2007 side view mirrors
This thread has been moved from the Performance Parts & Modifications subforum to the proper forum.
Please read The "Modifications" in "Performance Parts & Modifications" announcement at the top of the Performance Parts & Modifications subforum for a full explanation.
^What do mirrors have to do with performance parts? Anyway, IMHO the '07 mirrors are hideous... i would just get the signal installed into the mirror if you really wanted it.
'17 RDX Tech AWD - WDP
There are threads on here that discuss mod'ding the front side marker to be a blinker. IMHO, that's a much cleaner look, with the same effect. Also, it appears to be a much simpler install, and likely a MUCH lower cost. Plus, you can take pride in saying "I did it myself" still.
Yes they are compatible and simple to install. They will directly fit the 06 mounting location. The harness connections are the same on the 06 to the 07 with the exception of a pink/brown wire on the 07 mirror. That will be the wire you connect the wire from the front sidemarker Light. Please note: when I installed my drivers side mirror it was a plug and play application no need for a wire to the mirror from the sidemarker do not know why however if it works why mess with it.
BoricuaTL
04-08-2016 01:08 PM
dre707
09-08-2015 08:32 PM
