6 spd manual questions
I am used to the cable driven clutch in my cobra and know little on how the one in my TL works. A few things I’ve noticed and was wondering if I need to have anything checked.
1.) When it is cold it shifts like butter. As it warms up it still shifts fine but it gets notchy going into gear. No issue going in or popping out.
2.) I feel like there is a lot of play in the shifter once in gear. I’m used to aftermarket short throws. I can wiggle it left to right but I haven’t tested how far since I’m not trying to mess with it while driving.
3.) When I try to get on it and pop the clutch quail between gears and then I go to drive normal afterwards, sometimes the clutch grabs right off the floor but then after a few shifts goes back to normal.
4.) I feel like it slips when trying to shift at high gears but the rpms don’t jump around. I’m guessing it’s that solenoid or valve that I read a lot removed. Just wondering. I have no intentions of removing it. It’s a daily driver work car. Just trying to understand it all.
Thank You
Thank You
Lots of folks have has great luck with using GM Synchromesh Friction Modified Manual Trans fluid to get rid of the notchy feeling. It also sounds like there might be air in the system that needs to be bleed.
DMZ (02-06-2020)
From what I read I thought the GMFMSM was used more for not wanting to go into gear or popping out of gear. Also lots said it shifted worse when cold. Mine shifts great when cold.
1. get the gm friction modified fluid in asap. i started to switch mine out at 30k miles and it's all i've ever used.
2. you're never going to have normal shifts with the delay valve in the slave. take it out, it takes about 15 minutes and a bleeding procedure to get done. makes a big change
3. buy the hybrid racing shifter bushings that heeltoe offers, they help reduce that slop
4. the clutch set is a self adjusting clutch, so the grab point is never the same. i personally hate it but i love the car. i constantly debate going oem again vs xlr8 aftermarket when it's time to change mine
ultimate 6mt mod list that you could do (i've done them all):
- check valve delete in slave
- ss line
- shifter bushings
- comptech short shifter
- heavy shift knob
- friction modified fluid
- ss line
- shifter bushings
- heavy shift knob
The following 3 users liked this post by sockr1:
- ss line
- shifter bushings
- heavy shift knob
- ss line
- shifter bushings
- heavy shift knob
Latent car nut
I agree with the rest of the collective here, get ACDelco Synchromesh Friction Modified in your transmission as soon as possible. It made a world of difference in my my transmission shifted.
If the Synchromesh doesn't do the trick, then I would have the Clutch Master Cylinder and Slave Cylinder examined for proper travel.
I ordered the fluid. Found it on here: https://www.gmpartsgiant.com/parts/g...-12377916.html
I paid more for shipping then I wanted but whatever. I grabbed 3 qts. I’ll try that and look at other mods/ improvements come spring. I really want to swamp out the midpipe but can’t justify the cost for minimal gain and from what I read I believe you need to reflash it to get the real benefit.
The AC Delco Synchromesh FM is a must do maintenance. It helps with notchiness and becomes butter smooth.
As for your clutch issues, I've had that "spirited driving clutch engagement at floor" scenario for both my TLs (which went away when I did a non needed clutch job on my previous 3.2). It seems to be the aging of the pressure plate self adjusting mechanism. When you do go to push the clutch in after whatever type of driving and it is heavy, expect the clutch to engage almost immediately. It's helpful when dumping the clutch up top. Never had any other problems from that clutch "issue"
also, i removed the slave cylinder delay valve which helps pinpoint the exact engagement point. Went from "what the heck" to "never again"
AC Delco FM is a must for every MT TL, even my mechanic (20 years work on Acuras) describe it as magic fluid. Sloppy shifter can be fix with aftermarket bushing.
As far as the high RPM slip, there is nothing you could do about these car.
Remove the check valve only relieve some of the symptom, the biggest issue with the MT is rev hang (especially at high RPM). Clutch pedal will get soft after shifting at high RPM, pump it couple time and it should return to normal. I rarely full throttle MT TL as the clutch is a pain in the ass to replace. However my TL-S is different lol.
The synchromesh I ordered was not what I received. In the box I got 10-4014 or 88900399. Does anyone know if it is the same? They are saying on the paperwork that this part number replaces the other and it is obsolete.
Latent car nut
Not sure what you ordered, but ACDelco Synchromesh Friction Modified (10-4014 / 88900399) is the right stuff.
GM Part No.: 12377916
Synchromesh Transmission Fluid -Friction Modified 32Ozand I guess they sent me the ACDelco instead also I ordered 3 qts and they sent me 6 one is leaking and about 3 oz’s poured out in the box. Guess I’ll keep the extra if I ever do anything down the road
Latent car nut
I ordered :
justnspace (04-01-2020)
the new part is coming in a white bottle now, if you got the black bottle then its mean shiat wrong one lol.
So I did the slave, the GM synchro mesh, CT extension, weighted shift knob and braided line.
I hate the shifter. It wants to stick and takes more effort to get out of gear sometimes. The weighted shift knob is the one from HeelToe and is too small for my hand. I prefer the stock size over this $60 stainless one. Plus. It gets super cold and super hot.
The fluid in my system was awful and looked like mud when I removed the slave. I cleaned the whole system out and added new Honda fluid.
Overall the slave coming out help with higher RPM shifts but it didn’t fix the clutch feeling weird after high RPM shifts. It still takes a few pumps to get back to normal.
check your CMC and clutch line.
The OEM CMC knowing to have internal leak and causing all kind of weirdness. If your clutch doesn't slip and the pedal acting funny during high RPM gear change then its the only weak link left, my KBP pedal feels the same even shifting at redline.
Wait, the engagement point changes on these? I haven't noticed that with mine yet. It always seems to be near the top.
I will say I have definitely struggle to get the 1-2 shift smoothly. Sometimes 2-3 as well.
Latent car nut
There is no doubt the 3G TL 6MTs are a tad more difficult to drive smoothly compared to other cars, but it can be done with practice.
Midnight Mystery (04-02-2020)
it's a self adjusting clutch...
my buddy that I bought the car back from went through 2 clutches in 60K miles (pressure plate fingers broke off on the last one)...last one he did a month before he sold it to me and he already complained about it slipping again...I told him that's not possible, he's got to be riding the clutch putting heat into it in traffic or something. I've had the car back for 4 months now and after doing a new slave with delay removed and adjusting pedal throw to have a little play in it but to grab high...I have had NO issues with shifting or the clutch.
Also, bleeding this clutch system without a mityvac or a way to limit the tranny fork travel while bleeding makes it nearly impossible to bleed correctly. If you are getting grinding and then you pump a few times and it's smooth...you still have air in the line. I recall putting a trimmed broom handle between the back of the driver rotor and the clutch fork to keep it pressed while bleeding to get the final air out. Since then I have gotten a mityvac which did a good job of bleeding it.
About shifter feel...think about the hybrid racing bushings for the shifter linkages if you want less slop and maybe the short shift kit...for a knob, I have a titanium S2000 oem knob in both my S2000 and TL...perfect feel and doesn't get hot or cold IIRC.
Midnight Mystery (04-05-2020)
Latent car nut
If you are asking about how often the clutch engagement point changes, it is a gradual thing which changes over time as the pressure plate "self-adjusts".
^^^right...
a mistake I had to correct for my buddy as well...
not like every press will have a different feel.
I spent 15 years driving stick before getting the TL
and I could not consistently get out of 1st and 2nd
smoothly until the checkvalve was out.
I have the hybrid racing bushings too. Did e writhing at once. It never got stuck in gear until I put the CT extension on. It not likely it won’t come out, just takes more effort and it isn’t all the time. Just annoys me because that shouldn’t happen.
Russell Peters
12-05-2016 10:50 AM
403 UA6
07-16-2010 11:35 AM
