Technical issue regarding the phone memory dial
Folks, I have a silly question. Why did my phone address book get deleted? I only have a few numbers I call most often that I have in the speed dial, but they disappeared. Any ideas as to why?
by speed dial, do you mean shortcuts?
Did you give it time to populate? When I start the car, it takes several minutes before the history is populated.
Shortcuts are on the other display
Did you use the Driver 2 Key yesterday? If you lock the car with your key fob and walk away for a few min, then unlock it are they still not showing up?
No I did not use the other fob, but I ended up entering the info in again. It was not a problem, but I was curious as to why it happened. I wonder what caused the info to go away? Everything else is fine and operating normally. Any ideas? Just a glitch in the system?
pgeorg (05-22-2017)
I really can't think of a reason......maybe one of the many 2014 infotainment bugs.....
Could be. No big deal. We should all have these kinds of "inconveniences". High class problems I say.
pgeorg (05-22-2017)
I have an HFL gremlin that pops up every now and then. It has only happened so far after I have been operating car, stop for gas shut off car and then restart. The HFL connects and I can make or receive calls, but the mic does not work I can hear the other person, but they cannot hear me. I have rebooted phone, but that does not fix it. And, i I transfer to phone, the phone mic works. I have to stop and turn off car for several minutes. Annoying when it happens.
RLX Advanced #3606
I have had a few instances of that occurring, I have always attributed it as a "Brain Dump".
I pull over and do a full shut down the and restart which has brought everything back up..
Grandpa
Received 2,609 Likes
The iPhone 7 Plus.
It'll always link and you will always be able to make calls.
However SIRI won't take over the car's speakers since one of the iOS upgrades a while back.
And as Bluetooth versions advance on the iPhone, they have become glitchy on the Acura, sometimes not syncing the contacts, not forming the voice tags properly, or not syncing the previous calls list.
I am on a beta of 10.3.3.
Grandpa
I'll tell you what really annoys me:
You get used to using SIRI to make calls, so you inadvertently say, "Hey SIRI, call...." when you are driving.
It can take so long to get the call transferred to the Acura speakers that the recipient of your call might very well hang up.
