05 TL 6spd vs 03 G35 6spd
Both Stock.
My acura vs my brother's G35 sedan- both stock. I knew I was going to lose, but how bad?
Part One
http://www.youtube.com/watch?v=xZgBNjDsryM
Part Two
http://www.youtube.com/watch?v=riRQjBwEjsE
As I downed to 3rd, the gears on the TL is so long!! When I'm on 6K RPM, the G35 already shifted into 4th. I was thinking of the same short gear, but I was on the G35's rear til I slowed down for cars.
2003 G35 RWD sedan 6spd - 14.4 quarter mile
I'm thinking of 14.6 - 14.8 for the TL since my nose was on the G35's rear the whole time.
I used to have a 2006 Civic SI with 230whp and did 13.8 @ 99mph with IPS K2 cams, full bolt-ons tuned on Flashpro so I track frequent.
3.2L vs 3.5L... seems like the TL-S would be an even match. Just to enjoy the videos...
Getting TL-S cam installed, J-pipe, and CAI. Will see how far I walk the VQ motor.
Part One
Part Two
2003 Accord Coupe V6
Nice races man! Glad to see you got them on video. The 03 G35 Sedan 6spd is a easy low 14 second ride with lots of torque. I have seen traps around 99-100MPH. The TL 6MT isn't far behind though. It is capable of 14.4ish around 97-98MPH stock. Basic I/E will even out the score card. Add a J-pipe and or pre-cat deletes and you will pull on the G even without TL-S cams.
All motor
Your bro looks like an OG in the 1st vid lol.
Dude, are you serious? 03 G35 6 speeds are horribly slow, at least .5-.8 slower in the quarter and they trap like 3-4 MPH less. A stock 6MT TL can pull similar 1/4 mile traps to your old Si...
Not trying to be rude but you need a driver mod. You should be raping your brother's G35 from a roll or a dig, period.
Edit: Yeah, you need a driver mod BADLY. Your brother had a passenger, you were by yourself and he STILL beat you? Damn that's bad. You need to practice shifting OR your engine is messed up somehow, maybe both. Plus why would you start in 3rd gear @ 6k RPM? That initial shift just slows you down...
08 WDP TL-S
you are right...becuz 3.2L vs 3.5L...i own a 2G Type S before and tried with my buddy mom's car 2008 Accord V6 auto(which is the 3.5L)one,i had intake,lower and catback exhaust,i still lose...it was becuz 3.2L vs 3.5L problem....
i bet a 3G Type S bone stock even auto will the 03 G 6speed
The following 3 users liked this post by anx1300c:
i am so smart S M R T
All motor
All motor
All motor
Turd Polisher
If you two race, make sure to get it on video!
^ Bump @ this quote... I raced an AT TL with some sort of exhaust mod ( could be a j pipe) in Brooklyn. Tan exterior. Looks like you had a really bad launch; would love to race again. Hopefully I can line up with sonnick and a TL-S soon.
I can't see the videos since I'm at work, but it sounds like you should have started in 2nd gear? Were you guys starting at about 50 mph?
It was high 50's as it was day time and there was traffic we were holding on the fast lane so didn't want to drop any lower than the posted highway speed. If it was darker out with less cars, we would had all the speed we could on the freeway. But consider with traffic, 3rd gear roll was the best choice with traffic. Just wanted to see how I stacked up against the G35. The sedan is lighter than the coupes and with the coupes, I'm even.
All motor
If you started in 3rd at 55mph, that's not a great RPM for us. The VQ35 has a much broader torque curve, not to mention shorter gears as well. At 55mph, he is at the bottom of 3rd as well, but with his shorter gears, it's easier for him to make that up. Do a 45mph roll in 2nd, then a 60-65mph roll in 3rd. Then see what happens.
The Dumb One
i like to do short sprints on the hwy from like 60-90 as much as the next guy..
but its dead stop - finish line or nothing!
even if i lose, i'd rather lose to the driver and not the powerband of the car!
anyone can shift 3rd-5th!
take em to the track and just out-man him!
To OP, did you shift at 6k rpm on your TL? If so, that is the problem. You need to bring it up to at least 6.5k rpm, or more, maybe 6.7k then shfit. These cars shine at high rpms.
It is definitely the driver fail in this race. If the TL was driven right, it would have pulled on the G35 6MT.
...yeah, my head hurts too.
Not if the driver doesn't shift at correct shift points. Drivers make all the difference whether it's from dig or roll. You must be new...
I did not shift at 6, did not shift at 6.7, but I did shift at 7. TL's does not shine at high RPM as they shine right at mid range.
I've driven many cars from AWD, RWD, FWD in many years of my life from 3000GT VR4 to 98 GST to 99GSX, to 05 EVO to 06 SI, and 300ZX to 350z as I've own and tracked.
If this is drivers fail, I would not have broken records set by me. But aside from all that, I contribute my life on autocross and drag racing for the past 11 years. I'm not the best, I'm not DRIFT KING, I have techniques on different platform I could use on FWD, but the video states the facts. Of course if you live in Marland or California, those race tracks show the best times I've ever will see if I were to run my car and try to duplicate theirs, is IMPOSSIBLE. The elevation here will never be as near perfect as those tracks and the air/temp will never compare their summer vs my summer.
I've been doing lots of research on the TL lately and came across the "checkvalve delete". My 05 TL during the races had lots of pressure when I was at near redline, my clutch pedal would stall, taking it's sweet time to come back down.
We went again this winter as we barely have any snow this season but the road was great, the weather condition was great. I did not record it this time, but the outcome is different with my check valve delete on the slave cylinder.
With the CVD (check-valve Delete) the timing of shifting and the RPM grabbing when it should be grabbing that a certian RPm when I was shifting dramatically changed the race.
I was neck and neck on 1 race and was up a fender/door by another race both from 40 MPH - 110MPH.
So if this was drivers race, our TL manual from factory has disadvantages to a driver. Call it whatever you want, the outcome changed when I deleted the CVD off the slave cylinder.
Stock per stock, The TL would be neck and neck, with CVD.
Stock per stock, the TL would hang on the rear doors, w/o CVD mod.
End of my conclusion on my thread.
All motor
^^ Very good to know. Did your brother have a passenger this time as well? If not, the slave mod may be better than you think And if that's the case, I better get on it!
We both had no passenger otherwise I would have had it recorded. But I explained it very detailed.
I meant end of the G35 Vs TL is because I no longer will be stock so the comparision will be different. But others who can beat G35 6pd rwd on their complete stock TL, kudos to you.
As for the forum about the Slave mod, kudo's to Opel.
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/113-removal-slave-cylinder-check-valve-734300/
The cure to shifting fast!
https://acurazine.com/forums/showthread.php?t=734300
All motor
That's great news! The slave cylinder helped you make up over a car it looks like. I'm not sure if this is enough to call it "proof" based on 2 races, but enough to make me want to do it even more now.
