trailer hitch
Old Mar 27, 2024 | 08:56 AM
blaser's Avatar
trailer hitch
Did anyone in MA installed a trailer hitch on 3G RLX SH and where?
I need it for bike carrier and looking at Uhaul to install or anywhere else that have experience with it
Old Mar 27, 2024 | 11:33 AM
hondamore's Avatar
I know that the MDX Sport Hybrid specifically states that it is NOT suitable for towing, so I am assuming that the RLX Sport Hybrid would be similarly restricted. From previous discussions on the issue on this forum, I believe the concern was the "jerking" and "uneven acceleration" that can be caused by towing could potentially damage the twin motor unit. Whatever the reason, if Acura has stated that you should NOT tow with the Sport Hybrid powertrain, then I would recommend that you NOT install a trailer hitch.
A quick chat with your service technician at your Acura dealership would likely clarify the issue regarding towing before you proceed with installing the trailer hitch.
Let us know what your investigations reveal.
Old Mar 27, 2024 | 11:34 AM
hondamore's Avatar
I had a Quick Look at the RLX Sport Hybrid owners manual and under "towing", the manual states:"Your vehicle is not designed to tow a trailer. Attempting to do so can void your warranties."
No further explanation is given.
Old Mar 27, 2024 | 07:54 PM
hondamore's Avatar
I should add to the above comments that the Acura warning is related to towing a trailer and not hauling bicycles. The issue with having a trailer hitch on the car may come when you try to sell it and the prospective buyer worries about what the hitch was used for and whether damage to the car was done.
Old Mar 28, 2024 | 09:04 AM
andysinnh's Avatar
They do make a trailer hitch for Acura RLX's (such as this one from Curt https://www.curtmfg.com/part/12120 ). But as others have said, since Acura says not to tow with the RLX, even if you never tow with it, a future owner may question that fact. The other thing is that the hitch from Curt is the smaller 1 1/4" receiver opening, which (IMHO) is pretty small for a hitch-mounted bike rack. I've used a couple of hitch-mounted racks over the years on 2" receiver openings, and they work well. But with a smaller receiver opening, I'd be nervous about the rotational stability of the rack mount with the receiver, especially if you use an adapter to get the rack to mount to the smaller opening. I'd personally on an RLX consider a trunk-mounted rack instead. Just my $.02...
andy
Old Mar 29, 2024 | 09:58 AM
blaser's Avatar
thanks
mrfuni
Oct 25, 2014 06:28 PM
clarky0169
Oct 26, 2012 09:25 AM
dave9214
Oct 6, 2009 09:49 PM
jeeper31
Mar 21, 2008 07:34 AM
