5AT on my TL-S shifts smoother with A/C on. What could be the explanation?
Hear me out; I know it doesn't make any sense, but it's definitely true for my car
If I drive with the A/C on, the upshifts and downshifts are smooth and don't give the jerky motion a lot of us experience coming to a stop, especially with the Type S.
Once I turn my A/C off, everything changes. The downshifts are more noticeable/engine braking, when coming to a stop, regardless of incline (Grade Logic) and upshifts are a little more rough.
Could anyone explain this? Is my Serpentine Belt tension a little off, or just belts in general? I'm thinking once I turn my A/C on and there's load on the drive belt (serp), it triggers something.
Any thoughts appreciated....
That's strange to hear I have a 02 tl-s and mine is the complete opposite. Rougher with a/c on otherwise smooth without it. Although we have different cars,I'd assume the same engine set up in a way
Stay Out Of the Left Lane
Received 1,241 Likes
My 08 TL-S MT is a little rougher as well. It requires a little more finesse when shifting gears.
OP did you get the AT (if your car is AT) services like 3x3 and pressure switches? The only explanation I can think of is when you turn on the A/C, clutch engage cause a smallpower loss therefore the jerk motion is less noticeable or your description as "smoother".
Hmm, yeah thanks for the explanation; I mean when I say smooth I mean It's a big difference. I don't feel it downshift or upshift at all.
yes I did 4x3 prior to changing the switches and some time it does hard shifting from 3rd to second specially when you slow down for a red light.
do 3x3, I did 5x3 just to make sure i get all the old fluid out then I change the pressure switches and now it shift much better than the new TLX 9spd AT.
SidhuSaaB
05-30-2020 12:40 AM
joflewbyu2
10-08-2015 11:16 AM
