AC Filter change at 22k?!
The cabin air filter should be changed every year
You will be shocked at what you were breathing thru!
After the first time its much easier
If you own a screwdriver, flashlight, scissors and can work on your knees for 20-30 minutes
then YES they are screwing you
DIY and spend $20 at autozone or similar
Bosch makes one with anti mold fungus stuff built into it - good choice
Originally Posted by BoostedJack
$100? you can change it yourself for around 30mins.... I do mine once a year.
It's easy BTW.
It's easy BTW.
Registered Member
Purolator makes one which I used in both of my 3G TLs last month. Cost is around $19 and installation is free since I do it myself. If you have a late model '04 (yes, there is a difference between the earlier and later '04's), plan on a 15-20 minute job. If you have an '05, the job takes about 10 minutes.
It's in the 3G Garage
F-130: DIY: Replacing Cabin Air Dust & Pollen Filter
https://acurazine.com/forums/showthread.php?t=87494
https://acurazine.com/forums/ramblings-12/firewall-help-123884/ Good pictures here
https://acurazine.com/forums/showthread.php?t=108345
https://acurazine.com/forums/ramblings-12/best-place-buy-snowboarding-pants-jackets-122290/
https://acurazine.com/forums/showthread.php?t=131831 Replacing the filter without removing the entire glove box
~Da Nocturnal Cheetah~
Originally Posted by THTL
so the ATP filter is the best so far for the TL?
thanks
thanks
Hahaha...I wonder if when I trade my car in, if Acura will do this change for someone and alert them to the cut, or just use my hole and still charge them for the install!
When I went to the rockauto website, the instructions look like I don't have to cut anything, let alone unscrew anything in the 06. Is this true anybody? I'm printing the instructions and going outside to look at this!
My Garage not
1 Post
^^yea u have to unscrew stuff to do anything on this car including changing the cabin air filter.
aesir - if u diy u'd be surprised how dirty the air filter gets! the stealership is not trying to screw u on u needing to have it changed at least lol.
Sure enough, the diagram is short-changing in it's description of the instructions. All that does is get you to the area that hides the filter! AARRGGHHH!! Sooo, I'm going to follow the links that Ron A gave and cutout my own passageway to the filter!
I did mine today and it only took a few minutes. After reviewing the procedure, I don't see why you need to remove the stops and lower the door, as the door is just part of the panel. Seems to me that if you remove the 2 center push pins on the each side at the top, pull the complete panel back, undo the 2 electrical connections and then you can access the filter. To reinstall, just push the unit back in.
I don't know, maybe I'm missing something obvious, but next time the door or stops aren't going to be removed.
By the way, the filter was absolutely filthy!
which filter did you get and where? thanks.
On eBay (aofeparts), I purchased 10 of the preferred Acura Filtech oil filters ($51.50), cabin filter ($16.25), washers, A/T washers, Acura PS fluid from a dealer in CA. and was only charged $10 for shipping as all were combined into one box.
where can i get the ATP cabin air filter. How good is the Purolator Cabin Air filter. thanks.
