Acura ServiceNews Bulletins
#121
Administrator
Finally available from Honda, but not much in it. Maybe they are skipping a month and it won't be available until the month after it's published.
June 2010 added.
Major topics applicable to 3G and 4G TL:
None
General information:
Don't cover the headlights with a fender covers (for you DIY'ers)
TOP TIER detergent gasoline recommended.
June 2010 added.
None
#122
Honda won't sell parts to independent shops, now they won't let us see the monthly bulletins. Nothing like trying to enhance their customer relationships. I'm seeing Nissan in my future.....they still let you download owners manuals.
#123
Administrator
Everything works again!
#124
Great news.
#125
Administrator
July 2010 added.
Replace the spark plugs, don't clean them (General info)
That's all, folks
That's all, folks
#126
Very useful thread thanks!!
#127
Administrator
August 2010 added.
Rodent deterrent tape for wire harnesses-General info (probably good for knock sensor replacement or repair of wiring-mod edit added)
#128
Administrator
September, October and November 2010 added.
September 2010:
None
October 2010:
Steering Wheel Vibration? Could Be Cold Flat-Spotting (all vehicles)
New All-Wheel Drive Fluid (DPSF) for SH-AWD (general information)
November 2010:
Tighten Tire Pressure Sensor Valve Stem Nuts With a Torque Wrench (all models with TPMS)
0W-20 Engine Oil Application Guide Is Now Available! (general information)
New ATF DW-1 Now Available (replaces ATF-Z1 general information)
Steering Feels Notchy? Check the U-Joint Phasing (all models with telescopic steering)
September 2010:
None
October 2010:
November 2010:
#129
Administrator
IMPORTANT NOTICE
UPDATED 6 DECEMBER 2010
We have regained our access. See instructions in first post.
#130
Administrator
December 2010 added.
HID headlight beams look uneven? It's normal. (All vehicles)
Pinging While Accelerating? Could Be Low Octane or Low Quality Fuel (All vehicles)
#131
Administrator
January 2011: Not published.
#132
Administrator
February 2011 added.
Sorry, nothing applicable to our cars this month.
#133
Administrator
March 2011 added.
Sorry, nothing applicable to our cars this month. Two items, applicable to Acura Technicians only.
#134
Administrator
April 2011 added.
Sorry, only one page, nothing applicable to 3G/4G TL.
#135
Administrator
May 2011 added.
Replacing the Audio-Navigation Unit (’09 and later TL) Someone might want to DIY someday
Use Paper Strips to Adjust Door, Hatch, or Tailgate Seal Tension (All vehicles) Might be useful if you are out of warranty and having wind noise or water leakage problems
#136
Administrator
June 2011 added.
Sorry, nothing applicable to owners for our cars this month. All items applicable to Acura Technicians only.
#137
Administrator
July 2011 added.
But there is a handy tool available that might interest DIY'ers or auto repair or body shop workers: Push Pin/Grab Rail Cap Pliers Make Trim Removal Easier
#138
Administrator
August 2011 added.
Sorry, nothing applicable to owners for our cars this month. All items applicable to Acura Technicians only, but a couple of items might help out a few DIY'ers.
Engine Noise, A/C Not Working Right? Check Compressor Clutch First-might help explain some of those strange noises some people encounter.
Aftermarket Trailer Hitch Wiring Can Cause Electrical Problems-also might help some individuals.
#139
Administrator
September 2011 added.
HomeLink® Won’t Work with Garage Door Opener? Read This First (’08 and later TL)
Loss of Power While Driving? Could Be the Brake Override System ('12 TL)
A/C Problems or a Dead Battery? Check the Compressor Clutch Relay (General information for all Acura's)
#140
Administrator
October 2011 still not available. Will keep checking and post when available.
Edit update-October 2011 not published.
#141
Administrator
November 2011 added.
A Special Announcement for ServiceNews Readers-explains why some copies are no longer available.
Wind Noise From the Lower Windshield or Dashboard Area (09-12 TL)
#142
Administrator
December 2011 added.
Alarm Goes Off; TRUNK OPEN Message Comes On (’09–12 TL base model with accessory trunk spoiler) - not really a DIY but will explain why this is happening if the alarm goes off and the message comes on.
#143
Administrator
January 2012 added.
Major topics applicable to 3G and 4G TL: (Some of these are more applicable to techs with the proper equipment but might give you a little help if this happens to you.)
Try a Battery Cable Reset for Those Odd Electrical Problems - general information applicable to all
Engine Shuts Off, but Power Mode Stays in ON or ACCESSORY - '09-12 TL
One-Push Start Vehicle Won’t Start? Try This First - '09-11 TL
#144
Administrator
February 2012 added.
Major topics applicable to 3G and 4G TL: None
#145
Administrator
March 2012 added.
Topics applicable to 3G and 4G TL:
Tighten Tire Pressure Sensor Valve Stem Nuts With a Torque Wrench (All models with TPMS) It doesn't give you the torque values but it does alert you to the fact that when you install sensors you should find out what the specs are and install properly.
One-Push Start Vehicle Won’t Start? Try This First. Currently Applies To: ’09–11 TL with keyless access system. Some hints to help you if you encounter this problem.
JUSPEN80 (04-09-2012)
#146
Administrator
April 2012 added.
Another slow month. Nothing to add.
#147
Administrator
May 2012 added.
A/C Cools Poorly During Hard Acceleration- general information applicable to all
#148
Administrator
June 2012 added.
And another slow month. Nothing to add.
#149
Administrator
July 2012 added.
Left Dashboard Side Vent Is Warmer Than Right With A/C On - general information applicable to all
#150
Administrator
August 2012 added.
General information only applicable to all:
New HFL and Navi System Restrictions Help Keep Eyes on the Road (Currently Applies To: Models with driver distraction restrictions)-probably not applicable to most people here but it is a view of what's coming.
How to Deal With Common Seat Belt Complaints-might help you diagnose a problem with your seat belts.
#151
Administrator
September 2012 added.
Transfer HDD to Replacement Audio-Navigation Unit-09-12 TL (More for the techs but might be helpful for someone who wants to replace their own unit after the warranty has expired)
#152
Administrator
October 2012 added.
Nothing really applicable and only two items this month but I'll reference them here to show how all the technological improvements will affect future owners.
Red or Pinkish Red Water Detection Sticker Means Water Damage - Currently Applies To: ’13 ILX, ’13 RDX, ’09–13 TL, and ’10–13 ZDX (For keyless access remotes)
New Audio Anti-Theft System Means No More Code Cards or Stickers - Currently Applies To: All ’13 and later Acura models
#153
Administrator
November 2012 added.
General information only.
Filling Tires With Nitrogen: Why We Say No
#154
Administrator
December 2012 added.
Transfer HDD to Replacement Audio-Navigation Unit-09-12 TL (More for the techs but might be helpful for someone who wants to replace their own unit after the warranty has expired) Replaces information published in September 2012 Service News.
#155
Administrator
January 2013 added.
Sorry, not a darn thing for TL's this month
#156
I am not sure if it is me or something has happened on the site but I cant seem to read any bulletins past August 2008. I keeps telling me that I am not authorized, but I can read all of them up till then. Can you check on this and let me know what is going on. It would be much appreciated! This is awesome that you did this, very interesting and informative information!
#157
Administrator
Sometimes it fails after opening an instructions, and I found out that if I cleared my cache it would then work, but tonight I decided to try it without clearing the cache and it still worked.
I can't say why you are having the problem, but it does seem odd you can open old ones and not new ones.
Exactly what does the message say?
I found a couple that wouldn't open because the file was damaged. I'll check all of them later and see what I can do about them, but everything else opened ok.
#158
Administrator
Feb 2013 still not available. Will check a few more times before I conclude that Honda didn't publish one for last month.
Edit update 13Mar13: February 2013 not published
#159
I'm having the same issue. This is what I get:
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Please go back or return to the home page.
#160
Administrator
I just went through the process, as I always do when I get a message like this, and it works fine.
Follow the instructions exactly, and make sure you clear your cache before doing anything else.
I have added the cache instruction to the thread.
