5AT Transmission Fluid
Old Jun 5, 2006 | 12:09 AM
JS + XES's Avatar
I drive a Subata.
Can someone recommend me a good brand of ATF? I'm almost 30k and need to change the fluid. . . Also, how many quarts do I have to buy?
Thank you guys in advance!! AZ forum rocks!
Old Jun 5, 2006 | 08:10 AM
SSMTL04's Avatar
Team SSM
A lot of people recommend using Honda's ATF. Quart wise....i'm not sure
Old Jun 5, 2006 | 08:13 AM
SSMTL04's Avatar
Team SSM
After searching...most people seem to put in 3 quarts.
Old Jun 5, 2006 | 08:17 AM
Pure Adrenaline's Avatar
Dragging knees in
3 quarts x 3 = 9 quarts
I would stick with the Honda fluid.
Old Jun 5, 2006 | 10:09 AM
tmitch2315's Avatar
There are numerous threads on this but check the color on the dip stick and if it looks pink and clear you may only want to do one drain and fill. That refreshes whats in there and then keep an eye on it for color change. Its a bigger job than it looks and as "Pure" says should be done times 3.
Old Jun 5, 2006 | 12:24 PM
JS + XES's Avatar
I drive a Subata.
Thank you guys for replying.
So, I should get 9 quarts of Honda's ATF right?
Old Jun 5, 2006 | 01:46 PM
Ron A's Avatar
Administrator
You can get by with the one drain and the 3 quart refill, but you will be much safer and feel more protected if you do the triple drain and 3 quart refill each time.
You must drive the car on the road for at least 5 minutes after each drain to thoroughly circulate and integrate the fluids. Some people have said they just let it idle for a few minutes to save the extra work of taking it off the stands or the ramp, but when the dealer does it he drives it between fills. At least mine did.
Old Jun 5, 2006 | 02:47 PM
SodaLuvr's Avatar
Drain and fill once with either Honda ATF or Amsoil ATF. Color and Odor are irrelevant...
If you do a second service, wait until the next oil change, to allow the fluid some time to "clean."
SidhuSaaB
May 30, 2020 12:40 AM
steve
Sep 30, 2015 09:23 PM
hpfiend
Sep 27, 2015 06:59 AM
mellsonnj
Sep 24, 2015 04:42 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
