04 TL Hydrolocked, looking for a J35 block. Questions
Hi,
Fool of me used CAI on raining season, my TL is dead, no compression, still need to see if the rods are bent or not, at surface the cylinder walls looks fine, so I'll wait. But I have a question, in the case of the bent rods I will check for a new block. I can buy from a junkyard a J35AZ2 it seems, is from an Accord 2010 v6. The block size seems to be the same, I assume the rods and the crank are different. My questions are:
1 - Compression would be still 11:1? since I'll keep my heads
2 - The Valve clearance would be fine?
3 - Any extra consideration?
I'll re surface the heads as well. Any Input is appreciated
