Windshield wiper fluid hose issue
Old 10-28-2024 | 04:26 PM
Raleighwood007's Avatar
6th Gear
2020 Acura RLX. Fluid is coming out by front passenger door. I know it’s a hose but I need to know the best way to get to it to check it. . Also have a ? About the meaning of symbol on a panel under the hood. Thanks in advance
Old 10-28-2024 | 07:22 PM
John from PA's Avatar
See if Windshield hose is of any help in the routing of the hose. In replacing I would suspect you might also need a few clips.
There is another parts list at https://acura.oempartsonline.com/v-2...her-components
Old 10-29-2024 | 04:02 AM
DanL07RL's Avatar
I think that symbol indicate an adjustment port for the fog lights?
Old Yesterday | 04:04 PM
1186KA9's Avatar
Black Ac' Man
Headlight adjuster. You use a phillips head and turn it a direction to change the height of the lights. Don't touch unless you have flat ground, a perpendicular wall, and 25 feet of space.
NBP04TL4ME (Yesterday)
Old Yesterday | 07:00 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
This ^^^^
Old Today | 07:57 AM
6th Gear
Thanks.
Thank you so very much. So it’s leaking after the motor runs & it’s before it comes back up at the back of the hood at the hinge on passenger side. What I really need to know is the best way to access where it needs to be fixed. I removed a little bit of wheel well splash guards but I still wasn’t able to see it. The car isn’t that old so you wouldn’t think the hose would’ve dry rotted so quickly.
Old Today | 10:54 AM
1186KA9's Avatar
Black Ac' Man
I think you have to remove all the splash shields and maybe the fender. I think you have a rodent problem.
truonghthe
03-13-2024 08:44 AM
Courage
02-03-2009 08:05 AM
Quick Reply: Windshield wiper fluid hose issue
