6 speed grinds into 2nd on cold days
5th Gear
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
anyone else have this problem? The car grinds into 2nd on a cold day. It's almost like the trans fluid is too thick.
Stay Out Of the Left Lane
Received 1,236 Likes
If you really think it is grinding, might I suggest holding first longer and going right to third? At least until you can get it to your dealer.
TL-SHAWD 6MT Rocks!
I usually go from 1 - 3 - 6 with no problem, there is plenty of power on the highway.
and yes, from 1 to 2 it feels a little harder than other combinations...
5th Gear
Well vtechbrain, explain the cold temperature effecting shifting, if it's not to do with cold thick oil, since your brain is obviously the largest one in the forum. I have a 1998 Toyota Tacoma, and I’ve owned several other 5 spds in my time and none of them have had this problem. I'd think most manual transmissions have a higher ratio between 1st and 2nd why don't most of them grind?
Every car I've owned has had trouble getting into 1st and Reverse in cold weather, and sometimes going from 1st to 2nd. This is including 2 Acuras (94 Integra LS, 98 2.3CL). I found that double-clutching got rid of the stick temporarily until the fluid warmed up.
Received 2,329 Likes
Depends on a lot of things. Ratios, synchronizers etc.
Just about all Honda transmissions are like this when they're cold.
Problem sounds like my last Honda manual gearbox, a 1985 Honda CRX Si. It never liked going into 2nd until is was warmed up.
Since - I have not had the issue with Infiniti, Saab, or Toyota gearboxes.
I would want to get this looked at, a $35k TL should be more refined that a $11K CRX si
HMFIC
You can solve this by technique or lubricant. When shifting into second, go into neutral and then left and down for second - you don't have to double clutch. Once, it's warm don't bother. You can change the gearbox to synthetic lube or get a little bottle of the Ford friction modifier - this solved the problem in my last Toyota Supra Turbo.
Good Luck,
Don
Good Luck,
Don
To make you feel better, every standard I've ever owned ALWAYS did this too. 1st to 2nd was sometimes impossible in really cold weather until the car warms up. Its no big deal. Don't force it. Let the car warm up or go from 1st to 3rd.
Ryan
Ryan
rockyboy
12-06-2022 02:29 PM
Skirmich
09-15-2015 06:41 PM
