A-110(b): DIY Guide to replacing 3rd & 4th gear pressure switch for 3G TL (2007-2008)
#121
BANNED
how many times can we repeat the same thing?
Project 04TL (03-08-2013)
#125
You need:
2 x 28600-RKE-004
1 x 28610-RKE-004
3 x 90471-PW7-A0
For those that have not done this the connectors for the switches are color coded. It is very difficult to make a mistake.
But what the hell do I know? I just hope we don't waste the next 2 pages arguing something that doesn't seem to matter.
#126
takin care of Business in
Received 4,732 Likes
I just did the switches on a Type S using the part#'s posted by RAVI and they color code and everything matched spot on....
People need to STFU and just following simple damn instructions !!!
JCash23 (06-25-2022)
#128
according to the book, for a 07 base you need the following:
(2) 28600-RKE-004
(1) 28610-RKE-004
(3) 90471-PW7-A00
http://www.acuraoemparts.com/delray/...All&vinsrch=no
(2) 28600-RKE-004
(1) 28610-RKE-004
(3) 90471-PW7-A00
#130
we need a mod in here to clean the thread before someone orders the wrong parts and blames it on the thread/Ravi....
#131
what up people (im a noob so bare with me) I really wanna do this pressure switch change along with the atf and oil change and spark plugs.. i dont have tools and im not mechanically inclined either way... I usually do the services at my dealer but they "cant" use aftermarket atf and they told me the pressure switch change is not necessary ... I live in Inglewood California by LAX airport anybody knows shops or mechanics with experience in the pressure switches around this area? any help or info is greatly appreciated
#132
Glad I came across this thread!
We just bought a 2008 Base TL with 64k miles on it. Trans shifts great other than one downshift that just felt a little too firm for me. I've also owned a 2004 Base TL before and it also gave me some too firm downshifts sometimes before selling it.
I plan to replace the trans fluid (which still looks and smells great via the dip stick) and replace these sensors and will report back with how it goes.
#133
Going to be doing this soon. Probably at my next oil change. Hopefully I will notice some sort of improvement. Although, I haven't noticed any issues with the shifting thus far, the car has almost 120k on it. I've had it since 14k and I've never changed the switches, just the ATF. So it may be about time to get them done anyway.
#134
I am planning on changing these switches this weekend and doing a 3x3. My thoughts are to replace the switch behind the wheel while the car is on jack stands draining. Then do the other two while it is down. Then do the first refill before test driving.
Is there any though on doing the 3x3 first before the switches, or the switches and then the 3x3? Does anyone see any problems with my plan of attack?
#135
woowoo (03-27-2013)
#138
Thanks again for the write up and assistance Ravi.
I changed these switches today and did my 3x3. Everything is working great and there is a noticeable difference in shifting. The car now seems more eager to downshift when I floor it and will run to higher rpm before upshifting.
Some things I learned along the way:
All of the connectors including the switches are squeeze and pull except one. The one that isn't, is in the third picture where it points to the connector holding the wire harness in place and says "Detach". For this one you need to use a flat head screw driver to pry the tab on the right side, out toward the rear of the car. I stuck the screwdriver in between the plastic and metal, twisted till the tab freed, and then pulled the connector straight back.
For some of the squeeze connectors I had a hard time getting enough force on the depress levers with my hand in such an awkward position. You can carefully use a pair of pliers to depress the connector tab and gently pull it back off. Do not squeeze too hard. Do not use pliers to reconnect any of the connectors.
I had to remove the bracket for the switch under the air intake. Remember these are nuts so be careful when taking them off that you don't drop them. It is also a very tight space for the nut on the right. You cannot get to it straight on with an extender. I recommend either a 10mm box wrench or a small 1/4" socket wrench. I used the socket wrench.
For the switch under the air intake I had a hard time snaking the socket and the extender down onto the switch. Instead I disconnected the socket and put it on the switch first. Then I carefully clicked the extender and ratchet onto it. This gave me the extra half inch I needed by having the socket already snugged up against the switch. I did the same thing when replacing the sensor. If you have to do this be very careful not to hurt the new sensor why you are trying to snap the extender and ratchet in place.
For the final one toward the firewall I was able to do it without disconnecting the hose. I used my 1/2 inch socket wrench and the deep 7/8 socket with no extender. I carefully slid the socket and wrench between the two hoses and then pulled it forward onto the switch. Once it broke lose I squeezed my hand down in there to finish unscrewing it by hand.
For both of the top switches, I found the best luck lowering them in with the threads pointing up with my left and and reaching my right hand down the other side to catch them. This helped to keep the washers in place. I used my right hand as a support and back stop and my left hand to thread the switches in.
Last note is for anyone who plans on doing a 1x3 and change these switches at the same time. I recommend pulling the air filter box before you pull the fuse box and try to access the ATF fill bolt. Doing so enables you to lay the fuse box over in the space where the air filter usually would be. You can easily get your hands on the drain bolt and have plenty of room to break it lose. You can even use a smaller extender if you need to because it puts you so much closer to the bolt.
Thanks again to Ravi, JDM RICe, and everyone else who gave pointers on making this a very approachable DIY.
4drturbo (02-27-2017)
#140
Completed this over the weekend, a few notes that might help out others trying this. I was able to get access to the switch under the intake and the one through the wheel easily, but I couldn't get the connector off of the switch by hand. I couldn't tell if i had pressed the clip enough to pull it off without damaging it. So I ended up using a pair of pliers to get the one from behind the wheel off. For the one under the intake I placed a flat head screwdriver in between the switch and connector. Then slowly twisted the screwdriver to push the connector off as I pressed on the clip, if I felt some resistance on the screwdriver I would press harder on the clip until it slid off. At first I thought I would have to remove the front strut bar and some of the hoses to reach the one behind the engine, but it's accessible by snaking your arm through there. The easiest way for me to take off the switches was to place the socket over the switch by hand then connect the extensions and wrench. Thanks again to Ravi for the DIY.
#141
I need to do this ASAP! My car has a "glitchy" shift in most gears in stop and go traffic... its annoying as hell. I will be putting on a Comptech S/C shortly so I am hoping the switches and some redline Racing ATF will get rid of this issue!!!
#142
I'm just going through a service manual now, and it looks like there are 3 pressure switches: 2nd, 3rd and 4th gear, two of them the same. See attached
demon-cleaner (04-25-2017)
#143
Hey guys.. I have a 07 TLS that I bought 7 months ago with 67k miles.. It now has 75k miles and I just got service engine due A13 code which i read its oil and tranny flush.. What's this 1x3 and 3x3 mean? I'm sorry I'm new to this site... What fluid is recommended? I also noticed most of my gears jerk when shifting... Very noticeable jerks on every gear even when driving normal but more noticeable when full throttle... I'm buying the sensors stated in the 1st post this weekend... Thanks in advance!
#144
^^^ the most common reply will be to read, since the info is shared a million times....
but since am in a good mood, I will explain, again, LOL
The Automatic transmission does not drain out the full fluid when we do a drain, it only drains out, 3 quarts....for a flush, a 3x3 is recommended which means, you drain the 3 quarts and fill it will 3 quarts and you do this 3 times....
if you see a 1x3, it means you drain 3 quarts and fill 3 quarts and do it once....4x3 means, you do the drain and refill 4 times
a flush is done at the dealer where they suck out the old fluid and fill it with new one....I recommend AGAINST it since all the metal shavings and debris is stuck in the transmission....
Here is the fluid % chart for drain and refills:
1=39.5%
2=63.4%
3=77.8%
4=86.6%
5=91.9%
6=95.1%
7=97.0%
8=98.2%
9=98.9%
10=99+%
So it takes almost 10x3 to get all new fluid in there....
Now that you know drain and refill and how many times to do it...lets move onto the jerkiness of the transmission....
The switches should help....the pressure switches are pneumatic switches which close/open at a certain psi....with age, they dont open/close at the set psi....I would also look into Redline transmission fluid....some are running Type F, some are running D4 and some are running a mix....if you dont know what you want to run, I would just stick to OEM Honda DW1 fluid....
I run all Type F and instead of doing a 3x3 every 60K miles, I do 1x3 every 15K miles....I have done a 6x3 so far and I love how my transmission shifts....
1=39.5%
2=63.4%
3=77.8%
4=86.6%
5=91.9%
6=95.1%
7=97.0%
8=98.2%
9=98.9%
10=99+%
The following 2 users liked this post by swoosh:
hialeahzbg (08-30-2013),
RaviNJCLs (08-31-2013)
#145
Dallas Chapter Leader (Midwest Region)
#147
Perfect now I really understand this... I will definitely inspect my mounts and see if they need to be replaced.. I bought my car with 2 year extended warranty so is the pressure switch and mounts covered under it? I'm sure the tranny flush is out of pocket which is fine with me.. I had a 1999 civic Si before this and many other modded Hondas but this seems like a totally different car...
#148
do some reading....see whats right for you LOL...
the reason I dont want to "recommend" anything is because if you transmission goes kaput...you gonna start a thread saying "swoosh fucked my transmission" LOL
#149
also this is for an Automatic trans....if you have a MT, you should not be here
#150
#153
KCCO
Great thread. Will be doing this soon I hope. Do any of my Canuck brethren know of a Canadian online shop that sells Acura parts? Unfortunately, US companies can't ship internationally so I can't take advantage of the good prices at oemacuraparts.com and others like them. I really don't want to order from my local dealer if I can help it.
#154
Volunteer Firefighter
This is a little bit of a read but i want to be thorough and get the right info from the right people on here...
So I read this thread over and over and over... I lurk on here alot and only post if needed on any forum and right now is a need. I followed the instructions and I'am on my last 1x3 using 1 quart redline d4 and 2 quartredline racing atf so i decided to finally switch out all 3 sensors since i bought them months ago preparing for this.
Trans was shifting fine but at 99k miles I figured it was time for this preventive maintenance. Install went normal, after i was done i noticed it was smoother but i didn't do the final 1x3 yet since i wanted to test the sensors. Good thing since about half a mile down the road my engine light came on and no 5th gear. Came back ran a scanner and i got code p0848, Transmission Fluid Pressure Sensor/Switch B Circuit High. It was a long day so i let the car sit and decided next day to work on it.
Did some searching and came across the code is related specifically to one of the 3rd gear pressure switches, sensor b i assum since the scanner pulled "switch b"... so i decided to go back in, remove and inspect them. Saw no visual issues so i decided to switch them to see if the problem was still there. Cleaned them up, and while removing the sensor under the intake it snapped and the thread remained in the trans. I was able to get it out cleanly and luckily I had kept my original ones so i re-used one and cleaned it up and re-installed. Had no choice since the dealer has to order these apparently. Cleared the code. Drove half a mile and again same code and still no 5th gear.... i have 5th gear and it shifts smoothly for that start up until the half mile point but i guess once the sensor cycles with the computer, it shuts off and i lose 5th gear.
Anyone have that problem or know another solution? Is my research wrong and my problem really in my 4th gear sensor behind the driver side tire?
I'm pretty auto savvy but can't get my head around this one and i cant seem to find others with this issue. I see peolpe with 3rd or 4th gear issues but not 5th.
Thanks for any help guys
#157
Downshifts? Upshifts? Both?
Currently when my car downshifts from 3rd to 2nd, I feel a jolt , (almost like I got rear-ended by another car) maybe "shake" was the wrong verb to use.
#158
anyone yet maybe have an idea with my issue above? I don't want to jump thread to thread asking the same question, plus this one looks the most informative. I'm considering doing the job all over again with new sensors. It's really bugging me I cant find this problem anywhere else and don't want to be forced going to the dealer if I don't have to.
#159
Log Out | HelpSEWELL INFINITI OF FORTWORTH
Select Vehicle | New TSBs | Technician's ReferenceComponent Search: Conversion Calculator 2008 Acura TL V6-3.2L
Vehicle Level A L L Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P0848 Automatic Transmission Automatic Transmission DTC P0848: Open in 3rd Clutch Transmission Fluid Pressure Switch Circuit, or 3rd Clutch Transmission Fluid Pressure Switch Stuck OFF
NOTE:
- Before you troubleshoot, record all freeze data and any on-board snapshot, and review General Troubleshooting Information.
- This code is caused by an electrical circuit problem and cannot be caused by a mechanical problem in the transmission.
- Turn the ignition switch to ON (II).
- Clear the DTC with the HDS.
- Start the engine, and warm it up to normal operating temperature (the radiator fan comes on).
- Drive the vehicle in the 3rd gear in M, and verify that the SHIFT CONTROL indicates 3rd in the DATA LIST with the HDS.
- Check the 3rd PRESSURE SWITCH in the DATA LIST with the HDS.
YES - Go to step 6.
NO - Go to step 8.
- Test-drive the vehicle in 3rd gear in M for at least 2 seconds.
- Monitor the OBD STATUS for P0848 in the DTCs MENU with the HDS.
YES - Go to step 8.
NO - If the screen indicates PASSED, intermittent failure, the system is OK at this time. Check for poor connections or loose terminals between the 3rd clutch transmission fluid pressure switch and the PCM. If the screen indicates NOT COMPLETED, go to step 6.
- Turn the ignition switch to LOCK (0).
- Disconnect the 3rd clutch transmission fluid pressure switch connector.
- Measure the voltage between the 3rd clutch transmission fluid pressure switch connector terminal and body ground.
Is there about 5 V?
YES - Replace the 3rd clutch transmission fluid pressure switch, then go to step 13.
NO - Go to step 12.
- Measure the voltage between PCM connector terminal C9 and body ground.
Is there about 5 V?
YES - Repair open in the wire between PCM connector terminal C9 and the 3rd clutch transmission fluid pressure switch, then go to step 13.
NO - Go to step 20.
- Reconnect all connectors.
- Drive the vehicle in 3rd gear in M for at least 2 seconds, then upshift to 4th gear, and drive in 4th gear for at least 2 seconds.
- Check for DTCs with the HDS.
YES - Check for poor connections or loose terminals between the 3rd clutch transmission fluid pressure switch and the PCM, then go to step 1.
NO - Go to step 19.
YES - Troubleshooting is complete. If any other DTCs were indicated in step 18, go to the indicated DTC's troubleshooting.
NO - If the screen indicates FAILED, check for poor connections or loose terminals between the 3rd clutch transmission fluid pressure switch and the PCM, then go to step 1. If the screen indicates NOT COMPLETED, go to step 16.
- Update the PCM if it does not have the latest software, or substitute a known-good PCM.
YES - Check for poor connections or loose terminals between the 3rd clutch transmission fluid pressure switch and the PCM. If the PCM was updated, substitute a known-good PCM, then go to step 21. If the PCM was substituted, go to step 1.
NO - Go to step 24.
YES - If the PCM was updated, troubleshooting is complete. If the PCM was substituted, replace the original PCM. If any other DTCs were indicated in step 23, go to the indicated DTC's troubleshooting.
NO - If the screen indicates FAILED, check for poor connections or loose terminals between the 3rd clutch transmission fluid pressure switch and the PCM. If the PCM was updated, substitute a known-good PCM, then go to step 21. If the PCM was substituted, go to step 1. If the screen indicates NOT COMPLETED, go to step 21.
Vehicle Level A L L Diagnostic Trouble Codes ( DTC ) Testing and Inspection P Code Charts P0848 Advanced Diagnostics Advanced Diagnostics DTC P0848: Open in 3rd Clutch Transmission Fluid Pressure Switch Circuit, or 3rd Clutch Transmission Fluid Pressure Switch Stuck OFF
General Description
The 3rd clutch transmission fluid pressure switch is installed in the hydraulic pressure circuit to the 3rd clutch. When hydraulic pressure is supplied to the 3rd clutch, the switch is turned ON. When hydraulic pressure is not supplied to the 3rd clutch, the switch is turned OFF. The signal from the 3rd clutch transmission fluid pressure switch is input to the powertrain control module (PCM). The PCM detects the hydraulic pressure supply conditions at the gear change to 3rd gear (2nd -> 3rd, 4th -> 3rd) to reduce the shock that occurs at the gear change. If the 3rd clutch transmission fluid pressure switch is OFF while the rotation speed ratio of the input/output pulses is that of 3rd gear, the PCM detects a malfunction in the 3rd clutch transmission fluid pressure switch and stores a DTC.
Monitor Execution, Sequence, Duration, DTC Type, OBD Status
Enable Conditions
Malfunction Threshold
The input signal from the 3rd clutch transmission fluid pressure switch to the PCM is high when driving in 3rd gear.
Driving Pattern
Start the engine, and drive the vehicle in the D position and 3rd gear for at least 2 seconds .
- Drive the vehicle in this manner only if the traffic regulations and ambient conditions allow.
Conditions for illuminating the MIL
When a malfunction is detected, the MIL comes on and the DTC and the freeze frame data are stored in the PCM memory.
Conditions for clearing the MIL
The MIL will be cleared if the malfunction does not recur during three consecutive trips in which the diagnostic runs.
The MIL, the DTC, and the freeze frame data can be cleared by using the scan tool Clear command or by disconnecting the battery.
© 2013 ALLDATA LLC. All rights reserved.Terms of Use
Slpr04UA6 (09-26-2013)
