07 TL Type S wiring issues
Ok so I have a 07 TL Type S with a 6 speed manual tranny. I accidentally ran a screw trough a wiring harness and had to replace the wiring harness in the dash. The problem is the wiring harness I pulled and installed in my car is from an automatic and my car is a 6 speed. So there is nothing letting the car know when I have the clutch pressed in so the car will turn over but not start. Is there anyway I can bypass the switch for the clutch or what should I do. Thanks in advance.
Get the right harness!
Why didn't you just repair the wiring harness?
Here is the wiring diagram for the 07/08 AT and MT starting systems. Keep in mind that the cruise control also monitors the clutch switch.
It looks like you will need to connect the clutch switch to Pin# 3 of the Starter Cut Relay 1.
Automatic
Manual
Automatic
Manual
Cthulhuy (03-11-2023)
Thanks for the wiring diagram im gonna try to figure it out now. I didn't repair the original harness because there were so many wires that melted together I tried separating then but they were in the middle of the harness . I do still have the harness so if nothing else I'll just trace the bad wires out one at a time.
flexed2death
05-31-2012 10:02 PM
Stillmatic29
01-29-2011 08:09 PM
