2007 TL; 60K miles; timing belt replace??
Hi guys,
Had the TL at the dealer today for service and they told me that based on age they recommended timing belt replacement.
The car has less than 60K miles on it...but they told me that if it breaks the engine is done
. What do you think.
Also, they quoted me $890 (excluding the tensor)...sound about right??
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
better than the $1200 to $1500 some people get quoted.
I wouldn't too worry about it, the belt is fine, you only have to worry about it if your car been in the extreme heat or cold weather.
Even if its just based on age, you're still 2yrs shy of that 10yr mark. The belt should last until then, but if you have any doubt about it, then you can get it replaced for your own peace of mind.
Registered Bunny
Originally Posted by Acura
Replace timing belt and inspect water pump: If you drive regularly in very high temperatures (over 110°F, 43°C), or in very low temperatures (under-20°F, -29°C), replace every 60,000 miles# (U.S.)/100,000 km (Canada)
And once again, there is no published mileage or time limit for the belt under normal conditions. It's when the MID shows a "4" with "Service Due Now".
OP, have some fun with your Service Advisor: Ask him to show you where Acura recommends/requires you to change your belt now. If he pulls up the "severe" limits as a reason, ask him how many -21F days Michigan has seen in the last 7 years
JTS97Z28 (01-16-2015)
gotta love dealer with scare tatics, I just shut my dealer up by provide them with TSB and told them what is the problem and how to correct it.
3G TL/2G MDX Owner
Coming on 10 years, only 58k mi ...only now thinking about the TB replacement solely due to age regardless of the MID telling me.
OP you have some time or when your MID tells you to do so.
3G TL/2G MDX Owner
^^considering my TL is garaged 100% of the time....i'm not necessarily in a huge rush to go off and cough up a chunk of change. if i ever reach 105K it'll be a LONG time before that happens. though it does lurk in the back of my mind (the TB replacement job). i may hit the MDX TB job before the TL gets one
Phambam12
09-05-2015 04:10 PM
