3G-TL auto-trans fluid change
I'm going to tackle the automatic transmission fluid change (when the weather warms up a bit - 24 degrees now). Does anyone have photos of the plastic (or whatever) cover that needs to be moved that's in the way of the drain bolt? I've read the D.I.Y. on the process and am trying to get all my ducks in a row. Also when you change out the first batch of fluid and go on the road test, do you have to replace that plastic piece or can the car be driven without breaking anything? Any other words of wisdom from experienced trans-fluid changers? I have all the tools and am not afraid to tackle these projects as long as I've done my homework in advance. This is a great forum for support for "semi-mechanics" like myself.
I didn't drive the car between drains. I just ran the engine and shifted through the gears with the emergency brake on for several minutes at idle.
If the panel is not touching the tire (even when cornering), it probably would not hurt anything to leave it on while driving around the block as long as the one bolt is snug.
![](http://img.photobucket.com/albums/v316/xpditor/2004%20TL/UnderCarriage005.jpg)
I'm trying to remember if you leave the back fastener in and take the right one out to swing it away... I'm pretty sure that's it. You will be able to tell once you get under there. Refer to the detailed thread in the 3G Garage section.
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
