2005 TL maintenance minder question
Old Feb 2, 2011 | 11:12 PM
columbusjack's Avatar
3rd Gear
Hi Guys,
I am new to this forum, though I have viewed several threads on it already courtesy of the google search! I own a 2005 TL, which I bought used in 2007. It had around 41,000miles on it. For whatever reason, I got suckered into buying a 50,000 mile free oil change plan with the Toyota dealer who sold me the Acura.
The oil changes were at 5000 miles and would occur before the maintenance minder oil life went down below 20%. The Toyota mechanics would reset the maintenance minder after the oil change. As a result, I never saw the "service due" code.
I was recently trying to find out what maintenance was due on my TL, only to find out that maintenance minder is the only way to tell what needs to be done. The local Acura dealer won't give me a straight answer and keeps referring back to the maintenance minder.
I am at 77000 miles now and really worried that I could have missed some important services on my car. Is there a way to find out what I could have missed? I am thinking of getting the auto transmission fluid, air filter and AC filter changed ASAP.
My normal commute is 10 mile drive to work most of which is at 45-60 mph speeds. I would consider my car to have been driven under normal conditions.
Any advise you guys can provide would be really appreciated!
Thanks!
Jack
Old Feb 2, 2011 | 11:50 PM
B-R-94's Avatar
Wants a TL. Stuck with a
I think they should have replaced or cleaned the air filter when they did the oil change.
But if you can't get a straight answer I would definitely just change it all. Better spend the money on that than to run into more expensive issues later.
Old Feb 3, 2011 | 01:18 AM
Will Y.'s Avatar
Registered but harmless
Do the transmission fluid and the filters-- those were codes 3 and 2. Code 1 is an oil & filter change, and probably comes up every 7K-9K miles.
Code 4 probably won't occur until the car gets over 100K-- timing belt, spark plugs.
The owner's manual notes that the owner should change/flush the brake fluid every 3 years, regardless of mileage, and has the maintenance minder codes.
Welcome to AZ.
Old Feb 3, 2011 | 09:34 PM
3rd Gear
Thanks a lot for your responses!!! I will get the pending stuff done. Looks like the battery might need to be replaced as well.
Old Feb 8, 2011 | 12:07 PM
triax37's Avatar
This thread discussing services at different mileages (instead of just relying on the car's computer) might be helpful -
https://acurazine.com/forums/3g-tl-2004-2008-93/service-schedule-b-1-2-3-4-5-what-mileage-s-800173/
Old Mar 1, 2011 | 10:07 PM
3rd Gear
https://acurazine.com/forums/showthread.php?t=800173
Thanks a lot! That is of a lot of help!
Yikes
May 3, 2021 04:29 PM
Legend2TL
Nov 20, 2015 07:31 PM
handsom-hustla
Nov 13, 2015 05:04 PM
datadr
Sep 12, 2015 09:12 PM
MyGuti
Sep 12, 2015 06:52 PM
