A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
#121
Hopefully it just needs a valve adjustment.. worst case is bent valve/s or blown rings.
btw.. what was the actual pressure readings on all cyls?
#122
Interesting. How does an engine that's seems to be running fine suddenly lose compression in one cylinder after a TB change?
Maybe the belt was indeed off after the first attempt and you bent a valve?
#123
takin care of Business in
Received 4,732 Likes
now u guys know why i didnt do this on my own
#124
Nothing's been proved yet, I'm just speculating trying to figure out what happened.
#125
contemplating future mods
Great write up. Thank you for taking the time out to do this for the community. Not sure if I will be able to tackle this one by myself... If I do, I still have another 60K miles to go before I make up my mind...
#126
Hmm, I'll know more today I have to go talk with the guy working on the car.
If the timing was indeed off it was not more than a tooth. That said I really would caution against doing this yourself as there seems to be VERY LITTLE room for error.
JD TL-S (03-19-2015)
#128
http://www.acurapartswarehouse.com/P...gPicture=False
#129
I would opt for the P/N: 14550-RCA-A01 since it's the current part being sold by Acura dealers. Sometimes with an updated design or change in mfg of the component, they'll revise the P/N.
Auto Tensioner: 14520-RCA-A01
Adjuster: 14510-RCA-A01
Idler Pulley: 14550-RCA-A01
#131
https://acurazine.com/forums/vendor_directory.php
#133
I think Prestige has that timing belt kit special.. they might even do a special on the associated parts!
#134
https://acurazine.com/forums/3g-tl-2004-2008-93/complete-timing-belt-kit-special-%24295-763445/
#135
On picture #4 it looks like you had busted passenger side motor mount. How did your front and rear motor mounts look??
#137
my side mount is toast.. so I'm pretty sure my front mount has taken a beating. No knock or symptoms of front mount compromise though. No symptoms of a bad rear mount as well. I'm contemplating layering some window weld as a fix. Side mount is cheap but I know sooner or later it'll fail again.
I bought all the parts from MisterFubar.. He sold his TL and had a great deal in the blackmarket on these parts. The retail on the parts I bought from him are in the 350-450 range. This was a full kit so if you buy the kit special from prestige, you'll need to add on the add'l items not included.
#140
My side mount has a 1 hairline crack and of course the dealer is going to replace that under warranty but, when I had asked about the front motor mounts as well as the rear they said they were all fine including the transmission mounts. I can see the transmission and maybe a rear being ok but the front ones being ok sounds impossible being that the side passenger mount has a hair line crack. Could that be possible just that one on side while the rest is fine???
#141
#142
www.colradodetail.com
Majofo,
been searching around and wanted to know your thoughts on the 60k service? Minus inspection of parts and fluids, replace spark plugs, filters, anything else i should look into doing?
Thanks for your input... and great right ups!
#143
Dreading having to pay hundreds for a shop to do this.
It looks pretty easy for the first 6-7 steps... I can get the tools... but by step 9-10 it started getting beyond my ability. By step 30-35 I knew I would gladly be paying someone hundreds of dollars to NOT mess up the wife's car! Too many things could go wrong with me doing it alone.
Great Detailed Post! Saved me thousands (probably)
#145
ScoobyZINE
Well Majo, tomorrow is the big day for me. Have all my parts laying out in the garage, car on stands, right front wheel off. Still debating if I should pick up the hex tool to help remove the CP or not.. Not sure if the impact can break it loose I'll probably pick one up to be safe.
Oh yeah, I'm expecting a lightweight pulley to come via FedEx tomorrow to replace the boat anchor stock CP
#146
ScoobyZINE
Completed this last night. Started around 6 and finished at 11, and that includes cleaning. I had a friend helping so that cut a lot of time out.
The hardest part is removing the dang timing covers, after that it's a piece of cake.
I'll be checking the valves next weekend. Thanks again Majo!
#147
Take any pics?
#148
#150
Sweet Lord in Heaven OP!!! NICE JOB on the writeup!
I didn't see a write-up before but now that I have pictures to guide me through I think I'll set aside a weekend and do it.
This is why I love AcuraZine!!!
BTW: I replaced my spark-plugs ~75k miles and I'm at ~105k now. Should I change the plugs again when doing this? IIRC the plugs that I got (which were like a mid-grade quality) should last for a pretty long time.
#151
Very impressive in the detail of the write up! I am a tad confused on the logic of replacing the water pump (assuming it is not leaking). Is it the hassle of the timing belt so you might as well replace it (along with the thermostat) during the same job?
#152
ScoobyZINE
Yes ^^ Might as well replace the water pump the first time instead of going back in the motor later, right?
Here's the only picture I took.
Majo, I got a funny noise this morning coming from the belt area that sounds like something is loose. I did install an aftermarket lightweight CP and I verified earlier that it is tight. The sound just started this morning and I did my TB Saturday. I'm thinking/hoping it's the serpentine tensioner. EVERYTHING behind the timing covers was replaced for the timing belt job. Any advice on troubleshooting before I buy the part?
#153
#155
Imagine trying to remove the front cover without removing the serpentine belt tensioner like I attempted. The service manual didn't state the removal so I didn't. Needless to say I ripped that page out of the service manual and wiped my ass with it.
No.. So if you go to the dealership, make sure they itemize everything replaced here and make sure they give you all the old parts.
#157
See! If I attempted this job by myself, THIS is what would happen...
Then I'd be in the doghouse with the wifeypoo for months!
to the Stealership I go... with money in hand.
If they screw it up, They can fix it again!
#158
ScoobyZINE
^^^ It's really not that bad lol It was my first time changing one on a car. The serpentine tensioner is just something that wears out on a vehicle over time. Whadda ya expect? I can't complain, I've never had any problems out of the car so I don't mind to replace the tensioner lol
#159
AMU...Did the impact wrench work or did you have to use the hex tool? What were the specs on the wrench?
#160
ScoobyZINE
I definitely had to use the hex tool. I rented it from O'Reiley just in case. The impact with 130 lbs of air pushing it wouldn't budge it lol It's a Craftsman impact, not sure of the model. Definitely not their biggest but not their smallest either
Had to use a breaker bar and the hex tool to remove it though. Once you get over the initial "pop," it's all over but the cryin' lol
