2005 versus 2007 through 2008
OK, I have a dumb question, but searching for the answer is difficult.
I am looking at used TL's. I like the 2007/2008 TL-S but it's pricey. I noticed that if I just want a V6-6 Seday, the 2005's and 2006's are MUCH cheaper.
Here's the question. The HP spec for the 2005 is HIGHER?
Same RPM, same compression, same bore x stroke. What am I missing? Did they make a change that helps low end torque? Or did they do something in 2006 due to emissions that reduced power?
LasVegasTL (07-11-2011)
Sorry, been drinking and put wrong title.
2005 versus 2006. The 2007 and 2008 TLS are a 3.5 Litre, totally different engine.
2005 and 2006 are same dimensional specs on a 3.2 but HP and Tq are different. So the question is about them. Apologies to all.
OK, been drinking. I realize the TLS is a 3.5L. Sorry, i'm stupid.
OK, the question is about the 2005 versus 2006. Apologies to all, this is all my fault.
I don't remember that happening, but basically between 2005 and 2006 everything in reality is the same? Just test numbers? Seems like a pretty big difference.
https://acurazine.com/forums/3g-tl-2004-2008-93/sae-new-horsepower-rating-system-3g-garage-a083-589568/
From the 3G Service Department.
Would love a Type-S, but I am not sure they are worth the money. They are pretty rare and when someone has one, they list for well over KBB.
I can get a 2006 TL 6MT for like 18K, but a 2007 Type-S 6MT is more like 26K or 27K either with around 35k-40k MILES. Having a hard time justifying 7 or 8 thousand dollars differencs for one year newer with betters springs and swaybars.
And nope, not working this week, vacationing in UP Michigan.
The fogs in the lower grills were introduced in MY 07. The 06 still had the fogs integrated in the headlight housing.
Many prefer no TPMS and consider not having it a feature. I have a tire pressure gauge and know how to use it. If you live somewhere that it's beneficial to have a winter set of wheels and tires it's better not to have TPMS unless it's auto-learning, but I don't think Acura's is? Else you end up with a flashing indicator on your dash that lets you know you are running your winter setup. Unless you have a friend that has the scan and program tool.
B A N N E D
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
So far as i know apart from performance the 07-08 TLs also have the auxiliary input for mp3 players, and the opt backup camera and some cosmetic changes like taillights and the grille size/bumper so I think those are some things to keep in mind. Aux in 04-06 can cost upwards of 150 (USA spec makes one specifically for Acura/Honda) and that backup camera is of course pretty useful. I assume performance will be nearly identical Acura wouldn't have made a mid cycle refresh with a drastic performance change (except for the Type S)
Thanks all. I appreciate all the info.
I find out, hopefully tomorrow, if I need to start shopping for another car.
If I do, I will try for a TL-s (stronger engine, better suspension) but if they keep going for 27K I think I will save the bucks and grab a low mileage 06 that comes up for sale.
B A N N E D
but now the engine, yeah.... that's not going to come exactly cheap...., so better normally to start with a stronger engine
MetalGearTypeS
08-29-2016 08:28 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
