fixed red light
so for the last week my nav traffic wasnt working, acura link wasnt working.
The light was steady red. Got pissed, decided to do a reboot on the car; disconnected the negative on the battery for about 15 seconds; reconnected. Started the car, put in the radio code, and in 15 seconds the light turned green and the nav traffic worked again, so did the acura link. Note to auto engineers; Put a reset button somewhere on the car so that you dont have to disconnect the battery to reset the electronics. Pulling a fuse is not an option either. You might want to make several reset buttons, one that resets the entire car, and one that resets only the consumer electronics, that way the learned logic of the tranny doesnt get reset when all you need to reset is the nav and other user electronics that are bound to lock up. |
did you try "ctrl alt del" on the touch screen :)
A better way to reboot the car is the way Cadillac does it on my CTS-V......turn off car, open driver's door. Next time key fob is turned, car is rebooted. It's a pretty neat and undocumented feature.
Hey Bob,
How do you turn the FOB when it's in your pocket? |
Originally Posted by sotiri
(Post 14996589)
Started the car, put in the radio code, and in 15 seconds the light turned green and the nav traffic worked again, so did the acura link. |
Originally Posted by George Knighton
(Post 14997603)
How much of a cold start was this? Other than having to re-enter the radio code, what else did you have to re-enter? Anything?
(Post 14996695)
Bob's been in the sauce again ... . . |
(Post 14997614)
Nothing else
Did anybody at Acura lead you to believe that it was a reasonable part of the troubleshooting process? I had a red light issue a while back...I think it was two weeks ago. I could not get the TRF icon or information, but I could still get the concierge. The concierge said that she was aware of the issue and they were working to fix it, and whatever information I needed help with, she'd be happy to give it, including pushing a traffic detoured route to the car if necessary. Good service, if somewhat time consuming. :-) |
I have no doubt the light becomes red if there are connection issues, but as I indicated on the other thread, it also turns red when messages are received. There is a delay often as much as 10 minutes, but it always turns red at some point when I have unread messages with no other connection issues.
I am so glad I am color blind.
Well, I couldnt even get the concierge.
Basically no traffic, no connection to acura, and it lasted a week. Being around electronics so much- and seeing how the first advice I give when a system is not functioning normally is to do a reboot or power cycle- and most of the times that solves the issues, I took my own advice and decided to cold reboot the car. There are so many external possibilities that can result in an electronic device not performing as designed- that it seemed to me to be the simplest solution before I took myself to the effort to bring it in for a service call. And then I thought to myself, I'll bet thats the first thing the service tech will do- reboot the car.
(Post 14999488)
Please, just a little more if you have time: What led you to believe that a cold re-boot was going to help your AcuraLink issue?
(Post 15000683)
Now, where did I put that radio code...? |
(Post 15001160)
Ha ha ha.... Yeah, probably.
My AcuraLink has not worked for 3 weeks now. No AcuraLink Client Services nor Roadside Assisitance - both call buttons dead. No traffic either. Tried the reboot - nothing. My AcuraLink unit was replace 1 month ago. So frustrating.
I don't know if you have a few minutes to try the following, or if you already have tried it:
https://cimg8.ibsrv.net/gimg/acurazi...20db27513f.png https://cimg9.ibsrv.net/gimg/acurazi...382e407b9b.png https://cimg0.ibsrv.net/gimg/acurazi...dd63897de0.png https://cimg1.ibsrv.net/gimg/acurazi...551b387e7f.png HTH |
Originally Posted by miner
(Post 15786978)
I haven't had anything this severe, but I have had a weird issue to do with a temporary lack of satellite coverage over an area, and it was not related to hardware or AcuraLink. I have an ongoing issue regarding the relevance of cellular traffic, and I think we're all just stuck with that. Next time I buy a car, it's going to have a way to use my iPhone's coverage, or I'm not buying the car. :-) There's just no way that a car manufacturer can afford to have services that equal those of your own iPhone's network, maybe with the American Express Concierge added in. |
I've gone as far as hooking up my iPad in the car so that I have better instant coverage from Apple Maps and Waze, on a big enough screen.
I don't do it all of the time. |
Were you able to connect the iPad via bluetooth, or did you use the USB connection? I asked, because i tried to connect my iPad via bluetooth but i could not...... Thank you. |
(Post 15789626)
Can you update us where you are with this?
(Post 15789627)
I don't do it all of the time. I'm sure as each new model year goes forward, there will be better and better integration for mobile phones and cars infotainment systems. As George indicated this is becoming more important every year. |
