3G TL j-series swap
I have a 3G 2005 Acura TL the car has a 6 speed manual transmission and I was wondering what j series cylinder heads or blocks are compatible with my transmission that will gain it more horsepower
the motor you have is already a solid base 258-270 hp already. Do work on the existing motor. Swap J35 heads bsis cam PNP the heads, intake manifold, runners , then full exhaust , intake flashpro and you should be pushing close to 320-330 WHP. Do some research I have owned my TL for a little over 2 yrs and I learn something new every day
All j-series heads fit....
without tuning tho, you won't gain much.... I swapped to 3.7l MDX heads but wasn't tuned and lost power |
(Post 15980981)
without tuning tho, you won't gain much.... I swapped to 3.7l MDX heads but wasn't tuned and lost power Its all about that tune. |
I would have kept the 3.7 heads, if I didn't accidentally bind the block... :tomato:
i forgot to install the tiny pin to the crank, and the crank shaft spun out of position, then my dumbass tried to start the car...locked the whole engine up! Just ended up buying a used j32 and had a mechanic swap it for $650 |
^^^ Loose power? its must be a myth...
i'm sure if you tuned the car for the extra air, you'd see gainz.
as some of you may recall, i didnt change the heads cuz i wanted too, i changed them cuz i bent valves which lead me to the 3.7l heads...which then lead to a broken block. :tomato: and that is why they call me JustonJacks |
Buy my J37 dual vtec heads & grab flashpro.. :biggrin:
Thanx for the info guys and to think Justin I told all my boys you had the recipe lol . So thats j35a8 heads and intake manifold & flash pro?
(Post 15981075)
as some of you may recall, i didnt change the heads cuz i wanted too, i changed them cuz i bent valves which lead me to the 3.7l heads...which then lead to a broken block. :tomato: and that is why they call me JustonJacks Evilvirus or wajo once said "I am suprise that car isn't on jack" LMFAO |
Jack of all trades master of none :tomato:
Originally Posted by 314_04TL
(Post 15980980)
Yeah, a J32 isn't going to make 320-330 with those mods. I'm FBO and Flashpro tuned and probably around 265 whp. Cams and head work might put me at 290 if I'm lucky. |
