A-110(a): DIY Guide to replacing 3rd & 4th gear pressure switch for 3G TL (2004-2006)
Old Dec 13, 2010 | 09:36 PM
  #161
I hate cars's Avatar
Originally Posted by jdm_94-07TypeS
My 07 TL-S has 103K.The tranny is OK but really I don't know what transmission fluid has in it. What fluid guys can recommend me for a tranny with high mileage?
You've gotten the exact same answers in several of your threads.
Old Dec 14, 2010 | 09:17 AM
  #162
The-Chemist's Avatar
Ordered mine today and will put them in this weekend along with the filter and the 3rd 3x3 flush. Im at 60k and have not had any tranny trouble and would like to keep it that way. After reading the racing fluid threads I think I will try that at the next flush, but for now, I will stick with Dexron b/c I've already done 2x3 with it.
A big thanks to IHC and OP for doing the leg work on these switches. Posts like these make an amateur like me look like a pro doing the work.
Old Dec 19, 2010 | 08:03 AM
  #163
As a followup, I changed these out yesterday along with the tranny filter and 3rd 3x3. the shift quality from 3rd to 2nd has improved a lot. the rest of the gears is a slight improvement but an improvement none the less. I would do this $70 preventative any day of the week to help the longevity of a 4k transmission.
Old Dec 22, 2010 | 12:20 PM
  #164
smokyadam's Avatar
Got antsy and had a local mechanic do a 3x3 with 2 qt Redline Racing 1qt light racing and change the 3rd and 4th pressure switches. I have only limited time driving it since, but I can instantly tell a difference when going from Park to Drive- The shifts are much quicker but like has been said before- not harsh- I look forward to driving more and will report on findings. I have owned my TL for about 3 weeks and was disappointed with the trans performance right off- I did have Acura do a full 3x3 Z1 before I Joined about 15 days ago. I did not have issues just some lazy shifts at times. Thanks to IHC and Inaccurate and others for doing the leg work on this issue.
Old Dec 25, 2010 | 11:22 AM
  #165
DUHockey9's Avatar
I plan on doing the sensor switches and Redline Racing ATF changes sometime soon. I plan to do the 3X3 ATF change but over a week or two, so that I'm sure to drive through all the gears (I don't drive all that much honestly). Maybe this is a silly question, but does it matter if I do the sensor switches change before/during/after the ATF fluid changes?
Old Dec 25, 2010 | 12:39 PM
  #166
duffduffxx's Avatar
Does anyone know if this would work for the 2nd gen TL's?
Old Dec 25, 2010 | 12:42 PM
  #167
Yes. I can't remeber the thread title but you can do a search of my username where I reviewed it.
I did a '99 that was on it's way to the junkyard. It had the worst flare I've ever seen between 2-3 and 3-4. I was worried it would not be fixable. Between the Type F fluid and the switches it shifts better than new. Unbelievable. There are many more details in my other post.
Old Dec 25, 2010 | 12:46 PM
  #168
duffduffxx's Avatar
Thanks! I have to admit, the info "other thread" was on the page right before! Thank you so much!
Old Dec 26, 2010 | 01:26 PM
  #169
SQAcuraTL04's Avatar
I just did this today, and the install wasn't bad at all. I can attest to the fact that there is a noticeable difference in shifting in my 90k miles TL. Unfortunately I can't test it to the max because of the snow we are having in the tri-state area. :-(
Old Dec 26, 2010 | 05:08 PM
  #170
DUHockey9's Avatar
Could anyone answer the bolded for me? Thanks in advance.
Old Dec 26, 2010 | 10:00 PM
  #171
sddale's Avatar
No it doesn't matter the order. Mine were changed between drain and fills.
Old Jan 12, 2011 | 12:34 PM
  #172
04TLVTEC's Avatar
Materials needed:
x1 3rd Gear Pressure Switch (28600-P7Z-003)
x1 4th Gear Pressure Switch (28600-P7W-003)
x2 sealing gasket (90471-PW7-A00)
x1 brake cleaner (to wash away residual AT fluid)
Just to clarify. According to the above which was taken from the OP, is that all I need to do the pressure switch correctly? What about second, fifth, and reverse gears?
Old Jan 12, 2011 | 02:51 PM
  #173
dynodog's Avatar
Hmmmm.... I've been doing some research and came across something interesting with regards to the pressure sensors on the 07-08 transmissions.
In post #16 of this thread, Majofo posted some great diagrams and pointed out for us that the 07-08's have two 3rd clutch sensors.
Based on what I am seeing in the s/m, though, it appears that instead of there being two 3rd clutch sensors, one of those is actually the 2nd clutch sensor. This is the one located at the upper rear (and pointing aft) of the trans.
The pg 14-244 of the 08 s/m even has the procedure that is entitled:
2nd Clutch Transmission Fluid Pressure Switch Replacement
I realize that this doesn't change much with regards to the benefits of replacing these little buggers, but I hoped that it might be useful to know that one of was actually for the 2nd clutch.
Old Feb 10, 2011 | 02:03 AM
  #174
paperboy42190's Avatar
i just got an 07 tl-s. i dont notice anything wrong with the tranny, all the shifts are just fine, should i do this pressure switch just as a precaution?
+1
Old Feb 18, 2011 | 08:16 PM
  #175
Bearcat94's Avatar
AZ Community Team
+1
Thats the idea.
I've got a maint interval coming up (20% as of today) and plan to do mine. Mileage will be ~50,000 miles.
Old Feb 26, 2011 | 01:42 PM
  #176
samplemonster's Avatar
Took it to my local bodyshop, the mechanic did not know what to make of the pictures, and I couldn't either. I honestly can't or have the means to change the oil so I am a complete undeveloped in terms of knowing cars. Would someone in LA area help me out with this if you have a jack? I will try to cover for your time. Send me a pm, thanks.
Also, when I do figure it out, I'll make a completely idiot free guide with pictures step by step (zoomed out to zoomed in) on how to do this so others who are also new at this can benefit.
Old Feb 27, 2011 | 02:13 PM
  #177
DUHockey9's Avatar
I'm currently in the middle of my 3X3 and I was looking around while I was under there for the pressure switches (as I will be doing them very soon). I had a hard time finding them though. Could somebody be so kind as to tell me where they are in relation to, let's say the drain bolt for the ATF, or perhaps oil? For the sake of argument, let's say while facing the front bumper.
Thanks in advance.
Old Feb 27, 2011 | 03:29 PM
  #178
Thanks in advance.
Side of the trans facing the driver's wheel well. You don't have to jack it up or remove the tire. Just turn it all the way to the left and the switches are exposed in the wheel well. One of them is under a plastic cover. It's actually the rear of the trans but since it's turned sideways I call it the side.
Old Feb 27, 2011 | 06:26 PM
  #179
DUHockey9's Avatar
Awesome, thanks a lot ihc!
Old Feb 28, 2011 | 09:58 PM
  #180
Shinoda's Avatar
Who has the best price for the switches?
Old Mar 13, 2011 | 05:09 PM
  #181
just read through every post on this thread. no one has done it on 07-08 TL yet -_-
i just want to know how much more work it is to do it on my 07 tl-s because i think there was a post about how its blocked by some stuff that i gotta remove.
Old Mar 13, 2011 | 11:51 PM
  #182
binTL's Avatar
Crap, changed the switches today but forgot the gaskets in my hurry to finish the job before the rain. Now i need to redo them. Ugghhh. Is it safe to drive that way?
Old Mar 14, 2011 | 07:25 AM
  #183
No gaskets at all or you reused the old ones? Reusing the old ones is fine. No gasket will leak over time.
Old Mar 14, 2011 | 03:13 PM
  #184
binTL's Avatar
No gaskets. Overlooked it when i installed the new switches. Anyways, I am driving it for my commute today but will redo them tonight with new gaskets. Hope the switches are not damaged.
Old Mar 28, 2011 | 02:37 PM
  #185
vietxquangstah's Avatar
i've read through this whole thread and saw majofos post about the 2007-2008 TL's having 1 extra switch.
unfortunately the pictures he posted are expired so i can't see the part number.
can someone verify the 3rd and 4th gear pressure switches PART # for a 2008 BASE TL for me?
i'm assuming the gaskets should be same as the ones mentioned in the first post.
Old Mar 28, 2011 | 07:18 PM
  #186
JDM RICe's Avatar
To all who is interested in the complexity of the 07-08 models, I would say that this DIY does not apply. All sensors are in totally different locations
1 sensor is underneath the motor mount bracket as previously stated. You'll have to remove the stock intake airbox to access it.
1 sensor is underneath the throttle body. It sits on top of the tranny on the back side. The connector points towards the firewall. Access is very tight, at least for me. If you have child hands, this should be a walk in the park..lol I broke the sensor upon removal, so be careful!
The last sensor is on the bottom of the tranny. If you can find the VIN# plate on the tranny, it is just above it. The connector to the sensor points to the driver's side wheel. Access to it is tricky, you have to enter from the side where the fender well splash guard. You have to use a long socket and 10" extension
I took pictures, so hopefully I'll be able to update and contribute to this thread.
It took me about 2.5 hrs to change all 3 sensors. I probably spent an hour of that, easy, just trying to locate the sensors because I do not have an FSM. I simply took my time to ensure I got good pictures and changed the correct sensors...
Now that I know what's involved, it should be an hour job.
I can't say I noticed any improvement, maybe slightly. Like most, I'm doing this as preventative maintenance. Redline Racing ATF is coming up this week
I'll follow up with pix as soon as I can. I'm having issues with my SD card, so hopefully the pictures are not corrupt.
Old Mar 29, 2011 | 02:13 PM
  #187
dc5k20z1's Avatar
cool cant wait, provide all 3 switch part numbers if you have it. also the tranny filter part number...
Old Mar 29, 2011 | 02:19 PM
  #188
~Lefty~'s Avatar
Plus 1^ If somebody wouldn't mind to post up part number's I'd like to do this on my TL-S.
Old Mar 29, 2011 | 02:25 PM
  #189
dc5k20z1's Avatar
hmmm i think this will help confirm for some on 07-08 TL Base 5AT
#13 and #14, notice #13 is used twice and #14 is used once
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Filter, #1
Old Mar 29, 2011 | 03:08 PM
  #190
JDM RICe's Avatar
http://www.acuraoemparts.com/delray/jsp/prddisplay.jsp?inputstate=5&catcgry1=TL&catcgry2=2 008&catcgry3=4DR+BASE+(NAVIGATION)&catcgry5=AT%2BS ENSOR%2B-%2BSOLENOID&ListAll=All&vinsrch=no
that diagram confirms my install
Old Mar 29, 2011 | 06:42 PM
  #191
Jesstzn's Avatar
In another thread someone said you can clean those 2 switches.
Has anyone done this .. and with success?
Do the switches fail because the get clogged with crap or is it another reason?
Old Mar 29, 2011 | 07:00 PM
  #192
The 2nd gen guys thought this but that's not the case. The diaphragm hardens over time and throws the calibration out of whack.
Old Mar 29, 2011 | 07:23 PM
  #193
Jesstzn's Avatar
Could you look at this link .. it shows item 12 & 13 as different part numbers for the switches ..
TYIA
Old Apr 2, 2011 | 01:28 PM
  #194
DUHockey9's Avatar
I just replaced my 3rd and 4th gear switches and it was super easy. The hardest part for me was 1) locating the shroud covering the 3rd gear (I was expecting some large plastic covering, like in the wheel well or something) and 2)unplugging the one cable
I decided to take a few pictures for everyone. I know I had a little bit of trouble following some of the other pictures.
06 TL.
I jacked my car up and removed the wheel just because I could, and I thought I'd make it easy on myself. I thought I'd take a wide shot so everyone could see where these switches are in relation to the wheel well. I know it took me some time to locate it because I'm a noob and had NO IDEA what I was looking for. Also when I read about needing to remove a "shroud" i was picturing something bigger like in the wheel well, or perhaps like the plastic covering you have to remove to drain the ATF. I also removed part of the plastic in the wheel well for some extra room. It's not necessary but only required 1 clip.
Here you can see the plastic piece I moved out of the way, and the general location of the 3rd and 4th switch. The 4th switch is just out in the open. The 3rd is covered in a hard plastic covering (the "shroud").
Here is a closer view, from within the wheel well. Again you can see the 4th switch and the 3rd, with the 3rd being covered in the shroud. I've also noted the 2 bolts and the cable you will need to unplug in order to swing the shroud out of the way.
Closer view of the 3rd switch and the shroud. You can see the 2 bolts I removed, and the cable that needs to be unplugged. This was the hardest/most annoying part for me. There is a button to hit to pull the top half up and off. I used a small flathead to help me pry it up as I pushed the button. Then there is a slot in the bottom of the plug that I stuck the flathead in and pushed in (towards the back of the car), in order to pull the bottom part of the plug off of the metal clip. Once the cable is unplugged, and the 2 bolts removed, the shroud will swing away revealing the 3rd switch.
There is a plug going into each switch that you have to remove. Here you can see the shroud swung away revealing the 3rd switch. The plug is still attached to the 3rd switch. You can also see the 4th switch where I have already removed the plug.
At this point it's a piece of cake. Remove plugs. Loosen switches with a wrench. Remove by hand. Have the new switches ready to minimize ATF leakage. Tighten by hand, and then a bit more with the wrench.
Old Apr 4, 2011 | 07:36 PM
  #195
JDM RICe's Avatar
**I couldn't edit my original post, so I'm C/P and updating the post with pictures**
Ok here goes....
1 of the sensors is underneath the motor mount bracket as previously stated. You'll have to remove the stock intake airbox to access it.
Another sensor is underneath the throttle body. It sits on top of the tranny on the back side. The connector points towards the firewall. Access is very tight, at least for me. If you have child hands, this should be a walk in the park..lol I broke the sensor upon removal, so be careful!
Another angle of it
Good Luck
Old Apr 4, 2011 | 10:15 PM
  #196
kevinballer08's Avatar
05 AM TL
Great posts.
Old Apr 10, 2011 | 07:37 PM
  #197
CubanLynx84's Avatar
under renovations....
Yeah I saw that in my s/m too. now I'm wondereing if I got the right parts or if the 3rd gear switch is the same for that 2nd gear one. And I know us 5AT got differences between the years but is there a difference between the base and the type-s, cause I have a type-s.
Old Apr 10, 2011 | 10:34 PM
  #198
liono's Avatar
Another satisfied person. Changed the 3/4th switch today and made a world of a difference. I've grown so used to the sloppiness of the transmission that I was expecting it and it was completly gone after the change. Thanks OP for the writeup.
Old Apr 11, 2011 | 06:51 PM
  #199
Tango Lima's Avatar
Done. Damn that was easy, I am glad I found this post. I immediately noticed a difference, nice and smooth. Makes me wish even more that there was an AcuraZine mobile app.
Old Apr 11, 2011 | 07:19 PM
  #200
Carlito Benito's Avatar
I fixed the glitch
I did it this weekend as well. I pulled out the DSLR and took some clearer, closer pics for those who might be wondering what to look for.
The harness you need to unbolt to get to 3rd gear switch. You can see the 4th gear clearly marked:
