'07 TL - Is there any way to view maintenance minders?
Hi, I purchased my 2007 Acura TL used a few years ago. I am embarassed to admit that I had no idea about this "maintenance minder" system. I have receieved the message when I need an oul change and reset but I have never received any other messages. I am now over 100k and I'm thinking I should have had a maintenance minder for several things by now. Is there anyway i can see if these have been turned off or what percentage they are at. I am reading an 07 owners manual and see I shoulf have received minders for transmission fluid change, timing belt, spark plugs, rotate tires, etc. I have never received any of these and I have put 60,000 plus miles on this car myself and have now crested over the 100k mark. Is there a possibility mine have ben disabled? I can't find anything in book to check anything other than tires and engine
No idea if there is a history you can look at. The different codes in the Minder define what was "called" for. You may have not noticed that the letter/number combos changed over time and just assumed oil change and reset.
