaces “Soiled Leather Seats? Clean Them First Before Thinking Replacement,” posted in November 2008.
http://www.urvi.net/forumfiles/SN/B16010B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16010B.PDF
B16010C
Watch OnePack Videos Any Time from the Video Library!
Affected Vehicles: 2015 TLX and all future-release Acura models
http://www.urvi.net/forumfiles/SN/B16010C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16010C.PDF
B16010D
A Word On Aftermarket Code Readers
http://www.urvi.net/forumfiles/SN/B16010D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16010D.PDF
B16010B
B16010C
B16010D
#221
February 2016:
B16020B (REVISED-See March 2016)
Improper Body Noise Repair Can Be Costly
http://www.urvi.net/forumfiles/SN/B16020B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16020B.PDF
B16020C
Fog Light Lenses Look Melted or Discolored?
Affected Vehicles: All models with fog lights
http://www.urvi.net/forumfiles/SN/B16020C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16020C.PDF
B16020D
Power Distribution Schematics Added to Next Generation EWDs
http://www.urvi.net/forumfiles/SN/B16020D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16020D.PDF
B16020C
B16020D
#222
March 2016:
B16020B
Improper Body Noise Repair Can Be Costly!
EDITOR’S NOTE: This article revises the one posted in February 2016. Changes are highlighted in yellow.
B16020B
#223
April 2016:
B16040B
A/T DTC P287C After TCM Replacement
http://www.urvi.net/forumfiles/SN/B16040B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16040B.PDF
B16040C
Concentrated Sunlight Can Cause Melted Plastic Body Parts and Trim
EDITOR’S NOTE: This article replaces “Concentrated Sunlight Can Melt Plastic Body Parts and Trim,” posted in June 2011.
http://www.urvi.net/forumfiles/SN/B16040C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16040C.PDF
B16040D
Installing an Accessory Trunk Lid Spoiler? Always Use the Metric Rotabroach Master Hole Cutting Kit and the Deburring Tool
EDITOR’S NOTE: This article replaces “Installing Accessory Trunk Spoiler? Use Rotabroach Hole Cutting Kit,” posted in May 2012.
Affected Vehicles: All models with available accessory trunk lid spoiler
http://www.urvi.net/forumfiles/SN/B16040D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16040D.PDF
B16040B
B16040C
B16040D
#224
May 2016:
B15020B
Left-Foot Braking and the Brake Override System
EDITOR’S NOTE: This article revises the one posted in February 2015. Changes are highlighted in yellow.
Affected Vehicles: All models with the brake override system
http://www.urvi.net/forumfiles/SN/B15020B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B15020B.PDF
B16050C
Getting the Anti-Theft Code for an Audio Unit/Audio-Navigation Unit with Display Audio
Affected Vehicles: 2017 NSX
http://www.urvi.net/forumfiles/SN/B16050C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16050C.PDF
B16050E
Coming Soon: The All-New i-HDS!
http://www.urvi.net/forumfiles/SN/B16050E.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16050E.PDF
B15020B
B16050C
B16050E
#226
June 2016:
B14020D
CMBS Indicator On with CMBS DTC P2583-97
EDITOR’S NOTE: This article revises the one posted in February 2014. Changes are highlighted in yellow. Affected vehicles now include the 2015-16 MDX.
Affected Vehicles: All models with CMBS where the millimeter wave radar looks through the front grille upper molding
http://www.urvi.net/forumfiles/SN/B14020D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14020D.PDF
B14120C
Dashboard Side Vent Reflection in Door Glass
EDITOR’S NOTE: This article revises the one posted in December 2014. Changes are highlighted in yellow.
Affected Vehicles: 2015-16 TLX
http://www.urvi.net/forumfiles/SN/B14120C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14120C.PDF
B16050E
Introducing the All-New i-HDS!
EDITOR’S NOTE: This article replaces “Coming Soon: The All-New i-HDS!,” posted in May 2016.
B16060D
HDD Access Error Message?
EDITOR’S NOTE: This article replaces “Always Transfer HDD to Replacement Audio-Navigation Unit,” posted in December 2015.
http://www.urvi.net/forumfiles/SN/B16060D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16060D.PDF
B16060F
Brake Clicking Is Normal
EDITOR’S NOTE: This article replaces “Some Brake Click Is Normal,” posted in April 2001.
http://www.urvi.net/forumfiles/SN/B16060F.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16060F.PDF
B16060G
Engine Intermittently Rattles or Runs Rough with MIL Blinking?
Affected Vehicles: 2014-16 MDX, 2013-16 RDX, 2014-16 RLX, 2014 RLX Sport Hybrid, and 2016 RLX Sport Hybrid
http://www.urvi.net/forumfiles/SN/B16060G.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16060G.PDF
B14020D
B14120C
B16050E
B16060D
B16060F
B16060G
The following 2 users liked this post by EE4Life:
George Knighton (01-07-2017),
victorber (10-26-2018)
#227
July 2016:
B16070C
Use 16 mm Punch Tool to Install Accessory Parking Sensors on Rear Bumper
Affected Vehicles: 2017 MDX
http://www.urvi.net/forumfiles/SN/B16070C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16070C.PDF
B16070D
Don’t Use the Tool Kit Funnel to Manually Fuel the Vehicle at TQI
http://www.urvi.net/forumfiles/SN/B16070D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16070D.PDF
B16070E
SRS Indicator On with No DTCs or with Open Circuit DTCs? Check the Deployed History in the i-HDS
Affected Vehicles: All models using the SRS SAE standard
http://www.urvi.net/forumfiles/SN/B16070E.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16070E.PDF
B16070C
B16070D
B16070E
#228
August 2016:
B13030B
Speedometer Shops: The Place to Transfer Odometer Mileage
EDITOR’S NOTE: This article replaces the one posted in March 2013.
http://www.urvi.net/forumfiles/SN/B13030B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B13030A.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B13030B.PDF
B16080B
Accessory Remote Engine Starters Aren’t the Same!
Affected Vehicles: Acura models with available accessory remote engine starter
http://www.urvi.net/forumfiles/SN/B16080B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16080B.PDF
B16080D
Front Passenger’s Airbag Inflator and Inflator Harness Installation Tips
Affected Vehicles: 2009-11 TSX, 2011 TSX Sport Wagon, and 2010-11 ZDX
http://www.urvi.net/forumfiles/SN/B16080D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16080D.PDF
B16080E
Remember to Reset the Parking and Back-up Sensor Control Unit
Affected Vehicles: 2016-17 RDX
http://www.urvi.net/forumfiles/SN/B16080E.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16080E.PDF
B16080F
SRS Safety Guidelines
Affected Vehicles: All models with SRS
http://www.urvi.net/forumfiles/SN/B16080F.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16080F.PDF
B13030B
B16080B
B16080D
B16080E
B16080F
#229
September 2016:
B040603
Poor Installation of Adhesive-Backed Accessories Can Affect Your Dealership and the Acura Brand
EDITOR’S NOTE: This article replaces “Side Moldings Coming Loose or Falling Off,” posted in June 2004.
http://www.urvi.net/forumfiles/SN/B040603.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B040603.PDF
B16090B
Connected Circuits and Trace Features Added to Next Generation EWDs
http://www.urvi.net/forumfiles/SN/B16090B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16090B.PDF
B16090C
Aftermarket Roof Racks Can Cause Roof Damage
http://www.urvi.net/forumfiles/SN/B16090C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16090C.PDF
B16090D
Avoiding Door Inner Handle Paint Scratches
http://www.urvi.net/forumfiles/SN/B16090D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16090D.PDF
B040603
B16090B
B16090C
B16090D
#231
November 2016:
B14070E
8-Speed and 9-Speed ATFs Follow New Fluid Naming Convention
EDITOR’S NOTE: This article replaces “2015 TLX Uses New ATFs and Fluid Naming Convention,” posted in July 2014.
Affected Vehicles: All 2015 and later models with 8-speed dual clutch and 9-speed automatic transmissions
http://www.urvi.net/forumfiles/SN/B14070E.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14070E.PDF
B16110B
A/T DTC P0901: Description and Troubleshooting
Affected Vehicles: 2015 TLX V6
http://www.urvi.net/forumfiles/SN/B16110B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16110B.PDF
B16110C
Aftermarket Radar Detectors May Interfere with GPS Antenna
Affected Vehicles: 2013-17 ILX, 2013-17 MDX, 2013-17 RLX and 2013-17 TLX with navigation system
http://www.urvi.net/forumfiles/SN/B16110C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16110C.PDF
B14070E
B16110B
B16110C
#232
December 2016:
B14020F
Use ServiceExpress if SIS Isn’t Available
http://www.urvi.net/forumfiles/SN/B14020F.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B14020F.PDF
B16120B
Shift Quality Issues in a 9-Speed A/T? Check the ATF Level
Affected Vehicles: 2016-17 MDX and 2015-17 TLX V6
http://www.urvi.net/forumfiles/SN/B16120B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B16120B.PDF
B14020F
B16120B
#233
January 2017:
B16040D
EDITOR’S NOTE: This article revises the one posted in April 2016. Changes are highlighted in yellow.
B17010B
Loose Trunk Mat Trim Fasteners
http://www.urvi.net/forumfiles/SN/B17010B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17010B.PDF
B17010C
Multiple Indicators and MIL On with A/T DTC P26C3
Affected Vehicles: 2016-17 MDX, 2017 NSX, 2014-17 RLX Sport Hybrid, and 2015-17 TLX
http://www.urvi.net/forumfiles/SN/B17010C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17010C.PDF
B16040D
B17010B
B17010C
#234
February 2017:
B17010C
EDITOR’S NOTE: This article revises the one posted in January 2017. Changes are highlighted in yellow.
B17020B
2017 NSX Audio System Features
http://www.urvi.net/forumfiles/SN/B17020B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17020B.PDF
B17020C
Air Bubbles Under the Clear Protective Tape
http://www.urvi.net/forumfiles/SN/B17020C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17020C.PDF
B17020D
Read This Before Swapping or Replacing an AcuraLink Telematics Unit
Affected Vehicles: 2016-17 ILX (Tech Plus and Tech Plus A-Spec), 2014-17 MDX (Tech and Advance), 2016-17 RDX (Tech and Advance), 2014-17 RLX, and 2015-17 TLX (Tech and Advance)
http://www.urvi.net/forumfiles/SN/B17020D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17020D.PDF
B17010C
B17020B
B17020C
B17020D
Malibu Flyer (03-04-2017)
#235
March 2017:
B17030B
Never Mix Up Connecting Rod Caps!
EDITOR’S NOTE: This article revises the one posted earlier in March 2017. Changes are highlighted in yellow.
http://www.urvi.net/forumfiles/SN/B17030B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17030B.PDF
B17030C
Announcing the Acura Professionals 2017 TOPTECH Competition!
http://www.urvi.net/forumfiles/SN/B17030C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17030C.PDF
B17030B
B17030C
#236
April 2017:
B16040D
Installing an Accessory Trunk Spoiler? Always Use the Metric Rotabroach Master Hole Cutting Kit and the Deburring Tool
EDITOR’S NOTE: This article replaces “Installing an Accessory Trunk Lid Spoiler? Always Use the Metric Rotobroach Master Hole Cutting Kit and the Deburring Tool,” posted in January 2017.
Affected Vehicles: All models with available accessory trunk spoiler
B17040B
SH-AWD Rear Differential Leaks
Affected Vehicles: 2014-17 MDX and 2015-17 TLX with SH-AWD
http://www.urvi.net/forumfiles/SN/B17040B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17040B.PDF
B17040C
No AcuraLink Real-Time Traffic?
Affected Vehicles: 2014 MDX and 2014 RLX with navigation system
http://www.urvi.net/forumfiles/SN/B17040C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17040C.PDF
B16040D
B17040B
B17040C
#237
May 2017:
B17040B
EDITOR’S NOTE: This article revises the one posted in April 2017. Changes are highlighted in yellow.
Affected Vehicles: 2016-17 MDX and 2015-17 TLX with SH-AWD
B17050B
Opening Doors Without 12-Volt Power
http://www.urvi.net/forumfiles/SN/B17050B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17050B.PDF
B17040B
B17050B
#238
How-To: Service Bulletin URL
Forgive me if this is common knowledge that I somehow overlooked, but here's a screenshot illustrating the URL pattern for historic/archived Acura service bulletins. Or, at least, it's the pattern employed by the SB's I used as test cases when taking stabs in the dark on how to reach them... I hope it proves useful to someone.
How to guess the URL of an Acura service bulletin.
LoveMyTL-S (07-03-2017)
#239
June 2017:
B17060B
DTC P0562 Set with MIL Off and No Apparent Symptom?
Affected Vehicles: 2017 MDX Sport Hybrid and 2017 NSX
http://www.urvi.net/forumfiles/SN/B17060B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17060B.PDF
B17060B
#240
July 2017:
B17070B
Where’s the Sealing Bolt in That Reman 9-Speed A/T?
http://www.urvi.net/forumfiles/SN/B17070B.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17070B.PDF
B17070C
Chatter or Rattle Near Left or Right Door Tweeter
http://www.urvi.net/forumfiles/SN/B17070C.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17070C.PDF
B17070D
Aiming the Millimeter Wave Radar? Do the Mechanical Vertical Aiming First
Affected Vehicles: Acura models with the millimeter wave radar
http://www.urvi.net/forumfiles/SN/B17070D.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17070D.PDF
B17070B
B17070C
B17070D
Last edited by EE4Life; 08-01-2018 at 08:03 PM. Reason: Added B17070C - Chatter or Rattle Near Left or Right Door Tweeter
