Is a 2004 TL CAN Compliant?
Many Ford, Chrysler, and GM vehicles started implementing Controller Area Network (CAN) communications in 2004. As new vehicles are introduced, most are CAN compliant. As a result, you have some vehicles in 2004, many more in 2005-2006, most 2007s, and finally by 2008 ALL vehicles sold in the US must be CAN compliant.
What does the "Controller Area Network" do?
NVM Just did a google search and I got this result
" Abbreviated CAN, a serial bus network of microcontrollers that connects devices, sensors and actuators in a system or sub-system for real-time control applications. There is no addressing scheme used in controller area networks, as in the sense of conventional addressing in networks (such as Ethernet). Rather, messages are broadcast to all the nodes in the network using an identifier unique to the network. Based on the identifier, the individual nodes decide whether or not to process the message and also determine the priority of the message in terms of competition for bus access. This method allows for uninterrupted transmission when a collision is detected, unlike Ethernets that will stop transmission upon collision detection.
Controller area networks were first developed for use in automobiles. Equipped with an array of sensors, the network is able to monitor the systems that the automobile depends on to run properly and safely. Beyond automobiles, controller area networks can be used as an embedded communication system for microcontrollers as well as an open communication system for intelligent devices.
The controller area network, first developed by Robert Bosch in 1986, is documented in ISO 11898 (for applications up to 1 Mbps) and ISO 11519 (for applications up to 125 Kbps). "
Umm, yeah it does?! I mean when you get a CEL or some other alert, hook up an OBDII Code Scanner, and tells you what the problem is.
MrHeeltoe
20
02-23-2023 01:54 PM
GWEEDOspeedo
01-15-2016 10:39 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
TLguy42
09-26-2015 11:27 AM
