*For those who've done Accord Fogs*
#41
Ps...for permanent mounting...you can run two big regular screws through those two little doors the pop open on the front of the fog assembly...for directing, you can put a screw the through the sides/bottom of the bumper that basically screw and hit the fog housing to hold in place and point. That's what I did...worked like a charm. I have them aimed pretty far down now so the glare doesn't cross over my low beam cutoff.
Hopefully my wiring PM helps![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
They're pretty jammmed tight in there heheh.
Thanks for the help, I shot you back a PM =)
I read about attaching the wire to a 10mm bolt in the fuse box.
If you wire the switch independantly, then yes, you can do that, however, I'm wiring my fogs up the original OEM way (parking lights).
emailnatec
29
09-28-2018 04:27 PM
adreano17
09-29-2015 08:48 AM
