*Advice needed* Looking into buying a 2004 TL w/ 160k miles
Hello all,
First time here in the Acura world: I began as a Honda guy and former Mazda3 guy.. currently driving a Honda Insight (first gen) and looking to "upgrade" to the Acura world (more practical.
I took a look at used 2004 Acura TL in question. It has 160k miles on it as the owner was driving clients back and forth. Reason for selling is that the job requires a car with less than 150k.
Regardless, the owner is the first and only owner. They have all the maintenance records. The Timing belt has been changed at 101k. All recommend maint done.
Impressions of the car: When I drove it, i like the ride and the feel.
My questions tomorrow is when I actually do a real world test drive of the car is..
What should I be looking out for in a 2004? Some advice would be really helpful. Thanks!
~W
~W
Hello all,
~W
~W
2004 TL
160k miles
All maint records
Fully loaded with Nav
Silver with black interior
08 MDX, 04 TL (sold)
Have it checked out by a mechanic to be sure, but I would say it sounds pretty decent from your description. The TL should last a very long time if properly maintained and cared for and it sounds like this car was, since you say that all the recommended maintenance was done.
auto or manual cause if it is an auto, i'd stay far away from it (ask him how many transmissions has he put in the car) you can open the hood and see if it has been replaced becuase the ACURA replacement ones will have blue painted bolts.
the acura is a very long lasting car, and the drive is very smooth. the only thing i would be a little worried about the trani (if automatic).
there was a recall on the early TL 04 with automatic tranny. ask the owner about this since he was the only owner of the car and see if he took the car back in for the dealer to resolve the issue.
I have an 04 with 70K miles on it now, and love the ride..
cheers.
cheers.
cheers.
cheers.
Anything else to look out for?
BTW, see if you can find out when it was built. The early '04s had a problematic trans (even with recall) that was apparently the same as the 2G TL trans. The later '04s have the newer trans (same as 05) which seems to fix the issues.
That's a steal if it has a clean title and if the 105k service was completed already.
Had a long test drive today over the mountains in the East Bay. Wonderful driving car, slightly bumpy, but it's not that bad. The car was smooth and it drove really well through the hills. The engine felt like it was babied and even with AC on at full blast, it had a lot of power to carve through the valley.
Even my wife who was skeptical at first was worried about the car, but when she sat in it, it felt good.
Carfax looks clean, except for the 2 TSBs that was done on record (power steering and windshield wiper). The only lingering thing on my mind was the Auto trans from first to second & second to third was a bit rough.. I asked them about the TSB "TSB 04-020: Safety Recall: CL and TL Automatic Transmission 2nd Gear Inspection. but she had no idea about it.
So far, so good! Will keep you guys posted!
Sounds like a well maintained TL that has seen regular use. As long as you are going into it with the understanding that there will be some wear items (shocks, brakes, etc.) that may be coming up for replacement. Personally, I would be a lot more comfortable taking a plunge on this TL than some of the other recent posts on TL's with salvage titles.
Do your due diligence and get it checked out by a mechanic. Get estimates on any items needing attention and use that as leverage in the negotiation. Good Luck!
Some additional thoughts (went into edit mode too long)
Take the time to check all the switches/controls to ensure everything works (mirrors, all the windows, etc.). Be sure to ask the owner if there are any known issues. You may get someone that will honestly tell you of issues. If there is a real disconnect between what they acknowledge and what you find either they don't pay attention to their car or they are covering stuff up.
One issue that is coming up on some on 04's is the Main power button (not the set, coast etc but the main power) for the Cruise Control will not stay on and requires replacement. Mine is going into the shop on Thursday. Probably a $200-300 job. I believe others have had issues with bulbs going out on the steering wheel controls. If you find issues that require addressing, it is not the end of the world. Just decide if it is something you can live with or use it as leverage on the price.
Be sure to include some variety in your test drive. Include some rough roads or train track crossings to see how many rattles this TL has picked up (common complaint on earlier TLs but good dealers have corrected a lot of the issues).
2004 NBP TL 6MT
I too agree that with clean title and good maintenance it could be good deal. However, have automatic tranny driven and inspected by professional. If it checks out, what a steal. Should give you another 150K miles atleast.
I have about 148,000 on my '04 AT TL. It's been pretty reliable so far. Check the motor mounts. They usually go bad on this model. I had to have 2 of mine replaced at around 120k miles. I had an SRS light come on that the dealership said had a 150k or lifetime warranty, so I paid nothing for that. Some of the switches have their lights go out when you get up over 100k miles, but it's not a huge deal. I had a power steering pump fail on me around 80k that was covered by the extended warranty. So the only major repair I've had so far out of warranty has been the engine mounts, and like I said, those are common failures from what I understand for this model.
Unfortunately, replacing the pressure switches won't help with the rough shifts in 1st and 2nd. I would drain the ATF and run D4 in it. See how it shifts.. if it seems better.. go ahead and drain & fill again with another 3 qts of D4. If it seems like it has gotten worse, save your pennies for a new AT down the road. The 3rd & 4th pressure switches will smooth out the 3rd & 4th upshifts and downshifts, definitely not a bad idea with the miles the TL has but do the ATF first (don't flush out the ATF, it may jam up the valve body).
Btw, i'm picking up the TL today! Sold my insight a few hours ago and now moving on!~!!! so excited!
congrats on your purchase! One thing I was going to say was to check with your dealer on the next interval for the timing belt. From what I remember, it's 105K for the Timingbelt service, and then 60K thereafter.
There it is!
Took ownership of a wonderful 2004 SSM TL today with Navi.
Road it back home and felt like a king! So awesome, words cannot describe it!
I'll post some better pictures this weekend! Thanks everyone for your help! I'll keep you guys posted!
Woo! Congrats! Seems well maintained and that's a really good price. And as other have said, it was the earlier 04s that had a trans problem.. I believe the last digits of the vin were 15xxx and earlier. I too was concerned about this, but after a lil reseaRch and finding out my cars vin was somewhere after the 75000 mark on the vin, and actually produced in july of 04, I took the plunge.
AndrewS
19
03-14-2024 06:59 PM
jamestheunderdog
07-19-2016 07:58 PM
nanos
11-12-2015 08:41 PM
