[DIY] Let's Add Some Class: Side Mirror Puddle Lights
Old 05-27-2014, 07:56 PM
  #81
d1sturb3d119's Avatar
And this is how a DIY is written. Some other forums should take notes! Good work!
guitarplayer16 (05-27-2014)
Old 05-27-2014, 09:28 PM
  #82
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
Old 06-25-2014, 11:30 AM
  #83
richymolina77's Avatar
This is perfect, it's dark in my garage, it'll add the extra lighting so i don't trip on any toys lol
great diy!
guitarplayer16 (06-25-2014)
Old 06-25-2014, 12:21 PM
  #84
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
Thanh...this is an amazing mod that was very well executed by you...
Love the DIY as well...
Old 07-09-2014, 10:46 PM
  #85
I forgot to post this video here:
The following 4 users liked this post by guitarplayer16:
corrado85 (12-07-2014), Healingduck (09-15-2014), lights (07-25-2014), Timmy18 (07-16-2015)
Old 08-30-2014, 10:31 AM
  #86
So not a sociopath
CrazyEights's Avatar
Can't wait to wrap this up,
I've got the LED's install, but anyone have some tips on getting the wire through the door loom?
I can't get the white clip in the door to come off and really don't want to break it.
Old 09-01-2014, 08:11 PM
  #87
under renovations....
CubanLynx84's Avatar
Just drill a hole like GP did instead of messing with the door harness
Old 09-01-2014, 09:51 PM
  #88
So not a sociopath
According to this post there's an existing harness hole, I'm guessing there's a hole in the middle of the harness i should be able to pass the wire through, I was just trying what looked like holes on the ends.
Hey there,
I ran the wire through the existing door harness hole.
Yes, you can splice the wire into the footwell wire, that's exactly what I did
It aces a lot of time.
Old 09-04-2014, 06:53 PM
  #89
So not a sociopath
First thing, I it through the passenger door by removing the rubber loom first, then using a screwdriver to get the white clip out, easier to push up on the bottom tab, the wires for the LED will "fit" between the white clip and the edge of it's hole, but there's a chance it has cut into the shielding of your wire.
Lastly,
I feel like this needs to be edited in the first post.
DON'T USE FUSE #32!!!
That is unless you only want your puddle lights to work when the key is turned on, not really a big deal, I used furse #14 instead, but ya...
guitarplayer16 (09-04-2014)
Old 09-04-2014, 07:22 PM
  #90
Lastly,
I wasn't thinking when I wrote fuse #32.
You're right, Fuse 32 is only powered when your car is on.
I believe I used the fuse for the power seat, since that's always powered.
There's like 4, one for passenger/driver, and one for recline/slide.
Old 09-08-2014, 11:14 AM
  #91
Dossboss's Avatar
Nice tutorial
Old 09-08-2014, 11:42 AM
  #92
7th Gear
obsolete83's Avatar
Awesome and thanks for the step by step and where you buy!!!
Old 09-14-2014, 02:00 AM
  #93
Purple ashes's Avatar
Attempt #1 was a failure.. I used 18 guage wire thinking it wouldnt matter but i guess it did.. Couldnt find any 20 guage anywhere.. Tomorrow is gonna be a hella of a hunt.. Just to make sure i gotta get the 18-22 guage for t taps, splices, etc correct?
Old 09-14-2014, 08:28 PM
  #94
Correct
Old 09-15-2014, 10:47 AM
  #95
ddaviglus's Avatar
Amazing diy post by the OP and even greater discussion by all the other contributors (ie Guitarplayer16, DAMIN).
guitarplayer16 (09-15-2014)
Old 09-16-2014, 09:31 PM
  #96
Outcome is perf.. Great diy and help from guitarplayer16..
View this post on Instagram
The following 2 users liked this post by Purple ashes:
erg69 (09-17-2014), guitarplayer16 (09-17-2014)
Old 09-16-2014, 09:32 PM
  #97
Excuse the foggy headlights.. I guess i didnt seal it up right when i blacked those bbys out.. :-(
Old 09-17-2014, 04:57 PM
  #98
erg69's Avatar
Wait, 18 gauge wire will not work?
Old 09-17-2014, 05:15 PM
  #99
It will work
Nice job purple ashes!
erg69 (09-18-2014)
Old 09-17-2014, 05:48 PM
  #100
Slayer-33's Avatar
This is crazy hawt, nice video.
Old 09-17-2014, 10:08 PM
  #101
Boogsephine's Avatar
If these are wired to the footwell lighting / map light that fade out, does this mean they'll come on when the interior dome light is turned on? This is a DIY I'd love to do sometime soon but wouldn't want the puddle lights coming on if I had to turn the interior map lights on for some reason.
Old 09-17-2014, 10:46 PM
  #102
Nope, the dome supervision wire doesnt turn on when you turn on the dome.
That's the cool thing.
Now if you tapped to the dome wire, that's a different story.
Boogsephine (09-19-2014)
Old 09-26-2014, 02:35 PM
  #103
8th Gear
venzenzo's Avatar
Awesome idea, thanks for posting
Old 10-01-2014, 04:35 PM
  #104
6th Gear
TylerPerry's Avatar
looking good man, so as long as the interior lights the puddle lights will be on?
Old 03-28-2015, 07:30 PM
  #105
killer8rican's Avatar
does anybody know where to make the hole on a type s? the mirrors are different from the bottom and behind the glass. I need some guidance
Old 03-28-2015, 09:19 PM
  #106
PM Paperboy42190
He has the exact same LEDs from Oznium on his Type-S
Old 11-22-2020, 07:27 PM
  #107
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,652 Likes on 1,117 Posts
So, question, I'm trying to do this mod and I'm missing something. The lights are staying on and not going off with the dome lights. I have the red positive wire connected to the interior light fuse, and the negative connected to the red/green wire on the 5 wire connector above the MICU. Either the red/green wire is not the ground for the dome lights, or I'm missing something. In the 5 wire connector above the MICU, there are 5 wires: yellow wire with blue stripe, green, orange, black, and red wire with green stripe. What am I missing? Even when I connected the positive red wire from the LED to the power seat slide fuse, it still is lit all the time.
Old 11-22-2020, 08:25 PM
  #108
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I would like to know which negative wire to hook up the negative (black) wire to from the LED, because the red/green wire (it's red with a green stripe, not green with a red stripe like in the original post) is making the LED lit all the time. Also since I hooked up the positive wire to the interior light fuse (fuse 6 I believe), that's also why it's staying lit all the time. Is there a positive wire that I can hook up the positive LED wire to so that the LED light goes off with the courtesy dome lights?
Old 11-22-2020, 08:59 PM
  #109
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
It does not matter which of the 5 wires from that white 5-wire connector above the turn signal relay I connect the negative LED wire to, the LED stays lit all the time.
Old 11-22-2020, 09:30 PM
  #110
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I figured it out. Reading OWNS me. It's the GREEN 5-wire connector BEHIND the turn signal relay, NOT the white 5-wire connector above it.
Old 11-23-2020, 05:50 AM
  #111
jdmvette's Avatar
I've got these wired as puddle lights and yes, wiring them to work correctly was a pain in the ass
Amazon Amazon
Old 11-23-2020, 05:57 AM
  #112
jdmvette's Avatar
Old 11-23-2020, 12:08 PM
  #113
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Those look AWESOME!
Old 11-23-2020, 12:19 PM
  #114
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
@jdmvette Did you hook up the turn signal or parking lights, or did you just hook up the courtesy lights that are bright white?
Old 11-23-2020, 06:00 PM
  #115
jdmvette's Avatar
@gatrhumpy
If you want the lights to turn on with the fob as you hit unlock (like I did) you have to connect both the positive and negative leads from the light strip to negative signals on the TL.
I believe the positive strip lead went to a green/black negative wire that is at the front headliner switch for the dome lights and the negative can go to any regular grounding point.
I got all the wiring info from this forum. If you can't find the info let me know and I'll look up the threads I used.
space_boy
ILX
51
08-15-2017 12:06 PM
sockr1
10-01-2015 01:31 AM
PortlandRL
09-14-2015 12:01 PM
Ny1718
09-11-2015 09:21 AM
Nicho863
09-02-2015 08:12 AM
Quick Reply: [DIY] Let's Add Some Class: Side Mirror Puddle Lights
