A-122: DIY - 105k Service: Timing Belt, Water Pump, Spark Plugs, Thermostat *PICS*
#43
Ah, you're better off...you're not getting raped by the high cost of everything we New Joiseians face, anyway...but if you were up here in October of next year that would be all too spectacular
This is seriously my fav thread on AZine...awesome DIY in such a critical area, well written, saves people a boatload of cash, I could go on...
I am going to spend a good amount of time studying this and try to find someone that can lend a hand in doing this (to ensure I'm doing it right), but there's no way I am paying for the service at the dealer after reading this. Not to mention, I am sure the same level of detail you're following would not have been at the dealer...
Again, this really is awesome stuff...thanks for all the pics and detailed write up!!!
Any idea when you're going to be getting the ported components in?
JD TL-S (03-04-2015)
#44
I need to talk to Paul (NVA-AV6) about it before pulling the trigger on some new valvetrain components. That, plus I'm getting married next year.. so.. it'll either be this winter.. or next winter.. lol.
Rommel (02-05-2020)
#50
#54
Excellent write-up! I'm about 30k miles away from this and was trying to to figure whether I should do it myself or not. After this write-up, I'm definitely going to tackle it.
Thanks!
Thanks!
JD TL-S (03-19-2015)
#56
Dude, I have to say thank you. I have a lot of respect for someone that takes that much time to make a detailed DIY to help people out. This should definitely go into the garage.
It did something else for me, it confirmed that although I have a lot of confidence with tinkering....I will be paying someone to do this for me.
#57
#58
I think the crank pulley bolt removal is the hardest part of the entire job. It can look intimidating, but it's pretty straight forward once you get into it. If it's your first time be prepared to spend up to 8hrs to replace the TB.
#62
im at 104k now and im still debating wether i should do it myself? i am not a total noob when it comes to mechanics but im not pro either. it looks like ill be doing it my self. and also where can i get the gates belts and waterpump you guys talk about in this thread?
#64
And if you're not 100% certain about being able to do the job yourself, bit the $$$ bullet and let an experienced professional handle it.
#65
At what mileage (if at all) did you get the "4" and "Service due soon" message?
At what mileage did the message change to "Service due now"?
Thanks!
#66
Someone has posted a link where you can get the tool. I think it might have been in mmade's 100K thread, not sure.
#67
http://www.amazon.com/Powerbuilt-648...3798023&sr=8-1
#68
Thanks for sharing! Awesome!
What is the saving, in dollar, of doing it yourself vs. having the stealership does it for you? I don't think I have the skill to do this, but want to just because I like doing things myself. It's a quality control issue with me.
#69
I agree with the quality control issue. I like doing things myself so I know it was done right. Of course not everyone is capable of "doing it right" themselves, and I can definitely understand that. For some reason my brain stays really organized with this sort of thing...
Another nice thing is that you have the option to pick and choose what you want to replace. Since you can always do it again yourself for free, you can forgo changing "preventative maintenance" items like idler pulleys or even the water pump that could always last another 100k miles. You can wait till these items actually experience failure because they tend to be noisy and semi obvious when they do. Personally I replaced everything except the idler and tensioner pulleys when I did one of these V6 motors.
#70
If it takes that much force to loosen, then how did you apply the same force when you re-installed it? Torque wrench?
#71
The moisture, dirt, thermal and mechanical stress the CP bolt is subjected to for 100K miles makes the breaking torque somewhere > 600 ft.lbs (maybe more like 800 ft.lbs to be honest). The spec torque to reapply the bolt is 181 ft.lbs. Big difference.
#72
What do you know.. it happened after I posted.
~106.7K - Due Soon
~107.5K - Due Now
so somewhere between 0.8k - 1k miles.
#73
Mojofo (or anyone else): Know anyone in the San Francisco Bay Area that can do a good job with this service? I'm torn between letting the dealer do it, but possibly getting some things done "not so well", and definitely paying up the a$$. I don't think I have the mental fortitude or mechanical know-how to attack this one. Even if I tried, I think there's a good possibility I might f this up.
I think the only thing I may do myself is the spark plugs...
#75
Doing the plugs alone saves you ~$200.
I know people in the bay area but none of them are mechanically inclined unfortunately. Give a shout out in the regions section, I'm sure those guys will point you in the right direction. Shop around as well.. this DIY is still a good guide for those letting the shop do it so you know exactly what needs to be done. At your miles I would wait it out and find the best deal in the mean time. A decent quote will be around ~$700 all inclusive - valve adj & plugs. Anything lower than that is an excellent deal.
Call around and inquire about the labor price alone, ask if they'll do it if you bring in the parts. Also request the old parts be put in a box in your trunk when you pick it up so you verify everything was installed. I know Acura dealerships will only use OE parts but you still save a huge margin on OE parts bought online. The in house price sometimes carries a ridiculous margin.
#77
They're OE spec'd plugs so it's not necessary to change the gap. The actual spec is 0.039 - 0.044" or 1.0 - 1.1mm.
#78
Yeah, on the Iridiums, don't try to gap them yourself. You can check the gap, but if it's off, take them back and get another set/plug.
and the 04 service manual lists the gap as 1.0-1.1 mm or 0.039"-0.043".
Wonder why/if the gap spec changed between 04 and 05?
#79
Ok, I'm stumped. I just did this service on an 05 TL. Infact I did the timing belt TWICE now because I thought maybe the timing was off.
Basically the car idles a little rough, Cel (I'm assuming its a cel, picture of a motor) will either come on and flash for a few seconds or so and then go away or stay solid.
I've done, the Thermostat, Plugs, Timing Belt, Serpentine belt, Water Pump, and all tensioners (on the timing belt). I've went back to the old plugs just in case there was an issue with the new ones...
I have not pulled the code as I'm worried about driving the car to autozone.
I've attached a pic of the front cam as it is now. Is this correct? Is it off by a tooth? I've done this twice now I dont see how to get it any tighter on that cam.
I havnt slept in awhile so maybe the CP isnt EXACTLY on the arrow when I took the pic but I think it is....
Any thoughts?
Any thoughts?
